1/48 Eduard MiG-21bis
IanG
Post by IanG »
Starting this little beauty, as an "in-between Group Builds" build. No aftermarket needed, as there's PE, and canopy mask in the box.
Will be finished in Bulgarian markings.
ImageIMG_5931 by ian gaskell, on Flickr
Re: 1/48 Eduard MiG-21bis
Nice, great kits these.
DrSprue
Post by DrSprue »
Oh that looks like a its going to be a fun build. Love Mig's and Eduard! :pop:
-Doc
IanG
Post by IanG »
Thanks guys.
IanG
Post by IanG »
Sorry for lack of updates, totally forgot. So here goes.
Got the cockpit started, and the PE fits well. I used Akan's Emerald Green. With the coloured PE being a different shade, I used the Akan to blend in as much of the PE as possible.
Imageimage by ian gaskell, on Flickr
IanG
Post by IanG »
Cockpit now installed in the fuselage, along with the shock-cone. Shock-cone painted with Hataka Red Line Pastel Green.
IanG
Post by IanG »
Got the seat assembled, and PE belts applied.
Pretty good seat, for one that's kit supplied.
Painted with Hataka Blue and Red Line acrylics.
Just need to weather it a little, and it's done.
ImageDSC_0607 by ian gaskell, on Flickr
IanG
Post by IanG »
Got the seat finished, just need to put the ejection handle in place. I'll do this at the end of the build.
Weathered with a Ultimate was, AK Interactive pigments, and then dry-brushed with Vallejo Aluminium.
ImageDSC_0612 by ian gaskell, on Flickr
IanG
Post by IanG »
Lots of bits added to the the fuselage. A lot will added at the end, to lessen the chance of me knocking them off!
The Master Model pitot is assembled, and dry fitted for the purpose the photo. I lightly sprayed it with Tamiya fine primer, which made seeing the locating holes for the vanes easier to see.
ImageDSC_0634 by ian gaskell, on Flickr
IanG
Post by IanG »
Managed to get a bit of bench-time, this weekend.
Ultimate black primer applied to the airframe, pylons, weapons, wheel bay doors, and the undercarriage and wheels. They were left to dry overnight.
When dried, I painted the antenna areas in Hataka Red Line Pastel Green. These were then masked off, and surrounding areas touched up with some more black primer.
Following that, I made a start on the pre-shading. For this I used Hataka's acrylic Blue Line Insignia White. Although specifically made for brush painting, I've found if you thin Blue Line paints 70:30, in favour of thinners, and some drops of flow improver, they airbrush really well.
ImageDSC_0640 by ian gaskell, on Flickr
IanG
Post by IanG »
Making a start on the camouflage. Got the first colour laid down, Hataka’s Red Line acrylic Grey Green. The fuel tank is done, as it’s only the single colour.
This Bulgarian scheme has a hard edge to the camo colours, so I’ll be breaking out the Panzer Putty for the masking off.
ImageDSC_0656 by ian gaskell, on Flickr
IanG
Post by IanG »
With the lighter green now dry, I started to mask off areas ready for the darker green. This is Hataka Red Line acrylic Dark Green.
The masking is done using MIG's Masking Putty, which is very easy to use, and does not leave any residue, or marks, on the paint.
ImageDSC_0667 by ian gaskell, on Flickr
IanG
Post by IanG »
Well that's the camouflage all finished, just some touching up to do.
It's been a long time since I used any masking, when airbrushing camo. Recently I've been doing my camo's freehand. Can't say I'm all that happy with the result, it could've been better. In hindsight, I should have stuck to freehand.
Hataka colours used:-
Interior Grey-Green, camo
RN Medium Blue, underside
NATO Brown, camo
Dark Green, camo
Pastel Green, antenna covers
Next task is to Glass Coat in readiness for the doing the decals.
ImageDSC_0679 by ian gaskell, on Flickr
IanG
Post by IanG »
All the decals are done, and some Aqua Gloss coat applied, sealing the decals.
The undercarriage, weapons pylons, and fuel tank have all been weathered using Ultimate's dark dirt wash.
Once the gloss has fully dried, the main airframe will also be given a dark dirt wash.
ImageDSC_0690 by ian gaskell, on Flickr
IanG
Post by IanG »
One mucky MiG!!
Ultimate Dark Dirt wash brushed on, then cleaned off once dried.
ImageDSC_0699 by ian gaskell, on Flickr
shortCummins
Post by shortCummins »
that Bulgarian camo' scheme looks really good
rgds
John(shortCummins)
Nev
Post by Nev »
It’s really different that camo theme! lovely job sir :th:
On the Bench...
IanG
Post by IanG »
shortCummins wrote: Thu Apr 19, 2018 9:01 am that Bulgarian camo' scheme looks really good
rgds
John(shortCummins)
Thanks John.
One of the reason I chose the scheme, it’s a bit different.
IanG
Post by IanG »
Nev wrote: Thu Apr 19, 2018 9:24 am It’s really different that camo theme! lovely job sir :th:
Thank you Nev.
Yes it is different, and certainly stands out.
DoubleDigit12
Post by DoubleDigit12 »
Wow, I really like that Bulgarian schme. The paintwork looks fine to me!
James
IanG
Post by IanG »
DoubleDigit12 wrote: Fri Apr 20, 2018 10:06 pm Wow, I really like that Bulgarian schme. The paintwork looks fine to me!
Thank you.
IanG
Post by IanG »
Calling this MiG done!
viewtopic.php?f=45&t=24612
ImageIan G-1 by ian gaskell, on Flickr
Very nice, not seen that type of cammo before, I do like Mig21 it looks like it's doing Mach2 just sitting there :th: :clap:
IanG
Post by IanG »
Kevthemodeller wrote: Thu Apr 26, 2018 7:34 am Very nice, not seen that type of cammo before, I do like Mig21 it looks like it's doing Mach2 just sitting there :th: :clap:
Thanks Kev.
