Bondo Glazing & Spot Putty
expc624kevneale
Post by expc624kevneale »
:scratch:: Paul on last nights at the bench was using Bondo Glazing & Spot Putty. I have found it on line for £9:90 can anyone tell me what is the best to use to thin it down to apply it by brush to joints etc.
Re: Bondo Glazing & Spot Putty
It is lacquer based
Paul used Mr Hobby Levelling Thinner...and then almost died from the smell if you remember the live chat
expc624kevneale
Thanks for that didnt hear the chat had to go before it came on just saw that he was using it. If Mr Hobby is so bad will have use a spray mask and mix it outside.
Thanks for the info.
No worries
Careful with the putty as it can be a bit too "hot" for some plastics and melt it instead of just fill
Test it out a sprue first maybe
Return to “Glues and Fillers”
