Help disaster with video
latkin
Post by latkin »
Not sure who to address this to so anyone who can help please do. I intended to join this SIG with a figurine of a character called Bayonetta. While videoing the opening of the box and showing the contents the video unbeknown to be stuffed up and I only have the first part of it left. I still want to join but can't show the necessary unboxing as it is all now unboxed. I could photograph the parts as it hasn't been started just unboxed. Would this be acceptable as evidence of the model not been started yet so that I can join the sig?
Re: Help disaster with video
Hey buddy - Photographing the box, sprues and decal sheet etc will be fine :D
Look forward to seeing your build :th:
latkin
Post by latkin »
Thanks for that but there are no sprues, it came in bubble wrap as single peices, It is a resin kit and there are no decals as it is a figurine and the box is just a cardboard box. To make matters worse there are no instructions just a small parts sheet. I do have the first 6 minutes of the video as proof if needed to varify that I have not started yet. Is this still ok?
Photo's will be fine my friend. This is not one of 'those' forums :D
If to honest I would rather see pics of the sprues as I think you see the kit better :th:
latkin
Post by latkin »
Thanks for that. I will take some photos of the parts and post them and then start on the long process of cleaning up the parts as you will see from the photos. In this case Paul there are no sprues. The kit came in pieces wrapped seperately in bubble wrap and I meen every part was seperate which is how resin comes I believe although most resin seems to be put in a single bag.
