Airfix Supermarine Spitfire mkvb
My first Airfix kit. So far things are going together well.
Image20170816_044744 by Matthew Morvant, on Flickr
Image20170816_044814 by Matthew Morvant, on Flickr
StuartClark
Re: Airfix Supermarine Spitfire mkvb
Post by StuartClark »
Looking good!
Stuart
sheppsea
Post by sheppsea »
Very nice - I'm building this at the moment too :th:
StuartClark wrote: Wed Aug 16, 2017 5:14 pm Looking good!
sheppsea wrote: Wed Aug 16, 2017 5:25 pm Very nice - I'm building this at the moment too :th:
Thanks! I am no where near the collective talent here, but I am working on it.
A few updates from yesterday.
I got a little overzealous with the razor saw when I cut out the door opening. Oops!
Image20170816_152049 by Matthew Morvant, on Flickr
I had to do a little sanding on the the last bulkhead to get the two halves together.
Image20170816_153054 by Matthew Morvant, on Flickr
These little bastards have been the most difficult part of the build so far.
Image20170816_162907 by Matthew Morvant, on Flickr
A little overspray never hurt anyone, right?
Image20170816_162911 by Matthew Morvant, on Flickr
First stage of filling, need another
Image20170816_182138 by Matthew Morvant, on Flickr
Image20170816_182130 by Matthew Morvant, on Flickr
Added some more bits to the underside of the wings
Image20170817_160217 by Matthew Morvant, on Flickr
Instead of stuffing the canopy area with something, I chose to use canopy pieces that won't be on the final model. I applied Krystal Klear around the joints and let dry. I then cleaned up the overflow with a toothpick.
Image20170817_160209 by Matthew Morvant, on Flickr
I also finished out the wings and tail section.
Image20170817_160203 by Matthew Morvant, on Flickr
Please hold while I clean up the mess (and curse like a sailor) from dropping my airbrush...
Primed with Ultimate black (really not the Ultimate brand, but Ultimate is easier to spell than the other name)...
Image20170817_193322 by Matthew Morvant, on Flickr
My plan is to paint the entire body using Model Air Aluminum, then come back with hairspray, and then the top coat. I have never attempted this; hold on to your seat, I am sure laughs are sure to follow.
My test piece with aluminum and hair spray was a total bomb. I will need to find a different hairspray, the paint wouldn't stick. So, I skipped the aluminum and just sprayed my top coats.
I didn't have the "right" colors so I just picked what I liked. I heard a rumor there were no rivet counters here, so the wrong colors shouldn't bother anyone either.
Here is what I am using for anyone laughing along at home.
Image20170819_211107 by Matthew Morvant, on Flickr
This is the first camouflage pattern I have painted so I wasn't quite sure how it would turn out (or how to do it really). The bottom layer went on very well. I wasn't quite sure how to do the leading edges of the wings, so I just taped up the bottom surfaces and the let the paint fall where it may. I didn't try to only paint the base color where it was needed. I just sprayed up the whole thing.
Image20170820_174752 by Matthew Morvant, on Flickr
I missed the opportunity to photo the masking stage. I just used the 2mm Tamiya for curves to define the edges and then regular Tamiya to mask the insides. I did have to paint tear in a couple of places, and a few more where I nicked the body with the tweezers. Hopefully won't be too bad to fix.
Image20170820_205519 by Matthew Morvant, on Flickr
Image20170820_205507 by Matthew Morvant, on Flickr
SprueSurgeon
Post by SprueSurgeon »
I have the 1/24 version of this kit which by all accounts is completely dreadful.
Deuteronomy 32:35
1975GinjaNinja
Post by 1975GinjaNinja »
Nice, like he idea of using the spare canopy to cover the cockpit.
SprueSurgeon - the 1/24 version is right dog although I have seen some amazing models built from it. Was the first model I built getting back into the hobby. Even used a hairy stick to paint it. Not doing that again
Nige
Not too much to show from yesterday.
Landing gear is done. Which still needs some touch up.
Image20170821_212030 by Matthew Morvant, on Flickr
Prop is done. I don't know if I like the color of the cap. It is painted the same as the bottom, which is the correct match to the callout. However, it just looks like it doesn't belong. Thoughts?
Image20170821_212018 by Matthew Morvant, on Flickr
Image20170821_212052 by Matthew Morvant, on Flickr
I sprayed my model with Pledge Floor Care in prep for the decals.
Image20170825_060648 by Matthew Morvant, on Flickr
I am not sure what happened here. I think the water may have been too warm, I don't really know. I would love ideas. Something turned the finish cloudy. You can also see where I accidentally cut through the curve tape. I only sprayed one coat of green on top of the brown, but I still got a line through the decal .
Image20170825_060700 by Matthew Morvant, on Flickr
Let's all give me a round of applause for hosing one of the roundels on the bottom. Note to self: Self, don't mess with it after applying a generous coat of Micro Sol followed by a generous coat of Mr. Softer. :clap: :bash: :clap:
Image20170825_060800 by Matthew Morvant, on Flickr
It did lay down well, at least. I suppose I am going to have to paint match the color. Or, perhaps bullet damage is the way to go? Anyone have some tips on creating bullet damage to hide screw-ups?
I put another layer of pledge on the model after finishing up the decals. My Ultimate washes haven't come in yet so I made some out of pastels, water, and a drop soap. I can't say that I liked the results.
Image20170826_082449 by Matthew Morvant, on Flickr
Here is a shot prior to cleaning off. On a positive note your can't really see where I hosed the decal.
Image20170826_082508 by Matthew Morvant, on Flickr
Image20170826_083903 by Matthew Morvant, on Flickr
I may wash up the entire model and just wait for proper washes, or just call it a day and matte coat it.
EDIT: You can also see that I snapped off the antenna. I was just waiting for that to happen.
