1/48 Eduard SPAD XIII
DoubleDigit12
Post by DoubleDigit12 »
Hello,
welcome to my build of the Eduard SPAD XII.
Highly detailed kit including PE and masks.
Construction begins with the cockpit.
Only a little construction could be done before painting
After finishing the construction a layer of white Tamiya XF-02 white was used as a primer for the wood. A layer of black was also sprayed in the engine compartment.
After the primer was put down, a coat of yellow ochre oil paint was applied using a large flat brush to represent plywood.
After basecoating in wood colour, I then started to add details using Revell aqua paints.
I also used a MiG Brown enamel wash to highlight details.
Also during this stage I added all the photoetch dials to the cockpit and put a small drop of tamiya xf-22 clear to create a glass effect.
After that was completed, I created the photoetch seatbelts. This was quite a difficult task.
With the completion of the seat the cockpit was then stuck together. Unfortunately, the majority of this detail will be hidden after final construction.
Thank you,
James.
James
Timplastic
UN
Re: 1/48 Eduard SPAD XIII
Post by Timplastic »
Nice work James
Lovely work James :th:
Nice start - another good looking set of woodwork :th:
DoubleDigit12
Thanks guys!
James
Return to “Build Threads”
