Ism Friday's night live at the bench what have you been working on for *October 19th*
**Open now until 1 hour before the show on Friday, October 19th**
We thank you in advance for allowing us the opportunity to showcase your models! - Lee Larholt, Paul Bretland, and the rest of the ISM moderators and live crew.Image
js1714
Re: Ism Friday's night live at the bench what have you been working on for *October 19th*
Post by js1714 »
Greetings Slaves to the plastic, this week see's further progress being made on the Trumpeter, 1:35 Karl Gerät. Primed in Ultimate Grey, and based with various rust colours. Tracks are now also complete and painted. However there is much much more work to be done, hope you like it so far,,model on....OR....!! :bash:
Phyzio
Post by Phyzio »
Here is a photo of my first model in 40+ years. Got a very old Revell 1:90 kit of the Santa Maria off of eBay. Poor kit with many bent or warped parts (huge struggle to get the 2 hull halves together). Should have started with something simpler and newer. Paints used were those that were supplied with the kit (Revell Enamel, which were OK after vigorous shaking and stirring). The paper mast flags are horrible. Did not use the figures supplied with kit. The Portuguese Marine on the far left seems to be standing in the: “I’m a little Teapot, short & stout, here’s my handle, and here’s my spout”! Next model is a Revell level 3 RAF Typhoon Eurofighter, so no more bloody rigging or flags!
Strohmann
Post by Strohmann »
Building my Type 59 from World of Tanks:
Using Tamiya 1/35 t-55a as a base with bits from Legend Models T-54 1949 set, DEF Model D-10T barrel set, Voyager 7.62 tank MG, and Master Club tracks(MTL35048).
Tamiya 1/24 Mercedes AMG GT3 "Eva" racing team
*Primed in Ultimate modelling white primer
*Painted in Zero Paints Eva Purple
*Hobby Design decals
*Pro Range 2K clear
*Wheels and Spoiler painted in Tamiya TS-14
All spayed through the Ultimate Apex airbrush
Great kit and decals and a great looking scheme.
Timplastic
UN
Post by Timplastic »
This week I have been mostly eating out mens bums
Oops
This week I have been working on the Eduard focker d.vii. Prop is done and I have started on the rigging.
I have also opened the box top on the next build. I won’t be doing a norm and closing the box. This will be built !!! Image
MakingModels
Post by MakingModels »
This week I have mostly been making a photobooth..
Ingredients :
2x A1 sheet of Foam Board.
3x A2 Sheets of Foam Board.
1x Glue Gun and spare glue sticks.
1x Straight Edge
1x Cutting implement
x2 A1 Sheets of Card (one white one Black)
1x 1mtr Led strip light
Place in oven gas mark 6 for 1hour 45 minutes..
Bingo...
Danthegoat
Post by Danthegoat »
I have done a little bit on my Trumpy 72nd Su-30.
I have put together and fitted the engines and intakes with a little sanding and fettling. Used some Ultimate black primer to check seems and sanding. Hopefully I can get her into full primer children permitting at the weekend.
Lovely kit.
I am a decent modeller and an amazing lover. ;)
arilo76
Italy
Post by arilo76 »
WIP : Airfix 1/48 Spitfire VB
Ultimate Primer
MRPaints
Tamiya Paints
Few fitting issues but nothing really terrible.
Antonio
Stay Classy ISM
I’ve been a bit distracted from getting much modelling done these past few days so here is as far as I’ve got with the Welsh Models 1/144 Fokker F-27-500. The kit is more or less straight out of the box with a few little details added to give it that sense of je ne sais quoi. This is the second coat of Tamiya rattle can primer - I thought I’d save some time by using the paint straight from the rattle can and, you guessed it, paint in all the wrong places, After a good sanding down this is what it looks like after a try with decanted Tamiya white primer. Closer to completion next week, I hope.
warpedcrisis
Post by warpedcrisis »
Mixed bag this time
St chamond by hobby boss in 1:35 primed in Ultimate grey primer.
Revell 1:24 samba bus Ultimate grey primer and then Zero paints sealing waz on the lowe half and beige grey on the top.
Hope you all have a good weekend Andrew
Hey folks,
Progress on the 1/32 Trumpeter SBD-5A-24B:
Wheels on, prop finished and weathering in progress. Several photos show severe wear on the port wing. I may have overdone it slightly but who cares? Just about there, only the flaps/dive brakes, aerials, pitot tubes and radio wires to stick on and it's done.
Thanks for looking.
Image19_10_2018 by Alan MacNeish, on Flickr
Black73Cat
Post by Black73Cat »
Paul asked if I'd like to add this to the Telford display on the Ultimate stand. Having never displayed any of my work, I'm a bit nervous... especially as it has been sat there, unfinished for months! So I'm now on a mission to get it finished and onto some sort of diorama...which is also very daunting, having never done any sort of dio before! I should get it started but procrastination is strong 😂
Anyway...this is the 1/24 scale Italeri British Gas Transit...left to rot somewhere, since the late 1980s!
All painted and chipped a long time ago but this week, I've been sorting windows and wheels. Tyres were flattened with a combination of fire, knife and a white Ultimate sander. Windows were streaked with MIG Ammo products then I wanted to recreate the moss that builds up around window rubbers... eventually did it using MIG Ammo Slimy Grime wash then some green pigment which I got by evaporating some Ultimate Algae Wash.
Almost there... then I really need to make a start on the dio! 😏
Graeme Pearson
YouTube
Www.YouTube.com/Black73Cat
Novorus
Post by Novorus »
Well Mathew been working on the next How I do item in the series, which will be about water. So here's a seek peak!
Here is the base for my 1.72 LCVP Landing craft by Airfix. Primed in Ultimate black primer, painted using model color 898, 868 973 and 847.
Hope you like it.
James
NormanD
Post by NormanD »
Manufacturer : Hobby Boss
Kit : Soviet SS-23 Spider Tactical Ballistic Missile Mobile launcher
Scale : 1/35
Keeping the guess work going on what I am working on each week, I removed this one from the safety of it's box and began fiddling with it again, It's a large model with very good fit, but a bit of a head scratcher with all the small number photo-etch parts that need to be added, well can't complain as it's out of the box, so lets get going.
Tune in next week for another mystery out of the box fiddling session
I still refuse to endorse any ISM or Ultimate advertising on my photos
I have wrapped up the Tamiya Mercedes AMG GT3.
It was primed in Ultimate White, painted in Splash-Paints Hell Green Magna, and cleared with Splash-Paints 2K Flat. The decals are from SK Decals and were fabulous. Up until now I have been regretting going with a flat clear, but it is growing on me. I hope you enjoy my Beast of Green the Hell.
AdamChallinger
Post by AdamChallinger »
Bit of progress on Italeri's DAF Maritime truck. Got the chassis on both the truck and trailer finished. Been working on the cab, and also trying to work out how to get the interior in, after the cab has been assembled. Once that was done, i got it into primer and started work on the curtainside trailer. Lots of gaps once it was together, so filled them all and this is as far as i got. Shes quite a size as you can see!! Hopefully will get the rest primed and get some paint on this week.
Andreas
Norway
Post by Andreas »
Hello. This is the state of my current build. It’s a eduard spitfire in 1:48 scale . The principal weathering is done.. still needs some touch ups and there are still some subassemblies that needs to be done. Thank you and, stay classy ISM
- Stuff!
I love lamp!
Having been on holiday all I done since getting back is put a gloss on my revell 1/24 cobra Image
