Which filler?
HobbyModeller
Which filler?
Post by HobbyModeller »
Hey guys
I've run out of filler (I used Squadrons green putty) and need to restock in it as although I don't use It too much it's always handy to have some around.
However I'm at a loss as to what filler to use. Humbrol is probably the most accessable for me to buy but I had problems with there old formula.
What other fillers that are affordable and non-toxic would you recommend ?? :idea: Thanks
Re: Which filler?
HobbyModeller wrote:Hey guys
For myself, I use Vallejo's filler which is great it applies easy and you can fill a gap then while it off smooth using a moist cotton bud or allow it to dry in which it sands easy. ive been using it for over two years without a problem.
Recently I stated using deluxe materials perfect plastic putty' which works exactly like Vallejo's filler but with less shrinkage.
I think they are about the same price, but for me I would try the deluxe materials one.
I can't stand the humbrol filler at all, and only use squadron green for larger gaps.
If it would be of help I could do a review of different types of filler? Be it a video or photo review.
Re: Which filler?
EModels stock both, the Vallejo is half the price of the deluxe materials one.
Pages two and six I think
http://www.emodels.co.uk/plastic-kits/q ... ge=1&show=
HobbyModeller
Re: Which filler?
That would be great as the video would appeal to everyone not just me ;) I shall look into Vallejo but the only problem is that i'll need to mail it in :)
HobbyModeller
Re: Which filler?
Cheers for the link site's great :)
UKscalemodeller
Re: Which filler?
Post by UKscalemodeller »
Hobby modeller, where are you?
Re: Which filler?
I shall crack on with it this afternoon :D
Re: Which filler?
I don't use the Vallejo putty, find it far too soft and get too much shrinkage. I've always used white stuff and Mr Surfacer 500 as a two part fill, works perfectly. Although, just lately I've been using perfect plastic putty and it's ace :)
Re: Which filler?
Not trying to make your day harder... but have you ever tried to use Styrene ?
either rods or filaments (stretch sprue) to fill your gaps ? its free and it won't shrink !
in a bind it works well!
I also use Tamiya Grey putty and smooth it with their own brand of Lacquer thinner and works wonders
just my 2cents.
Re: Which filler?
schweinhund227 wrote:Not trying to make your day harder... but have you ever tried to use Styrene ?
just my 2cents.
Yeah that's a good way to fill gaps, I've used strips of plasticard to fill large seams before.
Video is uploading as I speak ill post it up once its done, be prepared as its got 35 mins of me waffling about fillers and that's only part 1 :D :lol: :oops:
Re: Which filler?
Yeah I use Vallejos Plastic Putty now as well. I have found that if you do want to sand it, let it dry for a good while (at least a day or so) as if not it doesn't sand very well, the sanding just basically pulls it apart. I have found that it doesn't shrink too much, nothing a quick second pass can't cure if needs be.
Re: Which filler?
Video has finally uploaded :roll: http://intscalemodeller.com/viewtopic.php?f=73&t=264
Don't know if its of any help.
HobbyModeller
Re: Which filler?
Cheers for the great advice guys I'll look into it unfortunately I live in the deep dark depths of Cornwall and there's very few model shops around, one sells RC kits and a few big Dragon 1/35 kits and there's a hobbycraft which stocks Airfix, Humbrol and Tamiya products. However stock in these shops varies and is usually limited meaning I rely on going to Exeter to pick stuff up or wherever I am on holiday in the Summer/Autumn :)
Once again thanks for all the advice !!
HamilkarBarkas
Re: Which filler?
Post by HamilkarBarkas »
I don´t have to use filler very often, i´m glad about it because i hate filling and sanding.
usually i need some tiny amounts of filler on my figures, i use Milliput there which is great stuff in my opinion.
Apart from that i use Revell filler from time to time, its not bad either.
HobbyModeller
Re: Which filler?
Well guys it seems that the higher powers are watching this forum :shock: as I have just heard a new model shop is opening very close to where I live, a proper model shop! Not only shall it have the normal Airfix Tamiya etc but also Miniart figures and the like along with the Vallejo range :D My problems seemed to be answered!
Re: Which filler?
HobbyModeller wrote:Well guys it seems that the higher powers are watching this forum :shock: as I have just heard a new model shop is opening very close to where I live, a proper model shop! Not only shall it have the normal Airfix Tamiya etc but also Miniart figures and the like along with the Vallejo range :D My problems seemed to be answered!
Brilliant news, hopefully well stocked for all your needs 8-)
Bagpiper
Re: Which filler?
Post by Bagpiper »
Great question. And Paul! I would love to see a video comparing the putty's and the two part ones as well such as Aves if you can get that in the UK. I would have no idea on shrinkage and to be honest the whole point is to fill a gap once without shrinkage I would think. Hope you get around to doing a video please.
Jim
Re: Which filler?
Bagpiper wrote:Great question. And Paul! I would love to see a video comparing the putty's and the two part ones as well such as Aves if you can get that in the UK. I would have no idea on shrinkage and to be honest the whole point is to fill a gap once without shrinkage I would think. Hope you get around to doing a video please.
Jim
I haven't seen aves over here jim? I will do a follow up video on these at some point :)
modellingmadness
Re: Which filler?
Post by modellingmadness »
Im using squadron white putty but I find it doesn't spread very well so i'm changing to either vallejo or deluxe materials.
Just have fun!
Re: Which filler?
Deluxe Materials is by far the best all round putty now :D
Fasolly1988
Re: Which filler?
Post by Fasolly1988 »
I'm using Revell Plasto putty. Very good one. Revell is making a lot of good quality products for our needs.
SteveC
Re: Which filler?
Post by SteveC »
I have heard of folks using Super Glue as a filler as it dries quick and does not shrink, does anyone have experience to share about that? :scratch:: I have looked here but not yet found anything about this.
Is one type of CR glue better than another for this?
~ What wisdom can be found
that is greater than kindness ~
SteveC
Re: Which filler?
Post by SteveC »
Thanks, I see that I got the initials wrong too.
I appreciate your input, that is certainly something to consider. :thumb2:
Return to “Glues and Fillers”
