#30 ICM 1/48 HE111 H6
Les0012
Post by Les0012 »
Yeeehaaaaa it's May 1st and after a long wait the Bomber SIG is here.
So my choice for this destruction oops sorry construction is the ICM He111 H6, of the 4 choices of scheme I haven't decided yet which to do.
The box art is quite impressive though basic.
Image1 by Les Goodison, on Flickr
Getting into the box is to say the least not easy, but once in you are faced with a shoe box type box.
Image2 by Les Goodison, on Flickr
The sprues unfortunately are not individually packed but packed into 4 bags 2 of which are the clear parts.
Image3 by Les Goodison, on Flickr
Image4 by Les Goodison, on Flickr
The sprues themselves don't look to bad at all, no visbale flash the panel/internal detail looks good.
Image5 by Les Goodison, on Flickr
Image6 by Les Goodison, on Flickr
Image7 by Les Goodison, on Flickr
Sprue C has 2 identical sprues.
Image8 by Les Goodison, on Flickr
Image9 by Les Goodison, on Flickr
Image10 by Les Goodison, on Flickr
There is 2 bags of clear parts, I have not opened the bags yet as one part had broken off so will examine the later.
Image11 by Les Goodison, on Flickr
Image12 by Les Goodison, on Flickr
Image13 by Les Goodison, on Flickr
Image14 by Les Goodison, on Flickr
Image15 by Les Goodison, on Flickr
The Instruction booklet looks good and is in colour, we've all seen a destruction book so I am not going to fill the thread up with pics of every page. As stated earlier, I will post pics of the chosen scheme as and when I decide.
Image16 by Les Goodison, on Flickr
The paint call out on the front page is in both Revell and Tamiya but again I am unsure which brand of paint or if a mixture of brands will be used :wall: Image17 by Les Goodison, on Flickr
The decal sheet looks to good and well printed but only time will tell on that score
Image18 by Les Goodison, on Flickr
Now for a little history of the HE 111 H-6, taken from the cover of the instruction sheet.
At the beginning of the 30s it appeared to the world that there was a need for a high speed bomber that could out strip the contemporary fighters of the day. Out of the specifications the twin engined HE 111 designed by the Heinkel Flugzeugwerke AG company was born.
As of May of 1941 the company was producing the HE 111 H-6 variant with liquid cooled Jumo 211F-2 engines giving increased power, with VS 11 wooden wider horde propellers and more powerful armaments. This variant could carry SC 1800Kg bombs or 2 LT F5b torpedoes externally.
The HE 111 H-6 was the most produced variant of Heinkel's medium bomber. They were to produce approximately 1800 aircraft up to the end of 1942. The HE 111 H-6 was to serve in all theatres as a level bomber,torpedo bomber, reconnaissance,mine layers and transport aircraft.
Technical and Tactical Specifactions.
Length........................16.38m
Wingspan.....................22.50m
Start weight.................14000Kg
Engines.......................2 X Jumo 211F-2, 1340 Hp
Max Speed...................435Kph
Service ceiling..............6700m
Range........................1950Km
Armament...................1-2 X 20mm MG FF,4-7 X 7.92mm MG 15, Bomb Load- up to 2000KG or 2 LT F5b torpedoes.
That's it for just now, the build will start in a day or two as I am waiting for a few bits of after market to arrive.
Please all enjoy yourselves with this SIG it has a promising entry.
Good Luck Les
Quax
Greenland
Re: #30 ICM 1/48 HE111 H6
Post by Quax »
looks interesting Les, there's several ICM kits now but it will be interesting to see how your 1/48th H-6 one compares with the 1/32 P's (other than size....)
watching with interest :pop:
A mess as usual...
Wow, the box art is AMAZING!!!
Looking forward to watching this build up, what a beauty
Wishing you good luck and a fun time
:cheers2: Scott
gaz45
Post by gaz45 »
Ooohh nice
Les0012
Post by Les0012 »
I've started, if you can call it started, still waiting for the after market to come in so have began by building steps 1-5, am a bit wary of glueing step 5 together as not sure what is going to be in the P.E kit, so a stop has been ordered.
So far the kit seems to put itself together, hope it stays like that.
Image19 by Les Goodison, on Flickr
It's a start all the same.
All the best Les.
Another ICM kit....this is so good.
Looking to add one of these to my stash of Battle of Britain aircraft, I'm going to watch this build with interest, good luck mate :th:
Les0012
Post by Les0012 »
Good Morning Captains,
Right so the PE still has not arrived, decision has been made.......out of the box it is then. Hopefully the masks for the glass will be here before I need them.
Progress so far, THIS IS AN AWESOME KIT it just seems to fall together.
The inside of the fuselage and the cockpit are nearly ready for paint, have a look,
Image20 by Les Goodison, on Flickr
Image21 by Les Goodison, on Flickr
Image22 by Les Goodison, on Flickr
Image23 by Les Goodison, on Flickr
Still a couple of control bars to be fitted, waiting for the glue to dry, as you can see it's quite fiddly with the rudder pedals etc.
Image25 by Les Goodison, on Flickr
So that's the update for now,
Les.
fiddly or not the detail is spot on for my eye :th: :th:
Good looking kit, looks like the engineering is good.
Les0012
Post by Les0012 »
Thanks Guys, it is a great kit so far, but I ain't had much chance to screw it up yet
Les
Les0012
Post by Les0012 »
Right everyone I have some paint on the inside of the fuselage.
Undercoated in Ultimate Grey then a coat of Tamiya XF-16 Flat Aluminium, clear coat then a coat of AK Interactive Worn Effects finished off with Tamiya XF-22 RLM Grey.
So now it's a case of picking out the detail and getting some of RLM 02 off for the worn effect. I will put some weathering effects on once the two halves are ready to go together.
Image26 by Les Goodison, on Flickr
Image27 by Les Goodison, on Flickr
It's the first time I have used this AK product so will be interesting to see what difference it has to the heavy chipping one.
Image_DSC0003 by Les Goodison, on Flickr
Thanks for looking in. Les
Nice looking kit Sir
Flying combat missions while sitting in that Perspex nose must have been a massive sphincter test if you ask me! :eeek:
Les0012
Post by Les0012 »
Ok all, were into week two now and so far I have managed to get paint down on both fuselage halves and the internal walkway/cockpit. paints used are Tamiya XF-22 RLM Grey, with detail picked out with various colours of Tamiya. Also the worn effects by AK seem to have performed well enough,as have the dark dirt pigments.
The only down side I would have to say is that considering the size of the model the interior detail is nowhere near as good as the Airfix 1/72 but I suppose being 'a budget kit' you get what you pay for.
Image32 by Les Goodison, on Flickr
Image29 by Les Goodison, on Flickr
Image30 by Les Goodison, on Flickr
Image31 by Les Goodison, on Flickr
That's it so far, hope everyone is having fun in their builds.
Les
InvalidUsername
New Zealand
Post by InvalidUsername »
Looking good!
disappointing to learn the internal details are lacking some what. :(
alextheblue
Post by alextheblue »
That's weathering up nicely there Les, some great work! :th:
www.alextheblue.com
Les0012
Post by Les0012 »
Good Morning my fellow Skips,
Thanks for the comments all.
Update, here we go, I have joined the two halves of the 111 together, oh boy that was a chore, the locating holes on one side are a bit tight so when the parts come together it leaves a cap, then apply the TET and being a hot glue hey presto the parts melt together. Think I may still need a bit of filler, will wait and see when the securing tape comes off.
A few pics of where we are at.
Image33 by Les Goodison, on Flickr
Image34 by Les Goodison, on Flickr
As said the internal detail OOB is not brilliant but for my skill set is sufficient lol
The two halves buttoned up and a shot of the glasshouse
Image35 by Les Goodison, on Flickr
Image37 by Les Goodison, on Flickr
Thanks for looking in by and I will see you again soon.
Happy Modelling all
Les
Great work on the internal build & weathering Les - she really does look well used!
Hopefully the gaps won't be too scary when you take the tape off.
Fantastic
Sure glad my build doesn't count, you guys are kicking butt with builds like this
Top marks for use and abuse weathering, sir :clap:
pourquoi61
Post by pourquoi61 »
My the ICM kits are looking like the new Tamiya.
Very nice. :th: :th: :th:
gaz45
Post by gaz45 »
Great start there mate looks great
Les0012
Post by Les0012 »
Latest update on my (yet to decide on paint scheme) He 111 H-6
Fuselage is buttoned up took a little filler, I used Mr Surfacer 1200 on the seams.
Lower wings are attached and I think some filling and sanding will be required here. This kit has an 18 inch approx. wingspan, that's quite a beast for my little work area. The roof panel has also been fitted.
Image38 by Les Goodison, on Flickr
Image39 by Les Goodison, on Flickr
The engines have been built and are well detailed for OOB, not sure if it's worth weathering them as once they're in place and the cowlings are fitted they will not be seen. Might just stain them a wee bit with oil etc.
Image40 by Les Goodison, on Flickr
Image41 by Les Goodison, on Flickr
That's it for now, Thanks for looking Les
Willem
Post by Willem »
Oh mate. That's looking fab so far.
Will
Edward R Murrow
pourquoi61
Always a difficult one as I think an open cover spoils the lines of the plane, but on the other hand...... :scratch:: :scratch::
Looking great so far. :th: :th: :th: :th: :th:
Oh my, that is looking great
Starting to look like a real aircraft now. Keep at it!!
Door prize draw coming up this weekend :banana:
Les0012
Post by Les0012 »
Latest update on the He 111.
Engines are fitted, upper wing surfaces or on and oh boy that was finicky, a bit of brute force and ignorance to move this that way and that the other way to get the surfaces to fit together but I think I got there in the end, a little bit of filler may be the order of the day though.
Image43 by Les Goodison, on Flickr
Image44 by Les Goodison, on Flickr
Image45 by Les Goodison, on Flickr
Image46 by Les Goodison, on Flickr
Image47 by Les Goodison, on Flickr
That's it for now, thanks for looking, Les
InvalidUsername
New Zealand
This is coming along nicely, great work :th:
Les0012
Post by Les0012 »
Okay everyone this is where I left her a couple days ago, engine nacelles are on as is most of the greenhouse at the front.
Image50 by Les Goodison, on Flickr
Now I have a few pieces waiting to be primed.
Image48 by Les Goodison, on Flickr
Image49 by Les Goodison, on Flickr
The greenhouse now, with the front gun in place, In the destructions the cockpit glass is put together before fitting to the front, I personally found it easier to place them one piece at a time on the front. You will also see that a little bit of filling has taken place on the engine nacelles. So this is where she stands now.
Image52 by Les Goodison, on Flickr
Image51 by Les Goodison, on Flickr
Will hopefully get her nearly done next week as I have a week off from the Tesco checkout but am off to see Mr Bryan Adams Ultimate concert in Glasgow next weekend
So here ends this wee update, thanks for looking by
Les
Willem
Post by Willem »
Really looking the part now. Have heard it's not exactly a fall together kit but you are smashing it so far.
Will
Edward R Murrow
Quax
Greenland
Post by Quax »
super job done there Les :clap: :clap:
A mess as usual...
You're cracking on with this one Les :th: some good stuff happening here mate :th:
Les0012
Post by Les0012 »
Thanks for the kind comments guys
Les
Les0012
Post by Les0012 »
Todays update everyone,
The aircraft is primed in the usual, as it now appears to be Ultimate Grey primer. I have to say that as Paul has said before it sprays better when warm and I certainly concur.
Image53 by Les Goodison, on Flickr
Some bits and pieces also primed as above
Image54 by Les Goodison, on Flickr
The primed aircraft, I am not an expert at this so gaps are apparent but hey ho I am only in it for the enjoyment.
Image55 by Les Goodison, on Flickr
Image56 by Les Goodison, on Flickr
I have also kinda decided on the scheme I am going to demolish and it the He 111 of 7./KG27 in Russia, November 1941.
Image57 by Les Goodison, on Flickr
Well that's it for just Thanks for looking by again.
Les
alextheblue
Ooooooh, that looks nice! Looking really good with its primer coat on. :th:
www.alextheblue.com
Les0012
Post by Les0012 »
Okay all it's time for my latest update.
The He 111 was given a coat of XF-16 Flat Aluminium with the intention of putting some chipping fluid on to later get some weathering done, but I have just realised that I have forgotten to put the fluid on before giving it a clear coat :wall: :wall: :wall: :wall: :wall: :bash:, so back to the drawing board.
So this is where it is at.
Image58 by Les Goodison, on Flickr
Image59 by Les Goodison, on Flickr
Some pre-shading with XF-1 Flat Black
Image63 by Les Goodison, on Flickr
Image65 by Les Goodison, on Flickr
The yellow wing tips and tail ring are on,
Image66 by Les Goodison, on Flickr
Image67 by Les Goodison, on Flickr
That's where it is at just now gonna try and get the RLM 65 on tomorrow but will see how it goes.
pourquoi61
Well you do know that you........... "Can't stop this thing you stared"
Talking about your He 111. :lol: :lol: :lol:
Great work. :th: :th:
demarcation
Denmark
Post by demarcation »
Awesome work so far mate!! :th:
//Anders
gaz45
Post by gaz45 »
That is sure looking the part mate
Good work ! one of the nicest ones in the SIG in my opinion. And a plane I love too !
pourquoi61
How was the concert?
Les0012
Post by Les0012 »
pourquoi61 wrote: Wed May 30, 2018 10:41 pm How was the concert?
Two and a half hours of nothing but music, only real chat was to introduce the band. Would recommend anyone to go see Bryan Adams :cheers2:
Thanks for asking.
Now that's done and the decorating is done I have to get back to the build.
Les
Les0012 wrote: Mon Jun 04, 2018 9:38 am
Thanks for asking.
Les
Adams is a Good Canadian kid :thumb1:
He grew up in North Vancouver...just a stone throw from me
pourquoi61
Twokidsnosleep wrote: Mon Jun 04, 2018 3:35 pm
Thanks for asking.
Les
Yes I know he is canadian,my late wife loved his music and one track is on our wedding video. No prizes for guessing the track.
Watching the build. :th: :th: :th:
Les0012
Post by Les0012 »
Ok so this computer seems to working better than the laptop :scratch:: Have been having problems trying to post comments and updates just kept coming up "Unable to display page"
Right its been a couple pf weeks since I last updated so here goes.
The underside has been painted in XF-23 Light blue and the topside in XF-2 Flat white, the wingtips and the tail band are XF-3 Flat yellow. So once the yellow was unmasked a clear gloss coat of Xtracrylics was applied to protect the paint.
Image68 by Les Goodison, on Flickr
Image69 by Les Goodison, on Flickr
Image71 by Les Goodison, on Flickr
Now onto the undercarriage, this was pretty straight forward and presented no real problems, although there is still a couple bits to be fitted I have went ahead and placed the legs into the wheel wells.
Image72 by Les Goodison, on Flickr
Image73 by Les Goodison, on Flickr
Some xf-16 Flat aluminium has been dabbed about the wing leading sdges and wing roots, hopefully this represents some heavy chipping
Image74 by Les Goodison, on Flickr
Image75 by Les Goodison, on Flickr
Some XF-1 and XF-2 Black and white were mixed together and although I think that I have put way to much on it's supposed to represent the dirt from the exhausts. I will be the first to admit that I have a lot to learn about weathering.
Image80 by Les Goodison, on Flickr
Image81 by Les Goodison, on Flickr
Another light coat of gloss varnish and time to bring some life about the aircraft. I think that the application of decals does just that, one side done this morning.
Image82 by Les Goodison, on Flickr
I also painted the wheel well doors today and some other smaller pieces so will get them on soon.
Now that is how she stands right now on her own legs, hopefully get her finished decaling tomorrow.
Thanks for looking in everyone see you all again soon.
Les
Coming along really nicely Les
Some great paint work there, can’t wait to see the chipping and weathering :thumb2:
Good stuff
Yep paintwork really starts to bring these things to life doesn't it - great work Les! :clap:
Les0012
Post by Les0012 »
Ok all, this is the last update for this build, (no piccies).
Today I finished the decals on the aircraft, then a final gloss to protect the decals. Hopefully tomorrow will get her a wash and possibly a flat coat, unmask and that should be it there or there about.
So next post will be the final reveal.
Les
Tat2bhoy
Post by Tat2bhoy »
Looking forward to the reveal, looking good so far :th:
Image Image #32
Revell 1:72 Type IXC/40 U-Boat ✅
Meng 1:48 Messerschmitt Me410 B-2/U2/R4 Heavy Fighter✅
Miniart 1:35 T-54-2 Soviet tank✅
Thanks for asking.
Les
Yes a great Canadian ! And he gives on of the best shows
