Tamiya 1/48 Douglas Skyraider
kpisnuts
Post by kpisnuts »
Hi all well I've developed a bad habit of starting models and not finishing them(I get to a boring bit or a tricky bit, or it's just not going very well (like this one) and I shelve it)
Well I've decided this yr I'm going to try and restart, and who knows maybe even God forbid finish a few.
Well this one not being a subject im very good at got left as soon as the going got even slightly tricky, when I left off (The kit dose not have the option for landing gear up but that was how I wanted it, simple enough I thought) the landing gear doors would not shut properly so I valiantly struggled for about 5 mins then shelved it and gave up.
Well I've started it again and ive done my best with landing gear doors, had a go at doing the panel lines with a pin wash ruined it, stripped the paint off had another go, same result so this time I repainted it and tried my own idea I got some 600 grit and a piece of black pastel which I sanded over the wing I then rubbed it in with my finger, then wiped the mess off with a damp cloth, i am quite pleased with the effect.
I've added some weathering (probably not great as I know little about planes but I'm happy with how it's going)
kpisnuts
Re: Tamiya 1/48 Douglas Skyraider
Post by kpisnuts »
Next update, last one for a fortnight (holiday of a lifetime cruising the Caribbean)
kpisnuts
Post by kpisnuts »
Hi all here is the next update, i was fairly sure I would make a mess of trying to do the exhaust staining with the airbrush so I opted for doing it with a brush, i know it would be better with the ab but I'm quite pleased with how it turned out.
Looking good :th:
I like it!
Quax
Greenland
Post by Quax »
looks great so far KP :th: :th: I also hope you enjoyed your cruise?
cheers
A mess as usual...
kpisnuts
Post by kpisnuts »
Well got a bit more done on this.
smokeriderdon
Post by smokeriderdon »
Another option for doing gun/exhaust staining is to use dry pigments and a q tip. Just swirl the q tip in the pigment and and brush it on. Works really well. But you did a good job with the brush. :) I did this same kit. I also have the AF version in my stash. Its a great kit.
kpisnuts
Post by kpisnuts »
Thanks for the info, noted for future use.
kpisnuts
Post by kpisnuts »
Hi all another bit done.
