1/48 Kittyhawk Sukhoi Su-17/22 UM3K Fitter
IanG
Post by IanG »
This will be my next build, Kitty hawk’s 1/48 Su-22UM3K.
The scheme will be in the Polish AF’s 305 “Black Boar” special markings
Aftermarket used will be;
Eduard PE cockpit set
Eduard seat belts
Eduard canopy mask set
HAD Models resin FOD cover set
ModelMaster pitot and fun barrel set
Model Maker 305 “Black Boar” decal set
ImageIMG_6094 by ian gaskell, on Flickr
ImageUntitled by ian gaskell, on Flickr
IanG
Re: 1/48 Kittyhawk Sukhoi Su-17/22 UM3K Fitter
Post by IanG »
Seats are nearly done. Very well detailed for kit supplied seats, and there’s a lot of parts to them. Painted the seat frame with black primer, and then details picked out with Hataka Blue Line paints.
Seat padding is Orange Line Sky Type S, with some AK Smoke pigment used to “dirty” it up.
Just the Eduard PE belts to attach.
The HAD Models resin FOD covers were painted with Blue Line Pure Orange. The Blue Line thinned a lot with Hataka acrylic thinners. The FOD’s will receive a small amount of weathering.
Finally, I repainted the Eduard cockpit set’s console panels, as the pre-printed colour had a pink hue, which didn’t look right. So I hand painted them with Blue Line Light Ghost Grey (note the colour testing on the outer frame).
ImageDSC_2852 by ian gaskell, on Flickr
DoubleDigit12
Post by DoubleDigit12 »
Looking good so far Ian!
James
IanG
Post by IanG »
DoubleDigit12 wrote: Sun Aug 26, 2018 9:59 pm Looking good so far Ian!
Thank you James.
IanG
Post by IanG »
Attached the etched belts, and applied a couple of decals, from the Airscale labels/placards decal sheet, to the headrest sides. Then finished off with a dry-brush of aluminium.
Also made a start on the instrument panels. The main IP’s are done. The PE panels are a very good fit.
ImageDSC_2862 by ian gaskell, on Flickr
ImageDSC_2864 by ian gaskell, on Flickr
Steve64
Post by Steve64 »
Lovely work Ian.
Did you see Spencer Pollard's YouTube review and build commentary on the M3/4 version? It helped me avoid potential pitfalls with the complicated fuselage assembly and a few other areas.
Looking forward to seeing more from you.
Steve.
IanG
Post by IanG »
The cockpit is now together, and given a light wash. Very pleased with the way it's turned out. The Eduard PE has really lifted the detail.
I have also got the fuselage section together. Completely disregarding the instructions, I cemented the sections, to make 2 traditional "halves". I have also used some thick plastic strip, cemented inside at the joints, to add some strength.
The black, on the upper most half, is where I have filled, and sanded out the cannon blast shield, which isn't present on the UM3K Fitters. Then it was primed with some Stynylrez primer.
ImageDSC_2871 by ian gaskell, on Flickr
IanG
Post by IanG »
Steve64 wrote: Wed Sep 05, 2018 1:06 pm Lovely work Ian.
Steve.
Hi Steve
Yes I did, before I build my own M4 early last year. It was a very helpful video.
ImageIan G-10 by ian gaskell, on Flickr
Steve64
Post by Steve64 »
Hi Ian
I'm pleased to read it. I followed the same technique with the fuselage sections, and like your kit, it worked out well. Your M4 looks great and so does your work so far on the two seater version. I'm looking forward to seeing the end result.
Thanks for sharing.
Steve.
IanG
Post by IanG »
Steve64 wrote: Mon Sep 10, 2018 8:34 pm Hi Ian
Thanks for sharing.
Steve.
Thank you Steve.
IanG
Post by IanG »
Cockpit tub now installed. A bit of filler here and there, but it’s in.
All the wheel bays have been painted, and weathered. Same with the wheel bay doors and airbrakes.
The starboard gun barrel has been replaced with a metal MasterModel item, and the port gun opening has been filled with some 1mm plastic rod.
ImageDSC_2878 by ian gaskell, on Flickr
DoubleDigit12
Looking good Ian!
James
IanG
Post by IanG »
DoubleDigit12 wrote: Fri Sep 21, 2018 9:45 pm Looking good Ian!
Thank you James.
IanG
Post by IanG »
So, all the scoops and antenna are attached. Also the fixed parts of the canopy are cemented in place.
The MasterModel pitots are really beautiful pieces of metal and resin. They are dry fitted for now. I’ll fix them permanently at the end.
I’ve made the swing wings removable, which makes things so much easier for painting and weathering. I simply cut open the locating hole, in the swing wing. So now they click on and off the main wing’s locating pin.
Prior to being primed with Ultimate black, the airbrake interior has been coated with Maskol.
ImageDSC_2885 by ian gaskell, on Flickr
IanG
Post by IanG »
Weapons pylons are now painted, and some masking was done to paint the bare metal areas.
A few light coats of Aqua Gloss was airbrushed on, and when that was fully dried, I made a start on the decals.
I’ve got the main markings applied, and am now looking forward to the pleasure of dozens of stencils!!
ImageDSC_2895 by ian gaskell, on Flickr
IanG
Post by IanG »
Now back on the Fitter.
After a gloss coat, the decals are done.
Loads of stencils, but there's still less than Phantom!
ImageDSC_3246 by ian gaskell, on Flickr
ImageDSC_3244 by ian gaskell, on Flickr
Fan-freakin-tastic :banana: :banana: :banana:
Sorry it hasn’t got the recognition it deserves, just a great build and scheme :thumb2:
Absolutely love how this is coming out. Details are great and the paint is phenomenal
Reminds me of those cool Playboy Phantoms...have a kit5 in the stash :think:
IanG
Post by IanG »
Twokidsnosleep wrote: Sun Nov 18, 2018 5:56 pm Fan-freakin-tastic :banana: :banana: :banana:
Thanks Scott.
I’ve been wanting to build this example for a few years now, but firstly there was no 1/48 Su-22UM3, nor the decals in 1/48 either. Luckily that all changed. :)
fly1ngdutchm4n
Post by fly1ngdutchm4n »
That's awesome.. love it :D !
IanG
Post by IanG »
fly1ngdutchm4n wrote: Mon Nov 19, 2018 3:06 pm That's awesome.. love it :D !
Thank you. :)
IanG
Post by IanG »
All the decals and stencils are finished. I’ve applied a couple of light coats of matt varnish, to seal them.
A mid-grey Ammo panel line wash has been applied.
The fuel tanks have been attached, and the undercarriage is dry fitted , just allow standing the Fitter for now.
I’ve also fitted the airbrakes, in a slightly open position.
On the top of the nose, and along the dorsal spine, I made some new antenna, to reflect the ones currently seen on Fitters.
IanG
Post by IanG »
Almost finished.
All the undercarriage attached. FOD covers and pitots fitted. Dark pigment was used to create wear marks, where the swing wings move in and out of the main wing root.
And a final coat of matt was airbrushes to finish off.
ImageDSC_3256 by ian gaskell, on Flickr
ImageDSC_3257 by ian gaskell, on Flickr
ImageDSC_3258 by ian gaskell, on Flickr
shortCummins
Post by shortCummins »
Ian, that black paint is really good, it could so easily have looked like a black slab, the orange(red) really lifts the whole piece
rgds
John(shortCummins)
IanG
Post by IanG »
shortCummins wrote: Sat Dec 01, 2018 3:14 pm Ian, that black paint is really good, it could so easily have looked like a black slab, the orange(red) really lifts the whole piece
rgds
John(shortCummins)
Thanks John. :cheers2:
IanG
Post by IanG »
Tazman3 wrote: Mon Dec 03, 2018 5:51 pm One of my favorite aircraft...just love it's lines...beautiful paint job...well done!
Thank you @Tazman3 :th:
Beautiful work as always Ian :clap:
As John said earlier the finish on the black is just stunning - is that simply the Ultimate Black Primer with the various gloss/matte coats on top or did you put down another layer that I've missed?
barrythornton
Palestine
Post by barrythornton »
Confession : I clicked this thread, not because its a Jet (not my bag), but because its a `Kittyhawk`, and i was interested to see just what a horrendous bag of marbles was going to be in the box :)
Erm ... turned out great, cant spot any major `Do Not Buy` issues, and no mention of any hammer inducing problems from either you or the comments.
Just goes to show. Well done sir.
IanG
Post by IanG »
​​And it's done! 🙂
viewtopic.php?f=45&t=26058
ImageIan G-3259 by ian gaskell, on Flickr
DoubleDigit12
Nice finish Ian!
James
IanG
Post by IanG »
DoubleDigit12 wrote: Wed Dec 05, 2018 8:26 pm Nice finish Ian!
Thank you James.
