Airfix Sea Fury
KungFuDrew
Airfix Sea Fury
Post by KungFuDrew »
:thumb2: :welcome: Hi guys! I've decided that I've lurked about here for too long, and this beauty showed up today:
So I decided that I had no excuse to not post a build of this beautiful aircraft.
The parts are well moulded with no flash in the normal airfix plastic. I was worried from seeing pictures that the panel lines would be trenches, but I had nothing to worry about. As you can see the panel lines are fine and the details are well defined:
As per usual construction starts with the cockpit. The pit builds up well, this is it dry-fitted:
It's pretty well detailed, the only problem I have with it is the rudder pedals, they're a bit "blobby":
That's where I am just now, I'll post more pics once I have the pit completed.
Thanks, Andrew
On the bench: Tamiya 1/32 F4U-1D Corsair, 1/350 USS Salem (very long term project)
DrSprue
Re: Airfix Sea Fury
Post by DrSprue »
Oh great, count me in to enjoy this cool build! :pop:
(I know I will learn something! :shhh: )
-Doc
