Hello from Alberta Canada
dave39
Post by dave39 »
Finally retired and want to get back into a hobby that I last participated in probably 45 years ago. Have I missed anything since then??? Have watched hours and hours of your utube wideos and with credit card in hand I am ready to head to the Hobby Store.
Look forward to chatting and learning the new and latest techniques. Any advice is much appreciated.
Should be fun!!
Regards
dave
Re: Hello from Alberta Canada
dave39 wrote: Thu Sep 13, 2018 9:10 pm Finally retired and want to get back into a hobby that I last participated in probably 45 years ago. Have I missed anything since then??? Have watched hours and hours of your utube wideos and with credit card in hand I am ready to head to the Hobby Store.
Should be fun!!
Regards
dave
:welcome: back.
You are no doubt amazed at the level of change.
As to buying stuff.... ONLY buy what you need. I bought so much that I don't use or need. A lot can be achieved with very little.
1 small flat pocket file.
1 heavy duty craft knife....exacto.
1 smaller craft knife
1 Tamiya extra thin cement ..... Some suer glue, and the cheap 1ml tube would be fine
2 masking tapes.... 10mm, 5mm
1 good quality tweezers with a parallel point .... Do not buy cheap or you will be forever looking for lost parts.
A variety of paint brushes
soft grip clothes pegs to use as clamps
1 good quality sprue cutter....do not use cheap side cutters as it damages the plastic. I now use Disipae sprue cutters.
If you are going to be using a lot of PE then a xuron PE cutter ( blue handle ). Tamiya also do good tools.
Paints are a different issue and sets can be bought that will do a particular subject at and when needed. Also brush painting compared to AB painting and types of paint will dictate what particular items will be needed. Thinners, brushes, gloss coats, metal paints, etc it is a huge subject.
In any case the stuff I have listed ( if I didn't forget something ) will be enough to finish a kit to a good standard. Advanced modeling may have a couple more extras.
:th: :th: :cheers2:
DerekHallett
Post by DerekHallett »
Hey Dave,
Where in Alberta are you located?
Derek
Hello and Welcome
Good stuff from Digger :thumb2:
Hide you wallet if you go on the Internet hunting firvmodel stuff......scary :eeek:
kiwigav
New Zealand
Post by kiwigav »
:welcome: Dave
Cheers Gav
:welcome:
Hello and welcome from Ohio (USA)...
Ben
Nev
Post by Nev »
:welcome: Dave to the forum :thumb2:
On the Bench...
dave39
Post by dave39 »
DerekHallett wrote: Fri Sep 14, 2018 3:55 am Hey Dave,
Derek
Red Deer. You?
DerekHallett
Edson. Check out Hobby Wholesale in Edmonton. Decent selection, lots of paint and other supplies, and fairly good prices. I try to hit it when I'm in town, but they also do online ordering (free shipping over $85) and if you're early enough, you may be able to get your order the next day (I have!).
Derek
Return to “Introductions”
