Great Wall Hobby 1/144th Avro Vulcan B.2
Tamiyasnob
Post by Tamiyasnob »
Part two of my group buildIs this, probably the best kit in this scale, see what you think after the reiew shot,s.
Really nice box art.
The first thing you are greeted with is this exquiste one piece lower fuselage
Close up of the panel detailing
Sprue A, not a hint of flash anywhere !
Sprue B, again flasless.
Weapon,s, crystal clear transparencie,s and lovely detailed weapon,s
Close up of the jet housing,s, note the location of the sprue gate,s, none of the mar the part,s in anyway.
As with the lower fuselage, the upper is kept seperate from everything else in a seperate box.
Unfortunately this did not prevent damage to one corner of the wing. Apparently this common with this kit, but is an easy fix if still a little annoying.
Close up of the cockpit area, (seriously this is 1/144th)
Decals and a display stand. Decals are for two aircraft involved in the 'Black Buck' raid,s
1/1 scale colour chart,alway,s a nice touch. Colour call out,s are for Mr Hobby but are easily converted .
Instuction,s are an A4 two page booklet, most of the dialouge is chinese ( I think) but constuction is straight forward enough.
[URL=http://s91.photobucket.com/user/Muckypu ... 1.jpg.html]Image[/URL
Hopefully this review has given you are fair idea of what this kit is like, but take my word for it, if you want a great small scale Vulcan the n this is it. Plus GWH are bringing out the refuelling version And I am sure the aftermarket boy,s will be all over this. So hope to start this next week when the Gannet build get,s a bit to intense,cheer,s Dave.
Re: Great Wall Hobby 1/144th Avro Vulcan B.2
Brilliant entry Dave, look forward to seeing this come together :th:
DC87
Post by DC87 »
I have been wanting to see one of these built. Looks like a great kit, I have my eye on the refueling variant that is just being released.
Best of luck, I'm sure you will do the kit justice.
Dan C
Filling the workbench with:
Sopwith Snipe late post war
WW1 RFC SE5a
WW1-1/32 Snipe
UKscalemodeller
Post by UKscalemodeller »
Looks nice. Good luck
bullgill67
Post by bullgill67 »
looks great looking forward to the build :pop:
michael
Looking forward to this one as I've been umming and ahhing whether to get this kit or not.... :th:
fly1ngdutchm4n
Post by fly1ngdutchm4n »
NICE!
Love this bird.
Looking forward to see it build! :thumb2:
SiDennis
Post by SiDennis »
Love this big bird, looking forward to this one :thumb2:
Simon
Jamesday1998
Post by Jamesday1998 »
looking forward to this build and really want to get this kit but the bad thing is it is pricey :pop: :pop: :th:
my youtube
Radzy
Post by Radzy »
That's amazing plane !!
I haven't got many occasions to visit UK, but I was lucky enough to visit our main supporting software headquarters who are placed in Wellesbourne.
And one of the remaining Vulcans was there (I think it's stationed there) - I could almost... touch it :)
Looking forward to see it finished.
Regards,
Radek
WIP:
My Portfolio
My YouTube Channel
Tamiyasnob
OK here is some tech on the aircraft
General characteristics
Crew: 5 (pilot, co-pilot, AEO, Navigator Radar, Navigator Plotter)[nb 1]
Length: 97 ft 1 in (29.59 m)
Wingspan: 99 ft 5 in (30.3 m)
Height: 26 ft 6 in (8.0 m)
Wing area: 3,554 ft² (330.2 m²)
Empty weight: 83,573 lb (including crew) (37,144 kg)
Max. takeoff weight: 170,000 lb (77,111 kg)
Powerplant: 4 × Bristol Olympus 101, or 102 or 104 turbojet, 11,000 lbf (49 kN) each
Performance
Maximum speed: Mach 0.96 (645 mph ( 1038.03km/h)) at altitude
Cruise speed: Mach 0.86 (567 miles per hour (912 km/h)) at 45,000 ft
Range: 2,607 mi (4,171 km)
Service ceiling: 55,000 ft (17,000 m)
Thrust/weight: 0.31
Armament
21 × 1,000 pounds (454 kg) of conventional bombs
1 x Blue Danube nuclear gravity bomb
1 x Violet Club 400 kt nuclear gravity bomb
1 x U.S. Mark 5 nuclear gravity bomb supplied under Project E
1 x Yellow Sun Mk.1 400 kt nuclear gravity bomb
1 x Yellow Sun Mk 2 1.1 Mt thermonuclear gravity bomb
1 x Red Beard nuclear gravity bomb
On 3 June 1982, Vulcan B.2 XM597 of No. 50 Squadron took part in the "Black Buck 6" mission against Argentinian radar installations at Stanley airfield in the Falkland Islands. Two of the four AGM-45 Shrike missiles were fired. On the return journey, while attempting to refuel from a Victor K Mark 2 tanker aircraft, the tip of the probe broke in the drogue. With insufficient fuel to return to Ascension Island, the Vulcan diverted to Galeão Air Force Base at Rio de Janiero in neutral Brazil. En route, secret papers were dumped along with the two remaining Shrike missiles, although one failed to launch. After a mayday call, the Vulcan was escorted by Brazilian Air Force Northrop F-5 fighters and was allowed to make an emergency landing at Rio; there was not enough fuel for a circuit of the airbase.[223] The Vulcan and her crew were detained until the end of hostilities nine days later.[224]
I must start of with a boo boo,the upper and lower fuselage halves are an extremly tight but perfect fit. So tight in fact that having dry fitted them together I was unable to seperate them, and trying to do so could end up with me damaging the kit :wall: .So if you plan to build this kit you may want to ream the female locating hole,s out a bit to lessen the tightness of the fit. Anyway some build shot,s
The air intake,s have been fitted,( no seam,s on these , they are slide moulded) and the tailplane fitted, Just six part,s and you have this beauty ! The three part stand is ball mounted, so it can be posed in different :scratch:: pose,s
Some Perfect plastic putty was needed on the intake,s to wing joint, though nothing major.
Same at the base of the tailplane but again merely superficial
Here is an example of the simplicity and wonderful fit of this kit, the engine fairing,s and bomb bay door,s have been removed from the sprue and just the sprue stub has been sanded smooth and-
Here they are dropped into place not yet glued, superb engineering.
Cockpit sprayed Matt black (Tamiya) and the pilot,s flying suit,s XF 22 and helmet,s Matt white. Other than that my Mr Magoo eye,s couldn,t see a great deal else ( they are minute)
Wheel,s all made up,again the detail in this scale is excellent, nothing to fiddly but enough to take a wash and dry brush just to accentuate the detail that is there
Canopy added, a two piece and again after slight clean up the fit is superb. As you can see this kit really catche,s the beautiful line,s of this wonderful aircraft.
Wheel,s dry fitted to check the fit and to ease painting later on, after I figure out some way of holding them while painting. I am fitting it wheel,s down but will alter it from display stand to airfield diorama when the mood take,s me.
If I only have one gripe with this kit it,s the lack of detail to the bomb bay interior, but if the aftermarket boy,s go to work on it I may have to build another or three.
So next up I will mask the canopy fit the weapon,s and she is ready to prime hopefully at the weekend, cheer,s Dave.
Nice update Dave - Certainly looks the business :th:
DC87
Post by DC87 »
Great progress, the landing gear looks awesome, must have been a bit fiddly.
Dan C
WW1 RFC SE5a
WW1-1/32 Snipe
UKscalemodeller
Looking good. Size wise I think this may be the only vulcan I may ever own
Looks a great little kit,look forward to seeing more :th:
Tamiyasnob
So seeing as it,s been a couple of monty,s since my last one, best do an update on the build.
Having primed the model I made a start on the pre-shade with Tamiya XF 69 Nato black
While I had the black in the paint cup I also sprayed the undercarriage
Next I sprayed the under surface,s inTamiya XF 75 IJN Grey, The Tamiya Ocean grey seemed a little to dark to me
Then the XF 75 was thinned and a drop of white added to achieve a faded look for the post shade
I then masked up the wheel well,s and sprayed the interior of these Tamiya Flat white
After a fairly long absense to start the Whirlybird sig I decided to resume work on the Vulcan,
The upper surfaces were sprayed Tamiya XF 83 Medium Sea Grey, unfortunately not only did lose the pre-shade I forgot to take a photo , so here it is at the start of the masking. I decided to use a method I have not used before, white tack rolled into worm,s to mark out the area,s to remain grey
Then masking tape to finish before applying Tamiya XF 81 Dark green 2[RAF}
Me being impatient as usual could not wait to remove the masking
So with the masking removed she is now ready for some post shading using lighter and darker shade,s of the grey and green upper colour,s
So that,s it for now, as I say post shading next, hopefully tomorrow so happy modelling, cheer,s Dave.
That is looking great mate shame about the pre-shading but it still looks super
UKscalemodeller
Stunning
that is all
Joesdad
Post by Joesdad »
Brilliant update and great paint work. I've kinda been looking at this kit myself, it's the price that puts me off..
More the same please mate :thumb1:
Tim
Tim (Ted)
British Aviation In Scale
T3hGuppy
Post by T3hGuppy »
Great update dude the camp looks really nice.
Really doing a awesome job on this bird :th:
Too much to list. !!
Camo looks cracking mate. Really nice work. A nice dark wash will bring back those panel lines on the top and bottom there.
Looking forward to seeing this get finished.
longlance67
Post by longlance67 »
Well done on the camo looks great :th:
Shane
Trumpeter Stryker ESV
Hobby Boss 1/48 F18 Hornet
28mm Napoleonic project
My Channel:
Post by Rob »
Very nice indeed :th:
Jamesday1998
Looks awesome!
my youtube
Tamiyasnob
OK, after a fairly long lay off got some more work done on the Vulcan
Post shading finished and a couple of coat,s of Klear in readiness for the decal,s
Undercarriage fitted along with the gear bay door,s
Couple of quick pose,s of the Vulcan on it,s stand
Decal,s on. If there is one let down on the kit it,s the decal,s, they are way to thick, even after three application,s of Micro set they still havn,t snuggled down. So next another two coat,s of Klear, a panel line wash and a matt coat to finish. Hopefully before the 14th, cheer,s Dave.
Looking good Dave, funny how adding a few decals dramatically changes the look of a kit :cheers2:
Jamesday1998
Looks awesome :jd:
my youtube
Dunhill2005
Post by Dunhill2005 »
Awesome plane!!! :jd:
Your job is awesome too :thumb2:
Very nice Dave - Have contemplated this kit many times!
Looking really good mate. Shame about the decals, but if they weren't for settling, they they weren't for settling I guess!
I look forward to seeing this finished now!
T3hGuppy
Post by T3hGuppy »
Really coming together nicely dude.
The highlighting of the panels really help the detail stand out. :th:
Looks beautiful, mate! That cam is perfect, well done. :th: :th: :th:
