1/48 MisterCraft Su-7 BKL 'Fitter'
arilo76
Italy
Post by arilo76 »
Something A bit different.
ImageIMG_0914
ImageIMG_0924
ImageIMG_0931
Thanks
Antonio
Stay Classy ISM
ElCapitan
Re: 1/48 MisterCraft Su-7 BKL 'Fitter'
Post by ElCapitan »
Should be a fun build. I've not heard much about MisterCraft kits, so I'm interested to see how it goes :pop:
ElCapitan
arilo76
Italy
Post by arilo76 »
After some more research and advice i find this photo tonight i will change the color of the cockpit not user if AK 2304 or the Tamiya XF-23
Antonio
Stay Classy ISM
arilo76
Italy
Post by arilo76 »
ElCapitan wrote: Thu Jan 11, 2018 9:32 am Should be a fun build. I've not heard much about MisterCraft kits, so I'm interested to see how it goes :pop:
HI ElCapitan it is the re-box of the old Su-7BKL/BMK OEZ, it should be a ok build not grate but ok, From MisterCraft i try to build a bf 109 and it became my test model so bad it was.
https://www.scalemates.com/kits/114899- ... u-7bkl-bmk
Antonio
Stay Classy ISM
arilo76
Italy
Post by arilo76 »
So Try to get the seat to look closer to the image I re primed the seat and the i spried in Tamiya xf-5
Image0010 - 1 copy
and then i used the hairspray and then the final color was the XF-80 and then with the stiff brush and water i created the scratches.
Image0010 - 6 copy
Image0010 - 7 copy
Image0010 - 8 copy
I will then use the some metal color to add some heavier scratches.
Antonio
Stay Classy ISM
ElCapitan
Post by ElCapitan »
Nice looking cockpit! The colour looks much closer to the real thing, you were right to change it :th:
ElCapitan
arilo76
Italy
Post by arilo76 »
ElCapitan wrote: Wed Jan 24, 2018 9:28 am Nice looking cockpit! The colour looks much closer to the real thing, you were right to change it :th:
Thanks and sorry for the late reply.
Antonio
Stay Classy ISM
arilo76
Italy
Post by arilo76 »
I have been working on and off on this project and how you can see a lot of re-scribing so no much to show just boring and tedious work
just want to share something that i find useful, i use uni-posca black markers that are acrylic to check the filling and re-scribing, before priming.
Thanks
Antonio
Stay Classy ISM
arilo76
Italy
Post by arilo76 »
Not a kit i would recommend actually stay away from it, i am sure a better modeler could have done better job.
Antonio
Stay Classy ISM
