Help Plasticard!!!!
AlexBB
Help Plasticard!!!!
Post by AlexBB »
Ok.... so have spent over half an hour searching for Plasticard on modelling sites and can't find any :scratch:: :scratch:: :scratch::
Please does anyone know what else it is called?
Need some size 10thou, 20thou & 40thou (0.254, 0.5 & 1mm)
Just cant seem to find it on eModels or anywhere else other than some Train Diorama shop I have never used.....
Alex J Beebee
sheppsea
Re: Help Plasticard!!!!
Post by sheppsea »
https://www.modellingtools.co.uk/plasti ... -118-c.asp
I use these quite often, they have 0.5 and 1mm, but only go as low as 0.3mm
This website also sells Plastruct products, but I have only used them once (no issues, except that I was expecting a pack but instead received single rods - my fault as I should have guessed that from the price!!)
https://hobby.uk.com/materials/plastic/ ... sheet.html
Cymru
Post by Cymru »
Also available via Amazon
Hanger:
STASH
WIP:
Current Projects
Orange Air Virtual Airline
DikDolan
Post by DikDolan »
Rallychef
Post by Rallychef »
I scratch build trailers for haulage firms and use Evergreen styrene sheets, strips and rods, Howard from Kit Form Services always holds a good stock great range and great service, I have spent £100's with him over the years, Highly recommended
http://www.kitformservices.com/scratch1.html
Regards Ian D
AlexBB wrote: Sat Feb 17, 2018 4:12 pm Ok.... so have spent over half an hour searching for Plasticard on modelling sites and can't find any :scratch:: :scratch:: :scratch::
probably using a new search word like...buy styrene sheets uk.... will see you right :cheers2:
colonelmustard
Post by colonelmustard »
I actually use old/used lottery cards that I literally pick up off the pavement for my 1/35 scale armour model needs. At a pinch I have used margarine cartons for thinner plastic. It may not sound very sophisticated... but it does for what I require.
I have heard sign writers often have lots of off cuts
