Mark's Eduard MiG-21 MT/SMT
Hi guys
This will be my entry in this sig
I will be building the Eduard 1/48 MiG-21 SMT kit wich offers 2 MT versions and 3 SMT versions
After building the PMF a while ago i decided to get another one as i really liked the kit
So this time i will be building this one
20180131_013511 by Mark Verploeg - Flickr2BBcode LITE
The kit contains
20180131_014339 by Mark Verploeg - Flickr2BBcode LITE
20180131_014352 by Mark Verploeg - Flickr2BBcode LITE
20180131_014401 by Mark Verploeg - Flickr2BBcode LITE
20180131_014411 by Mark Verploeg - Flickr2BBcode LITE
20180131_014431 by Mark Verploeg - Flickr2BBcode LITE
20180131_014449 by Mark Verploeg - Flickr2BBcode LITE
20180131_014807 by Mark Verploeg - Flickr2BBcode LITE
20180131_015322 by Mark Verploeg - Flickr2BBcode LITE
So that is what is in the box
I was going to build this one
20180131_015431 by Mark Verploeg - Flickr2BBcode LITE
But i noticed Ivan is going to build the same plane
And i think it would be nice to see as many different ones as possible so i decided to make the one from the boxart
2018-01-31_02-08-46 by Mark Verploeg - Flickr2BBcode LITE
That would be this one
It has the same colors but a slightly different scheme
It is a MT version (older variant) but that still looks the same on the outside
The most notable difference is the engine and that doesn't really show in the kit
So all that is left is to say good luck with everones build
And hopefully we can see a lot of MiG's soon
Take care
Mark
Re: Mark's Eduard MiG-21 MT/SMT
Hi guys
Well i think it is time for a little update
Allthough i don’t have as many photo’s left
Everything was on my phone and that decided to die yesterday
So i had to use the tablet to take some new photo’s and upload those
It is in the mids of getting it’s washes at the moment but i think i can get the fuselage closed today
The painted interior bits
Engine and landing gear bay in the painting stage
The inside of the wing section
So at the moment i am working on the washes and probably a little bit of chipping and then i can flat coat it and then put it all together so i can move on with the build
Thanks for stopping by and having a look
Take care
Mark
DrSprue
Post by DrSprue »
Oh great sprue layout Mark (or as Scott says outlay!) and start of this cool Mig! Hand over the popcorn! :pop:
-Doc
Thank you tony
Good thing those pics where uploaded and posted allready
But i did loose a couple of pics of this build from before the paint
And from a whole bunch of other builds and figures as they where all on my phone
But i am getting a new one tomorrow so then i can started all over
DrSprue
Post by DrSprue »
Good luck with the new phone Mark. I hope you can save your pictures a bit better with a new 1. Flickr or even Dropbox may be a good way to keep them on the net for easy access if anything else happens to it later.
-Doc
Thanks Tony
The problem was that i didn't upload all of them yet
But i have a new one and i will be building later today
But i have 4 builds that are nearly finished so i think i will start with those and then clean the bench before i get back to the MiG
Should be today or tomorrow so not all that long
Hi guys
Time for a update
I managed to finish 4 builds today and got back to the MiG
At the moment the fuselage is closed up and all the major parts are done
All that is left is the small stuff like the landing gear , weapons and some cockpit parts
20180207_193822 by Mark Verploeg - Flickr2BBcode LITE
Once the flat coat was dry i glued the various sub assemblies in the fuselage
20180207_194202 by Mark Verploeg - Flickr2BBcode LITE
And glued the 2 halfs together
It required a bit of pushing to get everything smooth but it was pretty close in the end
20180207_195243 by Mark Verploeg - Flickr2BBcode LITE
Then the back and tailsection was assembled
20180207_195744 by Mark Verploeg - Flickr2BBcode LITE
And the wing and wheelbay parts where glued together
20180207_195753 by Mark Verploeg - Flickr2BBcode LITE
After removing a little bot of flash the backpiece fitted great
20180207_195857 by Mark Verploeg - Flickr2BBcode LITE
And the wing section was glued in place
20180207_202430 by Mark Verploeg - Flickr2BBcode LITE
Then the elevators and various other small parts where added
20180207_203852 by Mark Verploeg - Flickr2BBcode LITE
And the tops of the wings where added
They didn't fit as well as i had hoped so some filling was needed
20180207_204600 by Mark Verploeg - Flickr2BBcode LITE
As you can see here
I don't know why but i had to fill a 5mm long gap on the left but i had to fill the entire line on the right side of the plane
20180207_210044 by Mark Verploeg - Flickr2BBcode LITE
Parts on the belly where placed
20180207_230720 by Mark Verploeg - Flickr2BBcode LITE
And some of the landing gear baydoors where added
The other parts will be fitted on the landinggear itself and i plan on painting those as seperate piece
Mainly because i need to paint inside those bays anyway asi forgot the inside of the wings
And that is how far along i am with this one at the moment
I will be adding a couple more bits today and prep all the parts for painting in the upcoming days
Now i just need to order in the required paints and get started on painting soon
Take care
Mark
Hi guys
So just a small update this time
The MiG is waiting for paint at the moment but that should be arriving tomorrow
So here is what happened since last time
20180212_034057 by Mark Verploeg - Flickr2BBcode LITE
The last bits for the cockpit where added
20180212_034104 by Mark Verploeg - Flickr2BBcode LITE
Sadly i knocked the plane from the stand and 2 of the 4 fins on the pitot tube where lost ,still didn't find them so i removed all of them
20180212_034109 by Mark Verploeg - Flickr2BBcode LITE
Pylons where added
20180212_034120 by Mark Verploeg - Flickr2BBcode LITE
The canopy was fitted with the mirrorpart (not an actuall mirror) and masked
20180212_034125 by Mark Verploeg - Flickr2BBcode LITE
The rocketlaunchers where assembled
20180212_034131 by Mark Verploeg - Flickr2BBcode LITE
And the landing gear and wheels
20180212_034136 by Mark Verploeg - Flickr2BBcode LITE
The seat was put together
20180212_034138 by Mark Verploeg - Flickr2BBcode LITE
And the droptanks
20180212_100821 by Mark Verploeg - Flickr2BBcode LITE
20180212_100823 by Mark Verploeg - Flickr2BBcode LITE
And everything is primed
So all i need now is paint so i can continue the build
Hopefully i can have it painted in about a week
Take care
Mark
Hi guys
Time for the final update for this build
I managed to finish it last night so for me this sig is over
But first i will show how the build went along
20180214_234755 by Mark Verploeg - Flickr2BBcode LITE
20180214_234746 by Mark Verploeg - Flickr2BBcode LITE
First off painting
The only things i masked are the clear parts and the lower part
Wich is painted grey ,the rest is painted free hand
20180216_173431 by Mark Verploeg - Flickr2BBcode LITE
It is hard to see but i misted the camo with off white
Just to dull down the colors a bit
20180219_013545 by Mark Verploeg - Flickr2BBcode LITE
Then after a gloss coat i started the decals
20180225_215552 by Mark Verploeg - Flickr2BBcode LITE
Then after the decals and a second gloss coat i added a a wash
20180225_220316 by Mark Verploeg - Flickr2BBcode LITE
I then added some dirt streaks
20180225_221734 by Mark Verploeg - Flickr2BBcode LITE
Once that was dry i started to add the parts that where painted seperate from the plane
20180225_232235 by Mark Verploeg - Flickr2BBcode LITE
And then i finished it up and called it finished
So that is it for the buildthread
I will be posting a reveal thread aswell to really finish the build
Take care
Mark
DrSprue
Post by DrSprue »
Came out really great Mark! :clap:
-Doc
Thank you very much Tony
It isn't perfect but i think it is good enough for me (for the moment)
