Ungluing tamiya cement
I glued pieces with tamiya regular cement (white cap). But due to my damn cat they set in the wrong alignement. is there anyway to unglue it like CA glue ?
Re: Ungluing tamiya cement
It actually bonds two pieces together....can you slip a sharp blade between the pieces
It melts the plastic together, so may indeed need to cut apart
digger303 wrote: Sun May 07, 2017 1:41 am It actually bonds two pieces together....can you slip a sharp blade between the pieces
It's what i tought but asked before going ahead with the cutting.
Thanks again digger
Cymru
Post by Cymru »
I've found you can sometimes drop some TET on the join, wait about 30 secs and then start prizing them apart, just keep adding TET as you go!
Hanger:
STASH
WIP:
Current Projects
Orange Air Virtual Airline
Cymru wrote: Sun May 07, 2017 4:59 pm I've found you can sometimes drop some TET on the join, wait about 30 secs and then start prizing them apart, just keep adding TET as you go!
Sorry about my ignorance, but what is TET ?
ForbesHutton
Post by ForbesHutton »
Garion77 wrote: Mon May 08, 2017 11:36 am
Tamiya Extra Thin. (The green cap).
Return to “Glues and Fillers”
