Trumpeter KV-1S/85 +Tamiya Russian army assault infantry
Dunhill2005
Post by Dunhill2005 »
This will be my second in progress.
Unfortunately, I have to tell you, I am working on the tank for some time and therefore I can’t show the assembly. Sorry!
Why do I make a progress? Schoof and I are working on very similar projects. Instead of a KV-1 he used a T-34/85, incidentally he makes it very good! Check it out!
We both want to help us a little on the figures. But I do not want to post my pictures in his topic. My aim is not to make a competition who is as far or what looks better.
Please be also honest, with your opinion about my kits. Criticism is welcome as long as it is constructive.
Construction could take a little longer, because I have no experience with figures. Also, I would like to build a small base, I've also never done. By the way I also try to be a father and husband. I even have to work ... Puh!!! Too much to do ...
GET STARTED:
Dunhill2005
Re: Trumpeter KV-1S/85 +Tamiya Russian army assault infantry
The KV-1S/85 was a Soviet heavy tank in World War II. In contrast to the KV-1 the KV-1S/85 received a 85-mm gun, which was derived from an anti-aircraft gun. Only a few were built. The performance data were similar to those of the T-34/85 - only the latter was faster but the KV-1S/85 was much more heavily armored.
Trying to install the 85-mm gun in a tank, already took place in 1939. However, development of a special tank for the gun was too expensive. With the emergence of the new German Tiger and Panther this development was taken by the Soviets in 1943 again. The main problem was the construction of a suitable gun. Any suitable proposals had a muzzle brake that was not accepted by the Soviet leadership, as they reduced the power of the gun.
With the release of the D-5T the construction with an appropriate tank could be started. Since the war was already far advanced less time in the development of a new tank could spent. Therefore they decided to install the 85-mm D-5T in the turret of the KV-1 and in the new developed IS-1. This was possible because the dimensions of the D-5T allowed the installation without any major modifications. Only the slewing ring had to be extended and the space for the radio operator in the interior fell off. Big problems with the serial production of the D-5T prevented mass production of KV-1S/85 and IS-1. When the gun finally stood in sufficient quantity, it was decided to incorporate the gun from now on in the new T-34/85.
The tank is not ready yet
EasyEight96
Malaysia
Post by EasyEight96 »
Great job on the tank there did you assembled the tracks and glued it before painting???
In -progress
Too many on the bench!!!
Matchbox Kits lover....
Dunhill2005
EasyEight96 wrote:Great job on the tank there did you assembled the tracks and glued it before painting???
Thanks...
I have painted the entire hull with my airbrush.
Then I mounted the tracks.Last I will paint them with a brush. I know it is not the best way...
Schoof
Post by Schoof »
Nice clean build .
Maybe not the best way to do the tracks but at least your tracks fit :(
Dunhill2005
Schoof wrote:Nice clean build .
I've seen your problem with the tracks.But I think you get the problem solved well.
As you have also solved the issue with the suspension... :thumb2:
Dunhill2005
Russian Army
During WW2, the Russian Armed Forces consisted of five main elements:
Ground Forces, Navy, Air Force, National Air Defense and Armed Forces Support.
The Ground Forces represented about 80% of the total manpower, being the largest in strength. It had approximately 5.300.000 military effectives at the outbreak of the Russo-German War in June 1941. However, devastating damage brought by the German Mechanized Forces resulted in more than 70% losses of its entire troop strength within five months. This led to a rapid reorganization of the Ground Forces, and with a help of the harsh winter climate of Russia, they managed to repel German’s advance just in front of Moscow. Due to the heavy losses, reorganized units became much smaller than before. The infantry reduced their divisional strength from 14.483 to 10.859. Tank Divisions, which had possessed some 20.000 armored vehicles, lost about 70% of them at the initial stage of the war. Most surviving Tank Divisions were disbanded, and the available tanks and crews were re-assigned to much smaller units like independent tank battalions or tank brigades. It was in 1945, just in prior to the end of the conflict, that the Russian Armed Forces recuperated the pre-war- level of their strength.
The main strength of the Russian counter-offensive was their tank troops. Following concentrated fire by their artillery units, the tank troops advanced in three groups, and many infantrymen rode on the tanks of the 2nd and 3rd groups. This infantry practice was unique to Russian tactics and was called “Tankoviy Desant” by the Russians. Since the Russian Ground Forces did not possess armored troop carriers like the German halftracks, an infantry battalion called the “Motor Rifle Unit” was attached to every tank brigade and assigned to close support the tanks. A Motor Rifle Unit consisted of about 500 infantrymen. Once encountering an enemy’s position, infantrymen would disembark from the tank, attack the position, and return to the tank. These infantrymen were spearheads of the attack, and due to the enemy’s defensive fire, liable to sustain heavy casualties. (Tamiya)
Is anyone read this? It’s a lot of text… :tongue:
Also the figures are not ready yet...
T3hGuppy
Post by T3hGuppy »
Really nice work dude.
Though you do realize one of the men doesn't have a head :shhh: lol :tongue:
Too much to list. !!
Dunhill2005
T3hGuppy wrote:Really nice work dude.
Shot down by an enemy. ;)
Schoof
Post by Schoof »
Wow great job on your Little men!!
Thats way beter then mine
Dunhill2005
Schoof wrote:Wow great job on your Little men!!
This is not a competition!
Wait until the washing... :ooops:
Schoof
Post by Schoof »
didnt mean it like that ;)
Dunhill2005
Schoof wrote:didnt mean it like that ;)
I know :D
wappynutter
Post by wappynutter »
Both yours and Schoof's builds are fantastic...
I personally haven't built any armour yet so both are better than I can do..... :th:
Regards Andy...Image
EasyEight96
Malaysia
Thanks...
No no I didn't mean to say that sorry :doh: its a nice build I'm just wandering should I leave the tracks last or to glue it on the hull
Sincerely sorry
EZ8
In -progress
Schoof
Post by Schoof »
Well that's up to you I Quess.
I like to put them on last (and discover that they don't fit :( )
But maybe you like it better to put then on from the start. ..
.so many builders so many building styles
It's mostly a personal taste thing Easy8. I myself will try to leave them off along with the wheels until I'm done painting. I find it easier.
For some modellers it's easier with them on.
I would suggest trying one build with them on and one off and see which one you are most comfortable with.
Dunhill2005
EasyEight96 wrote:
Thanks...
Sincerely sorry
EZ8
There is no reason to apologize. :thumb1:
I have not seen this as a criticism.Besides I've also asked to criticism if necessary.
I've never tried to mount my tracks afterwards but I will try this on my next kit.
Thank you :hi:
EasyEight96
Malaysia
Thanks for tips guys
In -progress
ww2hispanomodels
Post by ww2hispanomodels »
Really nice job! That KV-1S is spectacular! :thumb1:
Visit my Youtube page by this link: http://www.youtube.com/user/ww2hispanomodels
- Cyberhobby Sherman firefly tank 1/35
- Italeri 508 coloniale 1/35
- Revell V3000S german truck 1/35
- ICM katyusha rocket launcher 1/35
- Tristar Sd.Kfz.222 1/35
Dunhill2005
Moin moin
There is a little update about my soldiers.
The set of Russian soldiers is known a bit dated but I think it still very good. I like the poses of the soldiers, and they can upgrade a tank extremely.
I have painted my figures with the following colors:
Revell 82 dark earth for Coats and Hats
Revell 87 earth colors for the uniforms
Revell 85 Brown for the leather parts
Revell 385 Wood Brown for Pouch and Bag
Revell Anthracite 9 for Boots
The weapons, are not here to see, painted with:
50% 9 Revell Anthracite + 50% Revell 91 iron for the metal parts
Revell 84 leather brown for the wooden parts
All figures are coated with a thin layer 2 Revell clear varnish to cover shiny spots.
Badges and medals are painted with oil paints after Washing.
Dunhill2005
They look fantastic Dunhill. Nicely done.
I've used those same figures myself, I thought that they were really good for what they were.
You've brought them to life magnificently.
Dunhill2005
Thanks to a small medical operation I have more time for tinkering now.
No, no, no! No need for compassion .... :hand:
The Tank from Trumpeter is made of best quality. All parts fit great and are well detailed. There are individual track links, photo-etched parts, an aluminum barrel for the gun and copper wire for the tow cables are also available.
The whole kit was primed after assembly in burnt umber. Following the whole model was airbrushed in Russian green. Large flat surfaces have been brightened up with olive drab to show light weathering. Edges were dry brushed with a mix oil paints
(50% brown + 50% ocher).
Also some traces of oil and rust were displayed with diluted oil paint.
Next comes the Chipping and further processing of the lower hull.
Dunehill you did a first rate job on the shading and fading buddy.
It's excellent work.
Wow!!!
Good stuff!
gosselin2112
Post by gosselin2112 »
Nice work! I have the Tamiya KV-1 in the stash. Been in there so long that I have sort of forgotten about it. :) This thread is helping to spark some interest in building it sometime.
Russ
Very nice work dude :D
Dunhill2005
I need your help! :scratch::
I can’t decide myself how to position my soldiers on the tank ...
Left and right on the fenders or on the engine compartment cover?
If I positioned the figures behind they had cover by the turret but they would sit next to the exhaust pipes (Lots of protection but exhaust gases).
Left and right of the turret means no fumes, no cover and less heat from the engine. It may be cold in the east…
alextheblue
Post by alextheblue »
Very nice Dunhil, love the progress so far. The figures are great and using olive drab with the Russian green works really well - gonna have to steal that idea! :D :th:
www.alextheblue.com
If you've seen some of the pictures from the period, the mounted infantry mostly road behind the turret holding on for dear life until they reached their goal, then they dismounted. Hopefully without getting run over. I doubt that they even knew that exhaust from the tank was bad for you.
If they did, they probably were told... Too bad. Very though people. Safety and comfort weren't really given consideration by the officers and designers.
Hope that helps buddy.
Yeah I'm with Coen, stick them as they are in the first picture there. Better cover, and a bigger space to stand on. I am sure many a Russian soldier got slight burns from hot tank exhausts, and I am sure that was the least of their worries!
Dunhill2005
Crap! I ruined my first base ... :wall:
I used gypsum as foundation and let it dry for 24 hours.As upper material I used a mixture of white glue, silt and sand. I have diluted it using very little water.Unfortunately, the gypsum took to the water and was then crumbly. :scratch::
All ended up in the trash.
In the second attempt I left off the foundation and used less water.
Wish me luck...
Much Luck!
Without experimentation we'd all still be living in cave eating the brains of dead animals haha.
:th: :lol:
Dunhill2005
It's me again...
This time my base looks much better. OK! not on this pic but in real... :ooops:
Everything is completed. I just have to wait for better weather to make proper pics.
At the moment it is rainy and stormy outside. :scratch::
Looks good so far mate, I hope this one turns out for you!
That's really fantastic ground work Dunhill! Well done. Those track marks are really crisp, that's not very easy to do. You have to have your mix just right. Good job
Dunhill2005
Guten Tag... :hi:
Today I have better weather to make pictures and I have time because it is a public holiday in Germany (Day of German Unity).
Because it is my first base I have kept simple.
By the way, I always make my pictures here
Thank you for helping me at the decision, if the soldiers sit of the back or on the side.
Dunhill2005
How likely with each kit, there are some things that are well done and some not... :scratch::
Not all faces have I succeeded and unfortunately there are two flaws on the base... :x
Do good and talk them (quote the Bible)! :thumb2:
The advice for faces of Coen has worked well . Cheers!
I have used in some areas of the fuel tank, the hairspray technique.
Also, I am satisfied with my oil and rust stains.
Thanks for your support!!! :bow::
Wow... Dunhill excellent work buddy. You really caught the action. The infantry actually looks like they're dismounting for battle.
Well freaking done Dude!!! :th: :th: :th: :th: :th:
You put all those new skills together very well.
With a bit of practice your work is going to blow your mind soon
Nicely done! :clap: :clap: :clap: :clap: :clap:
bullgill67
Post by bullgill67 »
a fantastic piece of work all round :th:
michael
