Trumpeter 1:48 MiG 23BN Flogger H
Joesdad
Post by Joesdad »
A new build for me, I'm hoping to rattle through quite sharpish.
Here's my review of the kit...
viewtopic.php?f=352&t=21539#p267389
Hopefully the following pictures will be self-explanatory, if you have any questions please fire away..
Not bad detail on the cockpit sidewall
Oh dear!!
Detail painting before construction, something an armour Modeller doesn't have to worry about...
I've had this unopened bottle of MIG for about two years now, my only one..
This is the nose wheel bay all in bits...
Some seat stuff..
Moving on to the engine..
See you soon lads :D
Tim (Ted)
British Aviation In Scale
IanG
Re: Trumpeter 1:48 MiG 23BN Flogger H
Post by IanG »
Great start. Cockpit's coming along nicely.
Joesdad
Post by Joesdad »
IanG wrote: Thu Mar 09, 2017 9:19 pm Great start. Cockpit's coming along nicely.
Cheers Ian :th:
Tim (Ted)
Joesdad
Post by Joesdad »
Cracking on with it....
You can certainly see bad paintwork close up :crazy:
Wish I had a decent camera :roll:
Fuselage going together...
I thought I'd colour in the main landing gear bay
Wings next, motoring on...
No fit issues yet...
Working folding wings!
My very own Gundam :dance:
Brilliant :wall: what a t**t!
We'll see what it's like after a prime..
Air intakes after some paint, weather, and mask..
Landing gear bay after paint, weather and matte...
First fit problem. Had to trim some material to get the wing/fuselage fitting nicely (dry)
Where we stand now..
Phew!
Back soon..
Tim (Ted)
IanG
Post by IanG »
I had the same problem with the fit on that top fuselage/wing section. I thought it was because of the CWS resin correction set, but it seems to the kit itself.
Good progress :)
Joesdad
Post by Joesdad »
IanG wrote: Fri Mar 10, 2017 11:37 am I had the same problem with the fit on that top fuselage/wing section. I thought it was because of the CWS resin correction set, but it seems to the kit itself.
Good progress :)
I think it is the air intakes are set back a gnats chuff too far, after some sanding and shaving we're good to go..
Cheers Ian
Tim (Ted)
jelliott
Post by jelliott »
I had the same exact problem on the Trumpeter Mig 23MF Flogger-B kit. So it is definitely something with the molds for the Mig 23 series of aircraft. I had to shave and thin the main gear housing to get it to fit "somewhat" properly. I was still left with a small gap that I filled with Perfect Plastic Putty and it looked better.
Hasegawa F-4G 1/48
Academy U-2S 1/48 (temporarily on hold)
Joesdad
Post by Joesdad »
jelliott wrote: Sun Mar 12, 2017 3:11 pm I had the same exact problem on the Trumpeter Mig 23MF Flogger-B kit. So it is definitely something with the molds for the Mig 23 series of aircraft. I had to shave and thin the main gear housing to get it to fit "somewhat" properly. I was still left with a small gap that I filled with Perfect Plastic Putty and it looked better.
Yeah Jelli it's no biggie but couldn't work out for the life of me what it was!
Tim (Ted)
jelliott
Post by jelliott »
Not trying to hijack your thread by any means, but here is a shot of the MF Flogger-B that I'm finishing up. Hard to see the area here.
Hasegawa F-4G 1/48
Good work so far.
Joesdad
Post by Joesdad »
Thanks chaps
A little more. Canopy masked, tho it's a bit rough! Cockpit colour applied and waiting for primer..
After that I'd thought I better have a go at some weapons
Oh jeez!!! I thought decalling was bad enough..
The final result...
:crazy:
Tim (Ted)
arilo76
Italy
Post by arilo76 »
Hi Tim
really liking your progress, One question how is fitting of the kit? appart the part that you had to sand down the back of the wings.
Thanks
Antonio
Stay Classy ISM
Joesdad
Post by Joesdad »
arilo76 wrote: Tue Mar 28, 2017 11:09 am Hi Tim
Thanks
Hi Antonio,
Kits fits good, the join where the nose fits on to the fuselage needs some attention and you have to be careful aolround the air intakes but other than that going good. Weapons though are getting boring...
Tim (Ted)
arilo76
Italy
Post by arilo76 »
Joesdad wrote: Wed Mar 29, 2017 2:52 pm Hi Antonio,
Thanks Tim
I know i hate doing weapons, i will added to my wish list in Scalemates :lol:
Antonio
Stay Classy ISM
Joesdad
Post by Joesdad »
A tiny bit more.
After a black prime, I've got the bombs all painted and Clear coted. Next is too wash the little buggers. I've tried to mottle and vary the paint on them, tho you probably can't see it very well. The silver looks awful
Started on the main camo, then got fed up with it.. I'll try again later..
TTFN
Tim (Ted)
Joesdad
Post by Joesdad »
Some time later....
And re-sprayed whatever they are, much better..
A wash applied to the racks and bombs..
Just need a full cote...
More camo work...
Wheels..
Back in a bit..
Tim (Ted)
Joesdad
Post by Joesdad »
Phew! Thought I lost these snaps
Undersides. The colour is more blue in real life..
Close-up..
TTFN
Tim (Ted)
ElCapitan
Post by ElCapitan »
Looks great so far Tim
ElCapitan
arilo76
Italy
Post by arilo76 »
Tim that is some really great paint work and the weapons i really like the weathering on them, well done!! one question the wheel what did you use, they are really cool.
Antonio
Stay Classy ISM
Elve1984
Post by Elve1984 »
Great looking Mig, intresting color scheme.
Joesdad
Post by Joesdad »
arilo76 wrote: Wed Apr 12, 2017 7:46 am Tim that is some really great paint work and the weapons i really like the weathering on them, well done!! one question the wheel what did you use, they are really cool.
Hi Tony, thanks mate. Tamiya rubber black, for the rims I used one of them plastic circle template things and to finish a little dry brush. Hope that helps
Tim (Ted)
Joesdad
Post by Joesdad »
Thanks chaps :banana:
Tim (Ted)
arilo76
Italy
Post by arilo76 »
Joesdad wrote: Thu Apr 13, 2017 6:32 am Hi Tony, thanks mate. Tamiya rubber black, for the rims I used one of them plastic circle template things and to finish a little dry brush. Hope that helps
Thanks Tim :th:
Antonio
Stay Classy ISM
rwsmith14
Post by rwsmith14 »
she's looking good.. looks like she'll have a full loadout.. NIce !
Joesdad
Post by Joesdad »
Decaling time :dance:
Phew! That was easy....
All ready for some AquqGloss...
Ah! Sorry about the photo :nena: I had to stay like that till it was dry :roll:
Tim (Ted)
arilo76
Italy
Post by arilo76 »
Tim that is looking really nice.
Antonio
Stay Classy ISM
Joesdad
Post by Joesdad »
Now the Flogger has dried, it's time to apply a wash, namely an oil wash. Homemade, dark brown/black oil mix thinned the odourless sprits
Tailplanes..
The right hand (as you look) has been washed, left hand not...
Photobucket has decided to pack up on me, we'll have continue later :wall:
Tim (Ted)
Goose
Belgium
Post by Goose »
nice job mate!!!
love it
Bruno
Finished models:
on the bench:
F-16 solo turkish Revel-1/72
ElCapitan
Post by ElCapitan »
That looks great Tim, the wash makes all the difference!
ElCapitan
Joesdad
Post by Joesdad »
Thanks guys, but I did mean to post up the following but Photobucket decided to have a breakdown :wall:
Coming to the end of this one....
Tim (Ted)
Elve1984
Post by Elve1984 »
That wash really makes the detail pop out. what sort of Gloss coat did ya use under it?
arilo76
Italy
Post by arilo76 »
Really nice work Tim, definitely the wash made all the details stand out.
Antonio
Stay Classy ISM
Joesdad
Post by Joesdad »
Elve1984 wrote: Sun Apr 23, 2017 1:44 pm That wash really makes the detail pop out. what sort of Gloss coat did ya use under it?
Hi Elve, it was Alclad AquaGloss and very good it is too..
arilo76 wrote: Mon Apr 24, 2017 7:32 am Really nice work Tim, definitely the wash made all the details stand out.
Thanks bud. I like the way that an oil wash slightly filters down the paint, makes it look really grubby..
Tim (Ted)
Elve1984
Post by Elve1984 »
Joesdad wrote: Mon Apr 24, 2017 2:01 pm
I use that aswell, but it have the idea it doesn't dry rock hard or softens again when i apply a wash. how long do you let it dry before you apply the wash?
and what sort of wash do you use? wich paint and thinner?
Joesdad
Post by Joesdad »
Elve1984 wrote: Tue Apr 25, 2017 3:54 pm
I've just started a new bottle, I believe they may have altered the formula so the jury is out. Having said that I've had no problems yet, sets rock hard. Usually leave 24hrs and this wash is an oil wash using odourless sprit's.
Hope ok for you Elve
Tim (Ted)
