It's Friday nights live at the bench hat have you been working on for Friday June 23rd *
WHAT HAVE YOU BEEN WORKING ON THIS WEEK?" - A NEW SEGMENT OF FRIDAY NIGHT'S ISM LIVE "AT THE BENCH" SHOW!
* Open now until 1 hour before the show on Friday, June 23rd*
Re: It's Friday nights live at the bench hat have you been working on for Friday June 23rd *
Bumping this up forward to get some posts
1/35 Tamiya US M4A3E8 Sherman "Easy Eight" - European Theater
Ultimate Black primer
Tamiya XF-62 Olive Drab
Aftermarket:
1/35 L186 ABER BARREL 76mm for M4A3E8 SHERMAN
Excellent kit. Really makes building it a joy. Next up will be getting the accessories painted and the initial chipping/weathering done.
Have an excellent weekend everyone!
Continuation of the Sea King 1/72 by Airfix
Airwaves PE set to detail up grills and such
Hull is together now shown here in Ultimate primer...now has a layer of Tamiya XF3 flat yellow
Lots to do before the June 30th deadline
build thread here:viewtopic.php?f=591&t=21908&start=120
:cheers2: all
Last edited by Twokidsnosleep on Fri Jun 23, 2017 5:06 pm, edited 3 times in total.
exmoor
Post by exmoor »
progerss on the suzuki telefonic primed with Ultimate grey primer top coat mrhobby x5 blue. Gloss coat zero one coat
would like to say a big thankyou for the guys on the forum for the help and adviceImage
paul shapland
TommyKillander
Post by TommyKillander »
Hey Guys!
Been working recovering the wingsection of my 1/48 Hasegawa J7W1 Shinden after a horrible accident where I tipped a bottle of Tamiya Extra Thin on the bench and the underside of the wing got soaked :bash: :bash: :wall: :wall:
I left the wing for a week for the glue to cure and after that I carefully sanded down the uneven surfaces and polished it with a Ultimate buffing stick. I managed to save the top side, but the underside had lost some details :violin:
I hope to start painting it this weekend, fingers crossed :)
Tommy
Nev
Post by Nev »
I have been finishing the cockpit for my 1/144 Bandai Slave 1.
I used Tamiya paints mixed with Mr Leveling thinner and Citadel metals for drybrushing, with an oil based wash for the weathering:
On the Bench...
1/72 Academy A10A & Revell T-72 for the Warring Weather GB. Not a lot of bench time this week but last week the A10 was Ultimate Black Primer and this week it's Vallejo Light Ghost Grey; now ready for masking for the Dark Ghost Grey camo pattern. The bashed up T-72 build is just about completed except for the tracks which will be added after initial painting; the tracks are link & length and I need to figure out how to bend the damaged set for the right hand side without losing too much detail.
Joesdad
Post by Joesdad »
Kinetic 1:48 Sea Harrier FRS.1, this is for the FAA SiG.
Painted in MRP-114 Extra Dark Sea Grey, I've also used the Eduard BigEd set, Master pitot tube and a Brengun boarding ladder.
A lovely kit which built up with out to much problem, some filler here and there but it was fine. The nozzles are a weak point as they don't really fit that well so be careful.
Build thread
viewtopic.php?f=591&t=21977#p273307
Final reveal
viewtopic.php?f=592&t=22638#p282298
TTFN
Tim (Ted)
British Aviation In Scale
That is a fantastic Harrier build made even better when you read the story behind that aircraft...Superb modelling :clap:
Joesdad
Post by Joesdad »
Twokidsnosleep wrote: Fri Jun 23, 2017 4:14 pm That is a fantastic Harrier build made even better when you read the story behind that aircraft...Superb modelling :clap:
Thank you Scott much appreciated mate. It is a good story all right :D
Tim (Ted)
Some excellent work again this week chaps well done keep it up.(oo errr)
Dan
DarrenCo
Post by DarrenCo »
1:24 Airfix Typhoon
Work and holidays has been getting the way of progress, but time to get back to it, still quite a it to do , but getting somewhere now. Time to get this finished off.
Used Ultimate Primer, Vallejo, Tamiya, Mr Hobby ( Humbrol acyrilc, first and last time i'm doing that! )paints. Aqua gloss and Mat
