Ism Friday's night live at the bench what have you been working on for *October 27th*
"WHAT HAVE YOU BEEN WORKING ON THIS WEEK?"
* Open now until 1 hour before the show on Friday, October 27th*
m1ks
Re: Ism Friday's night live at the bench what have you been working on for *October 27th*
Post by m1ks »
Current one is the Aston Martin Vanquish from the Bond movie Die Another Day.
Just finished painting the adaptive camouflage and quite pleased with the result.
Image20171024_163805 by mike michael michaels, on Flickr
ElCapitan
Post by ElCapitan »
Started detail painting the ejection seats for my 1/48 Academy F-14 build - these seats are part of the Aires cockpit set and I'm really impressed with the level of detail on them.
The black is just Ultimate primer, and everything else is Tamiya acrylics. Not perfect when zoomed in, but to the naked eye I'm pleased with how they look. I might give them a few touch ups before adding the PE seat belts.
ElCapitan
exmoor
Post by exmoor »
tamiya ford escourt cosworth sprayed in Ultimate black primer top coats done with zero paints then finel coat 2k gloss
Image20171026_101551 by Paul Shapland, on Flickr
paul shapland
TheSmoo
Post by TheSmoo »
Started building a 1:16 scale revell Peterbilt 359 conventional truck ( basically a reboxed version of monograms 1983 kit) nothing fits quite right, tons of flash etc but getting there, have managed to source the CAT yellow for the engine from zero paints, going to try and light this rig up with led lighting, not decided on a paint scheme as yet, looking at flame stencils for a ghost flame effect probably with zero paints again all the chrome will be removed and repainted in molotov chrome or buffing powders, still experimenting with those and Ultimate primer on it all.
Cyber Hobby 1/35 SU-85M Tank Destroyer.
Painted with Ultimate black primer, shadow coated with white then Tamiya paint for the base colour. Dot filtered with oils, chipped then sealed with aqua gloss. Then a a Ultimate dark dirt wash, more oils for rust streaks, dirt and fuel stains then finished off with dry pigments.
sheppsea
Post by sheppsea »
Been working on a Tamiya 1/48 Mosquito FB Mk VI
Have added the Eduard PE set. I am slightly disappointed with the set as although it includes a detailed instrument panel its missing panels in other prominent places, like the radios at the back of the cockpit
This was also my first attempt to add further details myself, which is the reason for all of the lead wire. I may need to order slightly thinner wire next time but I reasonably happy for a first attempt
All the PE and lead wire now has some Mr Metal Primer on ready for 'normal' priming over the weekend
MakingModels
Post by MakingModels »
Tamiya Mid production Tiger with white wash.
White wash is done using Ultimate 'Winter' Clay wash. tank is gloss coated so a little bit shiny..
Dio is coming along, plain old Polyfilla for the base and the tree's are Balsa..
**SHAMELESS PLUG**Video on how I made the tree's will be on my YT channel Sunday :nena:
ImageIMG_1983 by Karl Smith, on Flickr
Started a Tamiya 1/35 T-34/76. Coming along well so far. Simple kit that should build up quickly.
Hope everyone has had a great week!
AdamChallinger
Post by AdamChallinger »
Working on my diorama, finish line is in sight but still a way to go...
