Revell 1/72 Horten Go 229
pourquoi61
Post by pourquoi61 »
I just had to join this build.
So here she is.
The important bits.
Sorry, no blurb. If you want that go look on Wikipedia.
Cheers. :cheers2: :cheers2:
pourquoi61
Re: Revell 1/72 Horten Go 229
Here I go, stages one and two done, no problems.
Easy and quick.
Next I spray Tamiya XF-22 RLM Grey over the cockpit and all other parts that are needed in this colour.
Sprue parts also.
I constructed the wings whilst waiting for the glue to dry on the cockpit sections.
I build and paint the starter unit and exhaust "onion".
Paint them Tamiya X-1 Gloss Black, the compressor fan and cooling fan I painted Citadel Mithril Silver.
In this next photo you can see sub-assembly 4 done and the cooling fan and "onion" built.
Some framing has also been added.
Sub-assembly 6 done. Guns painted Citadel Leadbelcher (Gun Metal to you and me) with a brown wash over the top.
Citadel Agrax Earthshade. Some details picked out in the cockpit also.
Side frame added, also you can see that at this point I glued the compressor unit to the front of the aircraft.
I feel it will aid construction.
Both halves joined and glued.
Front section on and glued.
A small amount of sanding here and also on the wing joints for a better fit.
Quick build so far.
Thanks for dropping by. :th:
Really glad you could join us for this SiG mate :cheers2:
Very unusual subject but a great shape to the wing - coming together really well and very quickly :clap:
pourquoi61
Tomcat64 wrote: Sun May 20, 2018 5:53 pm Really glad you could join us for this SiG mate :cheers2:
Cheers mate, I think I'll get chance to do another one considering how long the SiG is running for...or maybe another six or seven. :lol: :lol:
Quax
Greenland
Post by Quax »
looks an interesting kit, I might have to keep a look out for it!
good luck with the build :pop:
A mess as usual...
pourquoi61
Quax wrote: Mon May 21, 2018 7:53 am looks an interesting kit, I might have to keep a look out for it!
Thanks Paul it was you Ju-88 that made me want to enter. :cheers2: :cheers2:
pourquoi61
Had my son in hospital last week, so today was the first chance to do a little more work on the flying wing.
I attached the gun covers, this hides all the nice work done on them. :crazy: :crazy:
While the glue was drying it was time to mask the canopy. The framework is nice but difficult to see, especially on the front section, I could not manage to mask the framework so I just masked the lot. :doh: :doh:
The canopy went on with just a small amount of sanding so that the curve of the plane and canopy was seated nicely.
The front section was fixed on with Revell Contacta Clear. A small gap at the base was filled with PVA glue.
Time for pre-shading, which looks not so good but that's how the rest of the days painting session went. :violin: :violin: :violin:
The underside of the aircraft was painted Mr Hobby RLM 65 Light Blue.
Plus the undercarriage doors. :lol: :lol:
Once dry, I gave two hours today as it was a warm and dry day, the first part of the splinter pattern was free handed on.
Mr Hobby RLM 74 Dark Grey.
While the first coat of paint was drying paper masks were made from printer paper.
Second colour added. Mr Hobby RLM-81 Brown Violet.
Masks removed to find gaps! :bash: :bash: :bash:
This was down to bright sunlight shining through the window on to the model and my not so good eye sight. :violin: :violin:
A little touch up needed, that's better. :dance: :dance:
I might put another colour on. :think: :think: :think:
Thank's for dropping by. :th: :th:
pourquoi61
OKAY it is time to own up, in my haste to get the model underway I cut off a part which I later discovered I should not have. (Section one cockpit floor/undercarriage floor)
I cut away the location hole with the key-way that secures the front main leg.
This is the area.
So first I built the main leg.
I then sorted the right size tube to replace the bit that I had cut off.
Voila.
I then cut a small section out and placed the leg in.
Then I built the rest of the main leg workings. Watch out for the cross strut part (35) as it flirted into the carpet when cleaning up. :bash: :bash: :bash:
Then the leg was glued in place.
I will touch up the paintwork once the glue has dried.
That's all for tonight folks.
Thanks for dropping by. :th: :th:
Hope your son's ok mate!
Nice work on the paint job, and great save on the undercarriage too - this is really coming along nicely :clap:
pourquoi61
Tomcat64 wrote: Fri Jun 08, 2018 2:44 pm Hope your son's ok mate!
Thank you, he is recovering well but still on soft foods.
I am not happy with the paint work as the two colours are for me not a good choice.
Working on that. :think: :think: :think:
pourquoi61
:bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash:
Recap this is how I painted the wheels.
First the wheel halves were glued together.
Then painted black, sorry no photo.
A coat of Citadel Shadow Grey was painted on.
Once dry, a coat of Citadel Stormvermin Fur was painted over the top.
NOW TRAVEL FORWARD IN TIME TO TODAY. :? :? :? :?
So I assembled the rear undercarraige .
Once dry this was glued on to the model.
The instructions are a little confusing on exactly where to glue the leg actuators, but all becomes clear when installing said parts to the model.
Not happy with the two colour splinter camo, I chose to add another.
So I roughly drew around the wings.
Cut out a splinter shape that I liked.
Stuck rolled up pieces of Tamiya tape to the model.
Then placed the paper mask on top, adding small rolls where needed.
Picked my third colour, Vallejo Model Air RLM-65.(71.008,FS35352)
Then sprayed on.
I did add two other patches on the tail and wing tip.
The rest of the undercarriage doors are glued on and a coat of Tamiya Clear X-22 was sprayed on both sides.
Yes I know the wheels are not straight. :wall: :wall: :wall:
That's all folks and thanks for dropping by.
:th: :th:
pourquoi61
Time to add a bit of colour to the model so I went with a red colour(Revell Aqua colour Carmine Red-36)
I roughly masked off the area with Tamiya tape and brush painted with red.
After two coats of paint I removed the tape to reveal that some of the paint had bled underneath.
I scraped some of the excess paint off with the back of a knife blade.
The model was then given a coat of Tamiya clear and once dry the decals were applied and then another clear coat added.
That's all for today folks.
:clap:
Nice touch with the pale blue splinter patches - they stand out nicely and offset the other colours.
pourquoi61
Tomcat64 wrote: Tue Jun 12, 2018 10:03 am :clap:
Thanks but I had to do something with the colour choice to "snaz" it up a bit. :th: :th:
pourquoi61
On with the build and a clay wash of sand was applied and left to dry.
I went for sand as it was the only wash available to me at this time.
Then removed with a damp paper towel and cotton buds.
I then gave the model some oil/fuel leak marks using oil paint dots applied with a cocktail stick and then dragged downwards with a flat brush dipped in white spirit.
Once dry, the model was given a coat of Tamiya matte clear XF-86.
On the top side of the aircraft I added a small amount of white matte paint to the clear, applying more of the mix on the grey paint to add contrast to the three colours.
Just a few more parts to paint and add to the model and she is done.
Thanks for dropping by. :th: :th: :th:
