krusty's trumpeter rooikat
krusty69
Post by krusty69 »
hey guy's and gal's one goes in paint and another get's started.
trumpeter's 1/35 south African rooikat afv
Image20181119_205349 by robert noonan, on Flickr
Image20181119_205407 by robert noonan, on Flickr
Image20181119_205419 by robert noonan, on Flickr
Image20181119_205448 by robert noonan, on Flickr
Image20181119_205324 by robert noonan, on Flickr
Image20181117_181010 by robert noonan, on Flickr
well got started on the hull and the running gear. you can tell the difference between Tamiya and trumpeter, the Tamiya get fell together the trumpeter a little flashy. little fiddly, fit ok but not great, but still it's kind of a cool vehicle.
Image20181120_192026 by robert noonan, on Flickr
thanks for looking
krusty
krusty69
Re: krusty's trumpeter rooikat
Post by krusty69 »
been banging away at the running gear. the directions call for some fiddly bits before the running gear and the upper hull are joined. well you know I broke some of them off, skipped ahead a few steps and got the big pieces on. and will start filling the smaller pieces tomorrow.
Image20181121_204055 by robert noonan, on Flickr
Image20181121_204107 by robert noonan, on Flickr
krusty69
Post by krusty69 »
finished up the lower hull today that leaves the turret for tomorrow.
Image20181122_185538 by robert noonan, on Flickr
krusty69
Post by krusty69 »
ok we are calling this one built, got the turret cranked out tonight. she will be ready for primer tomorrow, than I can start the camo. frankly i'm a little nervous it really looks hard edge, and there is a lot of small parts to get in the way of tape. I'm using hataka lacquer, and i'm thinking about spraying the camo and trying to put on a hard edge with a brush. any idea's. or are all of you vultures want to watch the train wreck :whistle: . if you any idea's let me know
Image20181123_203928 by robert noonan, on Flickr
Image20181123_203940 by robert noonan, on Flickr
Image20181123_203950 by robert noonan, on Flickr
Image20181123_213117 by robert noonan, on Flickr
have a good one
krusty
DoubleDigit12
Post by DoubleDigit12 »
Brush is the right idea I think mate!
James
krusty69
Post by krusty69 »
that's the way i'm leaning. got it primed tonight will shoot the base coat after work tomorrow, and then do some experimenting on the belly Monday to see how the paint performs with a brush
thanks bob
DoubleDigit12
Maybe you could spray the brown colour then brush paint the green and beige to avoid buildup?
James
TheNordus
Post by TheNordus »
Have you considered silly putty or masking putty? Either that or Tamiya's masking tape for curves.
-Tommi
krusty69
Post by krusty69 »
DoubleDigit12 wrote: Sun Nov 25, 2018 3:27 pm Maybe you could spray the brown colour then brush paint the green and beige to avoid buildup?
I'm worried about he lighter color covering the darker ones, the paint say's optimized for airbrush.
got the base coat on tonight, first time using hataka paint mixed about 50 50 with leveling thinner. shoot fine, good coverage. tomorrow will spray part of the bottom with the brown, and then brush the edge to see what happens.
Image1543191349850 by robert noonan, on Flickr
Image1543193832326 by robert noonan, on Flickr
Image20181125_175807 by robert noonan, on Flickr
thanks
krusty
krusty69
Post by krusty69 »
TheNordus wrote: Sun Nov 25, 2018 5:04 pm Have you considered silly putty or masking putty? Either that or Tamiya's masking tape for curves.
I've had mixed luck with that tape, and I don't have any silly putty. I have tried some of the ammo of mig masking goo and did not have very good luck with-it. I think if I had some of Tamiya's sheet tape I could have tried that, so i'll put it on the list and try something new today
thanks
krusty
krusty69
Post by krusty69 »
finally got around to spraying some brown on the bottom of the hull. on the vertical I used a brush around the edge, while on the horizontal I painted over the entire section with a brush. just hitting the edge seem's to be the way to go. I did brush straight out of the bottle, i'm going to add a couple of drops of leveling thinner when I paint. should be spraying the brown tomorrow, and the green on the following night.
Image20181126_185541 by robert noonan, on Flickr
Image20181126_193509 by robert noonan, on Flickr
thanks for looking
krusty
krusty69
Post by krusty69 »
hi all sprayed the flat earth tonight. looks ok, will shoot the green tomorrow. quick thought about the paint. hataka orange line lacquer, i'm curiously optimistic. it's my first time using it, mixes well with gunze leveling thinner, sprays well, dry's fast and the finish looks good, better than any acrylic that I've used and a lot of sets that no else covers. plus 17ml squirty bottles that include a mixing ball. down side kind of smelly, and can be kind of hard to find.
Image20181129_202306 by robert noonan, on Flickr
Image20181129_202315 by robert noonan, on Flickr
thanks
krusty
krusty69
Post by krusty69 »
sprayed the green tonight, color's look good, I think the paint tonight was a little to thick or the pressure was to high. got a bit (ok a lot) of overspray. not to worry i'll start brushing in the hard edge tomorrow. this model was painted light color first, followed by the darker colors. i'm thinking maybe I should have painted the darker first in this case. hard edge might have been easier brushing the dark color, I guess we'll find out this weekend :whistle:
Image20181130_202133 by robert noonan, on Flickr
Image20181130_202141 by robert noonan, on Flickr
thanks
krusty
krusty69
Post by krusty69 »
alright fella's went and brushed the hard edge tonight. mixed 7 or 8 drops of paint to 1 drop of mlt. these pictures were taken when the paint was wet, looked at it after a couple of hours and it looks way better. I don't see any brush marks. tomorrow I will airbrush to fill and touch up the camo then we will know if this worked. :scratch::
Image20181201_192914 by robert noonan, on Flickr
Image20181201_192924 by robert noonan, on Flickr
Image20181201_192928 by robert noonan, on Flickr
well until tomorrow
krusty
krusty69
Post by krusty69 »
all right that did not work :wall: . airbrush the center of the camo, got more overspray ty to touch up with a brush. a real catch 22. next try at this will be with tape. fixed it best I could, and gloss coated today, decals tomorrow. :tongue: . any luck the weathering will cover the brush marks.
Image20181203_092537 by robert noonan, on Flickr
Image20181203_092545 by robert noonan, on Flickr
thanks for looking
krusty
DoubleDigit12
Lookin good!
James
krusty69
Post by krusty69 »
thank's doubledigit
been working on the weathering added a wash, some light chipping, and have been trying some ak dust effects, well i'll guess we'll see how that comes out after a matt coat.
Image20181205_182845 by robert noonan, on Flickr
Image20181205_182920 by robert noonan, on Flickr
thanks for looking
krusty
krusty69
Post by krusty69 »
all right we are wrapping this one up. did some playing around with the tires, used enamel dust effects on one and pigments on the other I think the pigments are the way to go. dusted the lower part of the model with ak real paint mixed 50-50 with mlt, and then a dull coat with testers and mlt 50-50.
nice kit, somewhat obscure vehicle. screwed up the paint big time, brush and airbrush don't want to seem to play together. it looks ok from a foot away, any closer and it looks pretty bad. missing some detail paint ( waiting for paint). but i'm calling this one complete.
Image20181206_182607 by robert noonan, on Flickr
Image[url=https:/Image20181206_185707 by robert noonan, on Flickr/flic.kr/p/2ciBX1b]20181206_185628[/url] by robert noonan, on Flickr
Image20181206_185646 by robert noonan, on Flickr
thanks for following along
krusty
