Revell 1/35 Dingo 2 GE A3.3 PatSi
AndrewR
Romania
Post by AndrewR »
Hi everyone and thank you for checking my first build :bow::
I've spent the last three months looking at other people's work, joining the live shows, joining groups and so on and I've finally decided to give it a go. Being a new comer to this hobby I have a limited budged as you could expect therefore picking a first proper kit was difficult but I finally decided to go with the 1/35 scale Dingo 2 GE A3.3 PatSi from Revell.
I've been working on it for the past month and I've learned a lot from it so far.
I've followed the exact steps showed in the instructions and I've started with the chassis:
Since I had the chassis done I've decided to also trow some paint on it:
Next step was to build the interior and I've also glued together the doors because I was sure I will not be able to paint them once I place them on the body and the hood because I wanted to test the newly bought paint from Revell (code 32189) and my skills of course :wall:
I've decided to build some sort of base for it with the idea to transform it in a diorama. The base was made for foam covered with paper tissues soaked into a mix of water and PVC glue:
From this point on a lot of things went wrong especially fitments issues, breaking the small parts, instructions having gaps in them and so on but I finally managed to get to this point when I threw my first wash with some oil paint I use on my paintings:
Looking at these pictures I've noticed a lot of things I need to fix and I will soon :D this is not done yet
DoubleDigit12
Re: Revell 1/35 Dingo 2 GE A3.3 PatSi
Post by DoubleDigit12 »
Looking cool so far!
James
Tiger131
Post by Tiger131 »
great looking build and love the weathering
If that is your first kit then you are doing very well.
AndrewR
Romania
Post by AndrewR »
Thank you guys for the kind words.
Well yes, this is the first kit I've built. A lot of time spent on doing research to be honest.
I've realized in the past weeks that this is quite an expensive hobby :)) and I need to get some $ to invest in some tools, paints etc.
