Chelsea's first build F-14A Tomcat
Chelsea
Post by Chelsea »
Hi everyone this is my first time and first build I'm working on the F-14 Tomcat academy model scale 1/72
So far it's all going well I'm taking my time doing a little bit a day.
My plan is to build and paint in sections, pre-painting the wings before I fit them to the fuselage and then giving the fuselage wings a final coat when assembled.
Currently I don't own an airbrush but I'm pretty good with spray pack paints using them many times before for different things.
The fuselage itself needs a little putty on one of the areas the rivits was joining it too the plastic brackets and I did sadly get a little glue fingerprint on the wing which I've sanded heaps n heaps trying to smooth it down without taking the flap markings off.
I currently would love to weather the tomcat but I don't have the skills as of yet.
I'll include some photos of my work so far and thank you for letting a girl play planes as well it's a fantastic fun hobby and so far loving it c:
Cats, tigers, leopards and planes <3
Chelsea
Re: Chelsea's first build F-14A Tomcat
Post by Chelsea »
Some photos c:
Chelsea
Post by Chelsea »
Priming some parts to see how they look, using some white primer and hoping for the best.
Updat on my wing I had to sand sand fill and sand I think I made a complete mess of the wings thankfully it's only a cheap kit.
This is my first kit so I'm nervous yet experimental with different ideas.... hopefully it won't look too ugly cause I would still love to display it even if it's not a masterpiece it's still something I'm learning
jmatt
Post by jmatt »
Watching... and good luck! :pop:
Btw, the Tamiya Fine spray primer is foolproof; love the stuff. Light coats with ample dry time between.
Chelsea
Post by Chelsea »
Hi Jmatt
I'm well on my way now to building something yay
I've decided to modify a few things tho, I've decided to leave off the undercarriage and try and modify a cover so I can hang my model afterwards and also see if I got what it takes to modify things :)
I've decided to sand the primer lightly and attach more of the under the fuselage and I'm going to try and get slightly colour differences to show a kinda "used" weathered affect c:
Anyways I'll keep you posted and upload some more pics today
Chelsea
Post by Chelsea »
Some progress yay
looking good.
A fine felt tiped or gel marker pen can be used to pre shade some area's. Not all though , just panel lines.
:th: :cheers2:
Chelsea
Post by Chelsea »
Hi thank you
I'm learning heaps n heaps, im learning about assembly process and preparation.
Some thing I've learned are to prime after the plane is together and also that some pieces are the same looking but slightly different
Pre shading looks awesome I can see that it will come through, I've done most of the shading uneven cause I think that it night look more normal.
I'm hoping to have something that resembles a plane by the weekend possibly have a coat of grey by Friday yippee
Chelsea
Post by Chelsea »
Some more progress photos, I decided that I wanted a cleaner look without undercarriage, it's incredibly hard to mark panels fit that aren't made for the job
Think I'm in too deep
Wishing I had the skills that that others
Looking good :th:
