Which Glue
privatepete
Which Glue
Post by privatepete »
Hi which is the best glue for clear parts ie windscreens any help
would be great :th:
Nev
Re: Which Glue
Post by Nev »
Micro crystal clear mate :thumb2:
On the Bench...
sheppsea
Re: Which Glue
Post by sheppsea »
This is the only Humbrol product I use; I've never had a problem with it but I can't say its the best because I have never needed to try any others
Re: Which Glue
My latest 'go to' glue is Deluxe Materials Glue 'n' Glaze.
privatepete
Re: Which Glue
sheppsea wrote: Tue May 30, 2017 6:31 pm This is the only Humbrol product I use; I've never had a problem with it but I can't say its the best because I have never needed to try any others
Avgas wrote: Tue May 30, 2017 9:19 pm My latest 'go to' glue is Deluxe Materials Glue 'n' Glaze.
Nev wrote: Tue May 30, 2017 6:17 pm Micro crystal clear mate :thumb2:
Thanks guy's for the info :th:
exmoor
Re: Which Glue
Post by exmoor »
I use micro mix with a drop of water to thin it a bit
paul shapland
Re: Which Glue
if you don't want it to come off tet can be used...without fogging. Also watch crystal cement.
Re: Which Glue
digger303 wrote: Wed May 31, 2017 1:04 am if you don't want it to come off tet can be used...without fogging. Also watch crystal cement.
TET can be used on clear parts? I did not know this. Did you have to use anything else to make it work?
privatepete
Re: Which Glue
exmoor wrote: Tue May 30, 2017 11:32 pm I use micro mix with a drop of water to thin it a bit
Thank you gentleman :th:
Re: Which Glue
aur0ra145 wrote: Wed May 31, 2017 7:57 am
No just used a minimum amount and had no problems. Cut off a piece of clear sprue and see for yourself. :th: :cheers2:
