It's Friday nights live at the bench hat have you been working on for Friday July 28th*
* Open now until 1 hour before the show on Friday, July 28th*
MakingModels
Re: It's Friday nights live at the bench hat have you been working on for Friday July 28th*
Post by MakingModels »
Started working on the Bandai Y-Wing for the Summer Sci fi Sig build.
Construction is as far as I can get it, I need to work on the Diorama before I can progress any further..
Check out the Section of the forum for this Sci Fi sig build, there is some excellent things happening...
ImageIMG_1658 by Karl Smith, on Flickr
warpedcrisis
Post by warpedcrisis »
PTDC0897 by andrew Haycock, on Flickr
Time to show the forum some love
Tamiya mini 1:24th scale
To many paints to list but the main colours are primed in Ultimate black primer, base coat Tamiya hull red
Ammo rust effects colour set and Vallejo London gray .
White was Ultimate white primer and then a couple of coats of Tamiya x2.
Weathering with mix of amm and ak interactive products
andrew
TommyKillander
Post by TommyKillander »
Hey guys!
I've been working on my AMK 1/48 Kfir C7 for The Holy Land GB.
Kit is very good with nice details and excellent fit, a really enjoyable build sofar.
Unfortunately I have lost some small parts on the belly of the aircraft so I had to scratchbuild replacements :bash: :wall:
But they turned out OK so everything is good :th:
The cockpit is almost ready now, so it's time to close it up and start masking the aircraft in preparation for paint.
ImageIMG_20170727_122204 by Tommy Killander, on Flickr
Tommy
JonMW
Post by JonMW »
Working on my Special Hobby AJ37 Viggen for the Warring Weather GB. Have started putting the fuselage together and rescribing the panel lines. Added Maestro colored PE to the cockpit as well as a resin seat from Pilot Replicas. Next up is fitting the resin wheel bays and getting the wings on.
Al MacNeish aka onemac
1/48 Tamiya Spitfire Mk IXe and AJ-1 Skyraider. Both:
Primed Ultimate Black (the old one)
Sprayed Ultimate Apex
Tamiya paints throughout
Stuffed up the spitfire decal on the fuselage so had to mask and paint - went too light on the sky
Raider coming along now has green paint in the wrong place :lol:
Thanks for looking
Al
ImageRaider_Spit by Alan MacNeish, on Flickr
