Few Questions
Arkimede
Few Questions
Post by Arkimede »
Hi Guys,
I've collected few questions for you before starting modelling my brand new Macchi 205 Veltro:
◊ It is necessary to clean the plastic model with soap and warm water before starting building it?
◊ Could you please shortly describe every steps of an aircraft painting? From the primer to the final painting effects?
◊ I've read that natural brushes are better than synthetic ones? What's your thought?
◊ Why does someone highlight that it’s important to have teflon gaskets in an airbrush?
Hope you can help me with these topic. Thanks in advance to everyone wants to give me hints. :thumb2:
MajorTom2004
Switzerland
Re: Few Questions
Post by MajorTom2004 »
Arkimede wrote: Sun Nov 12, 2017 2:30 pm Hi Guys,
Hallo Arkimede.
I try to answer what I know :whistle: I am confident you will get more and different opinons here
- It is usually not necessary to wash the sprues, I never do, some modellers do always. A good idea is to clean the model before priming, I do it with Isopropanol. Resin must be washed or cleaned.
- My method: Primer / Pre-Shading / Color(s) / Gloss varnish / Decals / Gloss Varnish / Washing / Semi Matte or Matte Varnish. All layers are applied in thin to very thin layers with airbrush, except for the Washing, this I apply with a paintbrush.
- Since I only paint few with paintbrush, I prefer natural ones, I think the shape, flexibility and ability to keep paint are better, however they are more expensive. For airbrush cleaning and drybrushing I use sythetic (cheap) ones.
- teflon is more resistant against solvents. However, if you pull out the needle, do it always to the front of the airbrush, regardless what sealing you have in.
Hope this help, happy modelling.
Thomas
Cymru
Re: Few Questions
Post by Cymru »
Hi Arkimede!
1: It's not strictly necessary but I do it "just in case". It doesn't hurt and may save you hassle when you come to paint.
2:This subject is FAR to involved to be gone in to here. I suggest you view the many YT vids on the subject.
3: I only use sable brushes as they are suitable for all types of paint.
4: Teflon is resistant to all kinds of solvents and so won't melt away/corrode. With the exclusion of cheap Chinese AB's all AB's manufactured in the last ten years or so will come with Teflon seals.
Hope this helps!
Hanger:
STASH
WIP:
Current Projects
Orange Air Virtual Airline
