German fuel drums - colour?
Greeting All
A quickie if I may. Is there a consensus as to what colour German fuel drums were in WWII?
I've seen a plethora of colours while searching so I'm not too sure.
Thanks
Re: German fuel drums - colour?
I think it depends on when they were issued and what paint the field unit had available.
I've seen them in field grey, dark grey (panzer grey) and dark yellow as well as rusted and wrecked like the one in schweinhund's photo. My guess would be that they would also have been camo'd and whitewashed if the units deemed it necessary in the field as well.
Thanks Guys - much appreciated
As well as captured and reused drums
digger303 wrote: Wed Mar 01, 2017 10:23 pm As well as captured and reused drums
Excellent. A bit of artistic licence then. I'll just go for what I think looks ok. :th:
ForbesHutton
Post by ForbesHutton »
Don't forget that some would still be in primer. I don't know when it started, or if the Germans did it, but around here it seems black is used on a drum to indicate it's some sort of lubricant, not fuel.
ForbesHutton wrote: Thu Mar 02, 2017 1:45 am Don't forget that some would still be in primer. I don't know when it started, or if the Germans did it, but around here it seems black is used on a drum to indicate it's some sort of lubricant, not fuel.
Good stuff. Thanks. I've got 6 drums which I plan to cluster together. Varying the colours seems like a good move so I think I'm going to go for a mix of fading black and grey. I'll use a lot of oils on them for rust and dirt so hopefully they'll look authentic.
Thanks again to everyone for the replies :th:
Thanks for all your help guys. This is what I ended up with.
OneSmallStep1966
Post by OneSmallStep1966 »
Very nice. What make are the fuel drums, Tamiya?
OneSmallStep1966 wrote: Thu Mar 02, 2017 6:22 pm Very nice. What make are the fuel drums, Tamiya?
Yes indeed, Tamiya. The set contained 6 drums, 2 types of jerry cans and some buckets. Its a very old set and the drums needed some TLC before they were ready for painting. I added the connectors on the side of each barrel by cutting rings from the plastic tubes that make up cotton buds. I'd seen them on other barrel sets purporting to be German barrels and the Tamiya set was missing them.
connectors are for lego.....bungs old fella :th:
digger303 wrote: Thu Mar 02, 2017 10:34 pm connectors are for lego.....bungs old fella :th:
Bungs they are then :lol:
