Airfix 1/72 Messerschmitt BF 109E-4
Quax
Greenland
Post by Quax »
Ok last but not least the Bf109E-4 from Airfix. According to Scalemates this is a reboxing with new decals of a 2012 kit. If this is a 2012 effort its ok but not great...
the cockpit is fairly basic even for 1/72 standards but as most of it will be invisible its ok. The belts are moulded to the seat and would take some significant effort to remove so if you want separate belts consider replacing the seat
a bit of filler here and a splash of Ultimate primer there..
A mess as usual...
Re: Airfix 1/72 Messerschmitt BF 109E-4
Wow that came together quick!
I guess if you want to use the pilot then you need to sand down the moulded details?
Quax
Greenland
Post by Quax »
Thanks Neil, the airfix kits are good to get from spruce to fun in one easy move..
Ready now for a gloss and decal.
Cheers Paul
A mess as usual...
Quax
Greenland
Post by Quax »
Calling this done now. Other photos in the reveal section
A mess as usual...
