martins revell 1/72 scale fairey gannet AS1/4.
martin57
Post by martin57 »
HI to all.
this is what i will be building for this GB.
it looks to be a good kit ,there is some flash here and there , but it is a 10yr old kit .
Image[/U
as you can see there are a few steps to this kit .
Now for some info.
Development
The Gannet was built in response to the 1945 Admiralty requirement GR.17/45, for which prototypes by Fairey (Type Q or Fairey 17, after the requirement) and Blackburn Aircraft (the Blackburn B-54 / B-88) were built.
After considering and discounting the Rolls-Royce Tweed turboprop, Fairey selected an engine based on the Armstrong Siddeley Mamba: the Double Mamba (or "Twin Mamba"), basically two Mambas mounted side-by-side and coupled through a common gearbox to coaxial contra-rotating propellers. Power was transmitted from each engine by a torsion shaft which was engaged through a series of sun, planet, epicyclic and spur gears to give a suitable reduction ratio and correct propeller-shaft rotation.
Newly assembled Gannet AS.4 at Manchester Airport, June 1956
The ASMD.1 engine (2,950 hp/2,200 kW) was used in the Gannet AS.1; ASMD.3 (3,145 hp/2,345 kW) in the AS.4; and ASMD.4 (3,875 hp/2,889 kW) in the AEW.3 variant. The Double Mamba engine could be run with one Mamba stopped to conserve fuel and extend endurance for cruise flight. The contra-rotating propellers meant that when only half of the Double Mamba was running there were no thrust asymmetry problems. The Mamba exhausts were situated on each side of the fuselage, at the root of the wing trailing edge. The gas-turbine engine could run on kerosene, "wide-cut" turbine fuel or diesel fuel, allowing the Admiralty to eliminate the dangerous high-octane petroleum spirit required to operate piston-engined aircraft from carriers.
In 1958 the Gannet was selected to replace the Douglas Skyraider in the AEW role. In order to accommodate the systems required, the Gannet underwent a significant redesign that saw a new version of the Double Mamba installed, new radome mounted under the aircraft, the tailfin increased in area, the undercarriage lengthened and the weapons bay removed. A total of 44 aircraft (plus a single prototype) of the AEW.3 version were produced
Operational history
The prototype first flew on 19 September 1949 and made the first deck landing by a turboprop aircraft, on HMS Illustrious on 19 June 1950, by pilot Lieutenant Commander G. Callingham. After a further change in operational requirements, with the addition of a radar and extra crew member, the type entered production in 1953 and initial deliveries were made of the variant designated AS.1 at RNAS Ford in April 1954. A trainer variant (T.2) WN365 first flew in August 1954. The RN's first operational Gannet squadron (826 NAS) was embarked on HMS Eagle. The initial order was for 100 AS.1 aircraft. A total of 348 Gannets were built, of which 44 were the heavily modified AEW.3. Production was shared between Fairey's factories at Hayes, Middlesex and Heaton Chapel, Stockport / Manchester (Ringway) Airport.
An Australian Gannet AS.1 on the USS Philippine Sea in 1958.
By the mid-1960s, the AS.1s and AS.4s had been replaced by the Westland Whirlwind HAS.7 helicopters. Gannets continued as Electronic countermeasures aircraft: the ECM.6. Some AS.4s were converted to COD.4s for Carrier onboard delivery—the aerial supply of mail and light cargo to the fleet.
The Royal Australian Navy purchased the Gannet AS.1 (36 aircraft). It operated from the aircraft carrier HMAS Melbourne and the shore base HMAS Albatross near Nowra, New South Wales.
Indonesia bought a number of AS.4 and T.5s (re-modelled from RN AS.1s and T.2s) in 1959. Some Gannets were later acquired by various other countries.
West Germany bought 15 Gannet AS.4s and one T.5 in 1958. They operated as the anti-submarine squadron of Marinefliegergeschwader 2 (2nd Naval Fighter Wing) from Jagel and Sylt. In 1963 the squadron was reassigned to MFG 3 at Nordholz Naval Airbase until the Gannets were replaced by the Breguet Br.1150 Atlantic in 1966.
OK on with the build .
[URL=http://s1150.photobucket.com/user/marti ... z.jpg.html]Image
built in wing spar thats always good , here are the first parts cleaned and ready .
bomb bay , upper deck and nose wheel bay .
had to sand the wing spars a bit so that thay would slide in and out ok, because there will be a far bit of dry fitting going on.
dry fitting went ok so far, looks like i will not need the filler .
next up fitting the control pedels and joy stick , and the excuset out lets ,make sure you get these the right way round.
The next step was to cut of and clean up the cockpit parts and seats.
i will be using the decals for the control panals so sanded of the moulded details.
then primed it all in UMP primer.
so there you have it , so far so good .
thanks for coming :cheers2:
arilo76
Italy
Re: martins revell 1/72 scale fairey gannet AS1/4.
Post by arilo76 »
interesting kit and nice progress so fare , let me how it goes together.
Antonio
Stay Classy ISM
Yep, this one is different
Never seen a bird like that before :thumb2:
Good Luck :cheers2:
TommyKillander
Post by TommyKillander »
Great start ! :th:
Keep up the good work :)
Tommy
martin57
Post by martin57 »
Well back again for another update.
this time i painted over the primer with a coat of aluminum, followed by a coat of satin black so i could do a bit of wear and tear .
i had a problem with the kit clear parts for the side windows, thay did not fit and looked rubbish,so i tried using revells clear glue.
it worked not great but still looked better then the kit parts .
[IM]http://i1150.photobucket.com/albums/o60 ... 8bdlz7.jpg[/IMG]
while waiting for the clear to go of i hand painted the cockpit , with the trusty tooth pick .
and made a bit of wear and tear .
i used the kit decals for the seat belts , just to see how thay looked.
not going to bad so far .
next up putting it all together , i used a slow setting glue for this part ( revell pro ) so i had time to line everthing up.
Right one thing it does not tell you in the instructions is to add nose weights or how much, so i broke out the led .
and at this stage cleaned up the radar dome and hook.
Got all that sorted, now to see if it all goes together , i glued up the wings as well,
i am pleased to say it fitted together well i used tape to hold it tight whilst it set but all in all i am happy .
Ok last bit for this up date .
broke out the rudder, elevators
one point to note on the elervators there is a slot for a staberlizer and it is very weak and that is were the sprue gate is attached .
Ok thanks for coming see you next time :cheers2:
Nice start Martin. Big old bird the Gannet.
arilo76
Italy
Post by arilo76 »
Martin really nice progress. :th: :th:
Antonio
Stay Classy ISM
SkyPainter303
Post by SkyPainter303 »
Lookin' good. This is a lot more involved than the Trumpeter Gannet.
martin57
Post by martin57 »
Hi to all.
this is a very quick up date on the build , because i will be away from the bench for a week. :cry: .
so i wanted to get the wings and tail end sorted , i thought that would be a good finishing point.
there was some filler needed ,i used the tamiya putty .
i have some work to do on the leading edges of the wings , just some gentle sanding will do it i think .
well i just had to do a little bit more (just cant leave it alone can you :lol: )
the front under cart doors needed to be separated for the wheels down position.
right just before i go ,on my last post one of the photos did not load so hear it is.
the use of the klear from revell to replace the rubbish kit clear parts.
Right thats it i am off buy for now , and thanks for coming :cheers2:
jnbattleship
Post by jnbattleship »
Good progress so far. I am starting to think that this kit is very under-appreciated in the modelling community.
Google / Youtube - TheRohalla
martin57
Post by martin57 »
HI to all, hope everybody is well.
well back to it after a bit of a break , due to other jobs to do.
first job was a coat of black primer (U.M.P)
this went down without any problems.
then moving on to putting some tamiya matt white and some AK sky down in a sort of patchey way ,never done it this way before so lets go for it.
did not come out to bad , a bit tricky but with practice in the future should get it sorted .
i also did the upper surfaces , just in the matt white ,to help with the highlights on the extra dark sea grey.
when that was all dry i gave the underside a couple of thinned coats of the sky .
the odds and sods i am painting on the sprue this time .
well iam hoping to finish on time all being well.
thanks for coming see you all soon :cheers2:
jnbattleship
nice progress, always like the stage when it looks like an aircraft :)
martin57
Post by martin57 »
HI all , hope every one is ok.
this build has been a bit slow for me this time , my old mate zak ,the dog has been ill of late and it has come time to say goodbye ,the wife and i have been caring for him for the last couple of months but he has had enough now , the vet is coming to the house tuesday the 20th .
he has been a great mate for the last 12yrs.
right ok.
after painting the under side , i masked of ready to paint the upper side, to get the curve up the tail i used some of the narrow tape from the U M P SHOP good stuff.
i went with the revell paint call out for a change ,
and here is the result , not to bad .
and the masking tape removed.
some touching up needed here and there.
After it was all dry i used this filter to put on a selection of panals ,it worked well.
NEXT up was the gloss coat using tamiya clear gloss , 2 coats and a rub down and we were good to go for the decals ,
some micro sol and set was applied to help settle things down.
THE cockpit glass is for me the main let down of the kit so far, it is very brittle and some do not fit well at all.
anyway got them sorted and masked of, along with the under cart .
thats it for now , hoping to get done by the weekend .
thanks for coming from me and my mate zak. :cheers2:
martin57
Post by martin57 »
OK here we go on the home straight .
props and undercarrige done ,sits nice .
canopys fitted
stretch sprue for radio wire.
the base was made up of a peace of shed roofing felt set in a childrens chalk board, and the tarmac lines were done with a heated nail, with some
model railway grass.
and she is all done .
thanks for looking .
final reveal photos are up. :cheers2:
Return to “Build Threads”
