Hobbyboss 1/72 Me163b Komet
Elve1984
Post by Elve1984 »
I don’t know if i post this in the right sub forum as it technically is a rocket powerd glider instead of a Jet aircraft. If its not admins then please move it to the correct subforum.
During our new years gathering of my local IPMS department i ran into this kit. I tought it would be a nice kit to try out my new airbrush, It was cheap and had a low parts count so i tought i would have it togheter quickly and would be spraying quickly.
The kit has got a pretty good surface detail overal but lacks a bit of cockpit detail. I planned to use this mostly as a airbrush experiment. As the cockpit was really empty i desided to do a little bit of scratch building to add some more detail. I havent got a whole lot of scratchbuilding experiance so this was also a nice way to experiment on that part.
The boxart
ImageIMG_4586-1024px-cp by Leon Vercruijsse, on Flickr
A peak inside the box
ImageIMG_4587-1024px-cp by Leon Vercruijsse, on Flickr
The cockpit is pretty empty
ImageIMG_4588-1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4589-1024px-cp by Leon Vercruijsse, on Flickr
Scratch builded a dashboard and side console’s
ImageIMG_4590-1024px-cp by Leon Vercruijsse, on Flickr
Glued in place
ImageIMG_4591-1024px-cp by Leon Vercruijsse, on Flickr
Added some lead wire detail
ImageIMG_4604-1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4605-1024px-cp by Leon Vercruijsse, on Flickr
After a Ultimate black primer coat.
ImageIMG_4607-1024px-cp by Leon Vercruijsse, on Flickr
Next up detail painting the cockpit and glueing everything in place.
Fridgy
Re: Hobbyboss 1/72 Me163b Komet
Post by Fridgy »
Wow, for not much experience scratch building, you did a great job.
Looking forward to where this one leads
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
SolventSolution
Post by SolventSolution »
Nice job so far. I don't even know where to start with scratch building...someday.
Revel 1/48 F-15E Strike Eagle
Elve1984
Post by Elve1984 »
Thanks for the compliments everybody. To be honest i didn't had a clue where to start on the scratchbuilding part, so i started with looking at some pics and went with the idea's that came to my mind with this as the result.
In the mean while i got the cockpit painted up and gave it a little bit of a wash and flatcoat. The flatcoat isn’t completely dry yet on the pics.
ImageIMG_4611-1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4612-1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4613-1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4614-1024px-cp by Leon Vercruijsse, on Flickr
After that I got everything glued togheter and masked the canopy.
ImageIMG_4615-1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4616-1024px-cp by Leon Vercruijsse, on Flickr
And sprayed on some Ultimate Black Primer.
ImageIMG_4617-1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4618-1024px-cp by Leon Vercruijsse, on Flickr
Now its time to get my new Airbrush out and apply some camo.
Elve1984
Post by Elve1984 »
I got some paint work done. Its the first time i used my new airbrush, the H&S infinity with a 0.15 needle. It’s really amazing, the amount of control you have with this. I am really happy i bought it. I sprayed my ME163 with Mr Hobby Aqueous colors thinned with some Ultimate thinner.
The lower part of the aircraft is painted RLM76 Light Blue, i used Mr Hobby H417 for this.
ImageIMG_4723_1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4724-1024px-cp by Leon Vercruijsse, on Flickr
The paint went down really well, its hard to see on the pics but the black base color gives some nice shading.
I masked the bottom half of the plane for the top paints.
ImageIMG_4725-1024px-cp by Leon Vercruijsse, on Flickr
After this i sprayed the first top color RLM82 Light Green, i used Mr Hobby H422 for this.
ImageIMG_4726-1024px-cp by Leon Vercruijsse, on Flickr
I masked the RLM82
ImageIMG_4727-1024px-cp by Leon Vercruijsse, on Flickr
Then it was time for the second top color RLM81 Brown Violet, for this i used Mr Hobby H421.
ImageIMG_4729-1024px-cp by Leon Vercruijsse, on Flickr
Time to remove all the masking and check out the end result.
ImageIMG_4985-1024px-cp by Leon Vercruijsse, on Flickr]
ImageIMG_4986-1024px-cp by Leon Vercruijsse, on Flickr
I am pretty happy with the result. Now its time to do some small detail painting with a brush and apply some gloss.
Elve1984
Post by Elve1984 »
I got some more work done, first applied a coat of Alclad II clear gloss.
ImageIMG_4988-1024px-cp by Leon Vercruijsse, on Flickr
After some drying time i applied the decals. But i forgot to take a pic of this. The instructions are verry unclear about the application. Wich decal goes where. Some numbers are on the instructions 2 times while there is only 1 decal. Some decals are on the sheet but not on the instructions. So i used some artist impression.
After the decals followed an other coat of Alclad II clear gloss. I let it try a couple of more days and weather the bird a little bit with some Tamiya Black Panel line wash.
ImageIMG_4992-1024px-cp by Leon Vercruijsse, on Flickr
ImageIMG_4993-1024px-cp by Leon Vercruijsse, on Flickr
Next up is a Flat coat and then i am calling this bird done.
arilo76
Italy
Post by arilo76 »
Really nice Komet and nicely done.
Antonio
Stay Classy ISM
Elve1984
Post by Elve1984 »
Thanks, got the flatcoat on, but still need to take some pics.
Elve1984
Post by Elve1984 »
As photobucket blocked everything i moved my pics to Flickr, so everything in the buildthread should be visable again.
