#8 Revell 1/72 Ju 88A-4 Bomber
TheNordus
Post by TheNordus »
Hello, I bought this set off a local department store some time ago because I find the Ju-88 to just be a beautiful piece of military engineering. I'm not an aircraft modeller usually, so I'm just going to build this one out of the box.
Here's a picture of the contents of the box. I decided to start building immediately, as I knew I'd have to paint the cockpit before putting the rest of the thing together.
1/72nd scale is bloody tiny! Here's my finger (covered in red Tamiya primer) pointing at the cockpit pieces. The detail on this set seems pretty good. There are a few ejector pin marks inside the cockpit but I thought you would not be able to see them after you put the cockpit glass on.
Here's a picture of the sub-assemblies I built before painting. There haven't been any fit problems so far, except the pilot's seats positioning was a little bit ambiguous. So far I've enjoyed building this model so much that I'm thinking of buying another bomber in 1/48 scale tomorrow.
-Tommi
Re: #8 Revell 1/72 Ju 88A-4 Bomber
Hey welcome to the sig!!!
The 1/72 scales are pretty small, but then the bomber's wingspan and fuselage get pretty big fast
I agree with you about the beauty and engineering of the JU and He bombers...if not their use
I welcome you to the sig and hope you have some fun along the way
:cheers2: Scott
Hi ! nice ! I have the same kit for my entry ! good luck with it !
Wow that cockpit detail looks nice for a 1/72 Bird. Great thing about the JU-88 is with that big glass canopy frame you'll be able to see so much of it when you button it up.
TheNordus
Post by TheNordus »
Garion77 wrote: Thu May 10, 2018 11:37 pm Hi ! nice ! I have the same kit for my entry ! good luck with it !
I noticed your build as well. You certainly got a lot of after market for yours. Boggles my mind how someone could work on PE in 1/72nd scale when it's already impossible for me to fold tool clamps in 1/35 scale.
Stokesy44 wrote: Fri May 11, 2018 9:30 am Wow that cockpit detail looks nice for a 1/72 Bird. Great thing about the JU-88 is with that big glass canopy frame you'll be able to see so much of it when you button it up.
The detail is pretty nice, however the cockpit glass in this kit is a bit thick and warps everything you view through it.
Twokidsnosleep wrote: Thu May 10, 2018 5:29 pm Hey welcome to the sig!!!
:cheers2: Scott
Hi and thanks for the welcome! the Ju-88 was also used in the Finnish air force so there's a bit of national pride involved in my love for this craft.
Here's a quick progress update. There are definitely some unfortunate gaps in the wing roots and next to the engines, but they're mostly on the underside.
-Tommi
TheNordus wrote: Fri May 11, 2018 10:51 am
:cheers2: Scott
Well the PE I have is to get more expérience with it. I’m a beginner and have a B-17 in my stash that would love to come out good...and tought the sig was a good way to learn as it would be easy to get comments or ask questions. But i’m having more trouble figuring in which order to do everything than with the manipulation of the PE itself.
pourquoi61
Post by pourquoi61 »
Out the box, love it. :th: :th: :th: :th:
Door prize draw coming up this weekend :banana:
One month left in the sig
viewtopic.php?f=660&t=25285
