Tarangus 1/72 SAAB JA37 Viggen
TommyKillander
Post by TommyKillander »
Hey Guys!
I have waited a long time to build a SAAB Viggen in 1/72 scale and now it is finally going to happen ! 8-) :dance:
The individual I'm thinking of is this one, the 37378 (F4-38):
It entered service in 1984 at Frösön and was later moved to the missile test range at Vidsel, up north in Sweden. It still stands there on display.
I made a review of the Tarangus kit on my YouTube channel, so check that out if you want more detailed information.
Boxart:
Sprues:
Assembly instructions (with Errata sheet)
Paint and decal callout, Decals and clear parts.
I had some aftermarket for the old Heller kit that I'm considering to use on this kit.... :think:
Tommy
Re: Tarangus 1/72 SAAB JA37 Viggen
Nice nice...and you are keeping with your 2019 plan :thumb2:
TommyKillander
Twokidsnosleep wrote: Sun Mar 24, 2019 6:43 pm Nice nice...and you are keeping with your 2019 plan :thumb2:
Yeah, so far so good... :D
Tommy
TommyKillander
Okey Guys!
I've done some thinking.... My idea was to reuse all the aftermarket that I bought for the old Heller kit... But on second thought I will not do that :think:
Look at the difference in size between the kit part and the PE... :shock:
....and the bangseat :wtf:
I have a couple of resin BOY 401 chaff/flare launchers, but they where fitted to the Viggens at the end of the service-period so I will leave them out as well.
I will probably only use the turned metal pitot tubes and the masking sets as it looks right now ;)
The kit parts look great by the way, so I'm not too worried about making a "almost" OOB-build...
:geek:
Tommy
TommyKillander
Let's begin the build!
...and put the sprue-cutter into action
The radar-handle is Tiiiiny.... :shock:
Added the sidepanels in the fuselage
And I started to dryfit the air intake funnels
It looked better than I thought it would do actually...
I will continue checking the rest of the fuselage tomorrow ;)
Tommy
TommyKillander
Hello,
I have continued with some more dryfitting today.
The fit is not Tamiya-grade, but the parts will fit together nicely with some TET and clamps.
The JA37 version of the Viggen was 13 cm longer than the other versions due to the increased length of the RM8B engine. And since Tarangus wants to reuse the toolings for upcoming versions, there is a 2mm "ring" that fits between the front and rear part of the fuselage.
Read the instructions so you use the right one - both parts are included in the kit ;)
Wings looks nice and it is quite easy to cut the elevons and make them drooped.
It sure looks like a Viggen
Tommy
You are smoking along on this build
Great work, tiny pieces!!!
Looking forward to this, I do like the pre 90s jets :th:
TommyKillander
Twokidsnosleep wrote: Wed Mar 27, 2019 8:53 pm You are smoking along on this build
Kevthemodeller wrote: Wed Mar 27, 2019 10:25 pm Looking forward to this, I do like the pre 90s jets :th:
Thanks guys!
Tommy
I love the Viggen (and the Draken) and have been so tempted to pick up one of these.
Really looking forward to seeing you work you magic on it Tommy :pop:
TommyKillander
Tomcat64 wrote: Fri Mar 29, 2019 11:26 am I love the Viggen (and the Draken) and have been so tempted to pick up one of these.
Thanks Neil :)
If you want to build in 1/72 scale this is the Viggen kit you want to get. For a Draken the Hasegawa kit is the best option.
Same goes for 1/48, but if you can get your hands on an Eduard Draken, don't hesitate - great value for money with all the aftermarket that is included and it has a boxart to kill for ;)
I know that I kinda tagged this one for the Scandinavia SIG but one of my IPMS fellows started a 1/48 Tarangus JA37 and I got seduced... :crazy: :shifty: :lol:
I'm sure that I can come up with something else if the Scand SIG goes live :dance:
Tommy
TommyKillander wrote: Fri Mar 29, 2019 5:58 pm
Thanks Neil :)
Tommy
Thanks Tommy :th: I've got the Eduard Draken lurking in the stash so I'm definitely going to try and get the Scandinavia SiG off the ground for the second half of the year :)
TommyKillander
Tomcat64 wrote: Fri Mar 29, 2019 6:13 pm
Thanks Neil :)
Tommy
Lucky Lad 8-) I remember now, I think you have mentioned before that you have one in the stash.
Okay... weekend... lots of stuff to do that didn't happen during the weekdays and also prepare for next week :crazy: :bash:
But I got some quality time at the bench today, go figure... :lol:
First of all, primer on!
Now.... what colour should I choose for the cockpit. Paint callout says H308, but I think it has too much blue... :think:
Decided to go for the XF-80. I think it looks better
Let's put som paint on the bang seat
I decided to skip the PE seatbelts and make my own from thin strips of Tamiya masking tape
Now it's time for the tricky part.... :shifty: :? painting the details on the sidewalls and IP.... There is no decals in the kit for the IP, unfortunately.
The details for the knobs and dials was so small so I basically had to drybrush the details using black paint.... I couldn't pick out the details - even if I was using a 000 brush. Hopefully the washes will hide the lousy paintjob :tongue: :bash:
Finally I drilled some holes for the fuselage pylons and a "rat-hole" for the RAT (ram air turbine). In contrast to many other aircraft, the RAT is always released during landing so a Viggen on the ground should have the RAT deployed.
Tommy
TommyKillander
Hey Guys!
I had a thought about painting the MFDs, but masking and spraying a 2x2mm square seems ridiculous.. So I took some left-over decals and cut out a couple of black squares.
I also added some stencils with white text for the black HUD projector housing.
Weathered the cockpit parts...
...and glued it in place
Next up is the air intake funnels. There a a couple of ejection pin marks to take care of
There are also some release-marks on the inside
But after som sanding the fit is acceptable; but it will require some filler and sanding anyway
So let's glue them together ;)
Tommy
TommyKillander
Love this airplane and its camouflage. Doing well so far, nice cockpit. Can't wait for the next update.
Ben
Very nice detail work there mate :th:
TommyKillander
DRUMS01 wrote: Tue Apr 02, 2019 2:26 am Love this airplane and its camouflage. Doing well so far, nice cockpit. Can't wait for the next update.
Ben
Thanks, yeah it's a great looking aircraft :)
Kevthemodeller wrote: Tue Apr 02, 2019 7:19 pm Very nice detail work there mate :th:
Thanks Kev! :)
Tommy
TommyKillander
Oki-doki...
Short update today ;)
I have sanded the intake funnel now until I got a decent result. The final work needs to be done after the airscoops have been fitted, because there will be a couple of seams to deal with there too...
Speaking about the airscoops... They have a couple of small supports that I have decided to add as extra detailing.
I have drilled a 0.38 mm hole and I'm using guitar-wire (gauge #009).
Stay tuned
Tommy
Stunning work as always Tommy - I never cease to be amazed how much detail you can cram into a 1/72 cockpit!
TommyKillander
Tomcat64 wrote: Thu Apr 04, 2019 5:07 pm Stunning work as always Tommy - I never cease to be amazed how much detail you can cram into a 1/72 cockpit!
Thanks Neil, you're very kind :)
The office is basically OOB - kit is really nice and it has some really nice details, so I haven't done much improvements.
Tommy
TommyKillander
Hello!
It's been a lot of activity at the bench this weekend - great stuff! :thumb2:
Some primer on the stuff that needs to go into the fuselage before we can glue it together
Some metal shades
The wheel wells has some parts painted in olive green
The RAT-nest
The inside of the "extension-ring" need to be painted as well... bummer, I missed that :bash:
Done!
Ok... let's have a look at the rear end of the aircraft... :think:
Thrust reverser and reheat chamber
The guys at Tarangus have done some funky engineering here... :shifty:
The rear end of the afterburner has some variable geometry "feathers" but the moulding is quite weak, so I will try to improve them.
The feathers are cut from 0.25 mm styrene sheet using my Silhouette Portrait
Hope I can pull this off.... Wish me good luck :shifty: :?
Tommy
Superb attention to detail Tommy :th:
TommyKillander
Kevthemodeller wrote: Sun Apr 07, 2019 12:09 pm Superb attention to detail Tommy :th:
Thanks Kev :D
Ok... million dollar question... what the heck is this!? :wtf:
It's nothing that belongs on a Viggen... that's for sure :crazy:
Let's fill the cavity with sprue-goo and let it rest for a couple of days, before I sand it flush.
After fiddling with those tiny pieces of plasticard for a while, I decided to cut a strip that I will use as the first layer.
But, before I can proceed with that delicate stuff I had to do some more radical work with a saw...
...and while doing that I realised that I forgot to add the extra actuators for the elevons that the JA37 has :bash: :oops:
....yeah, I should have done that before I cut the control plane :roll:
Ok, I thing we are back on track again...
Let's add some details to the IP cover - defrosting pipe for the windshield and an optic sensor to adjust the brightness of the HUD
And we have the glass of the HUD-projector and the HUD itself
Next step is the windscreen and masking
I think we are ready to close up the front fuselage now! :dance:
Tommy
TommyKillander
Okey... short update;
Glued the front fuselage together... it was as easy I thought it would be - I basically had to hold 4 pieces and apply pressure while applying glue :crazy:
I couldn't get rid of the seams, so there will be some filling and sanding work :roll:
But I also managed to glue some random stuff together... ;)
I will let the nose cone and centerline tank cure for a day before I start sanding and polishing.
Tommy
Nice details Tommy :clap:
She is looking great :thumb2:
Wow that's come along nicely since the last time I had chance to drop in.
Stunning attention to detail as always Tommy - great to watch it come together.
TommyKillander
Twokidsnosleep wrote: Wed Apr 10, 2019 6:45 pm Nice details Tommy :clap:
Thanks Scott :)
Tomcat64 wrote: Fri Apr 12, 2019 11:25 am Wow that's come along nicely since the last time I had chance to drop in.
Thank you Neil :)
Tommy
TommyKillander
Ok!
I spend most of yesterday in bed with a flu, but today I feel better an I was able to get some stuff done... :tongue:
I have added the details for the variable geometry nozzle in the afterburner
I have also sanded down and polished the strange detail on the outside of the thust reverser
And glued the two lower thrust reverser petals in place The top one will be hanging down
Painted some Pale Burnt Metal tones as a basecoat for the weathering.
Tommy
TommyKillander
Hello!
I did some testing weathering the Burnt Pale Metal and it was too light, so I decided to spray another coat with a darker tone:
I also did some experimenting with masking sprue goo :wtf:
I have no idea if this will work - but if it does it will make sanding and rescribing much easier... :whistle:
Tommy
TommyKillander
Hello!
Weathering of the engine and trustreverser parts done and everything is sealed with flatcoat.
And the sprue goo adventure continues.... :scratch::
Tommy
TommyKillander
Hello!
Tommy
jmurphy18
Post by jmurphy18 »
That looks great so far Tommy! Nice fit. Now if it just takes tape for the build I am your man after all the taping I have done over the last 2 days :o :lol:
John M
TommyKillander
jmurphy18 wrote: Thu Apr 18, 2019 11:49 pm That looks great so far Tommy! Nice fit. Now if it just takes tape for the build I am your man after all the taping I have done over the last 2 days :o :lol:
I sometimes consume insane amounts of masking tape for my builds, but if thats the only way to make sure that I don't destroy my paintwork with overspray - so be it :)
I'll get in contact with you when it's time to mask the splinter cammo :crazy: :D :lol: :lol: :lol:
Tommy
JonMW
Post by JonMW »
Looking really nice so far!
jmurphy18
Post by jmurphy18 »
TommyKillander wrote: Fri Apr 19, 2019 8:17 am
Tommy
I do understand I have some tape I do need to throw away as it does not seal right but I just cannot bring myself to do so as I just bought it. It was a “bargain” on Amazon when I could not get the Tamiya for 5 weeks.
My wife caught me taping brake rotors so I could paint them 3 different colors. They are the size of a nickel or ~ 2.5 cm :tongue:
LOL on your taping. Just have some fresh coffee :)
John M
TommyKillander
JonMW wrote: Fri Apr 19, 2019 9:45 am Looking really nice so far!
Thanks Jon! :)
Congrats to your prize for your beautiful Volvo at the 08 Open show - great job! :thumb2: :clap:
jmurphy18 wrote: Fri Apr 19, 2019 12:36 pm I do understand I have some tape I do need to throw away as it does not seal right but I just cannot bring myself to do so as I just bought it. It was a “bargain” on Amazon when I could not get the Tamiya for 5 weeks.
:lol:
I'm like that too... I'll be damned if I even have to consider to throw away stuff that I have bought for my hard earned money... :mrgreen:
Tommy
jmurphy18
Post by jmurphy18 »
thanks
John M
Wonderful work Tommy!
TommyKillander
bfrd wrote: Sat Apr 20, 2019 4:27 pm Wonderful work Tommy!
Thank you very much, Matt :)
Okey... I have been concentrating on the main wheel wells today - I was planning to leadwires and stuff but then I remembered that the gear bay doors are almost closed on the ground, so I skipped that :shifty: :shock:
The compartment are painted in different metal shades and olive green.
(yes, I suck at brushpainting....) :oops:
I also decided to remove the strange triangle-shapes on the outside of the thustreverser.
Tommy
TommyKillander
Hey Guys!
Short update ;)
I have weathered the main wheel bays and flat-coated them.
It's the first time I used GX-113 and it performed perfectly (I thinned it with MLT)
...and I glued the rear part of the fuselage and main wing together :banana:
Tommy
TommyKillander
Hey Guys!
Time for a vlog update!
Tommy
TommyKillander
Hello!
Did some small stuff to get some variation from all the filling sanding and buffing that is going on right now... :shifty:
Added the AoA-probe and some noseweight - instructions says 5g but this is probably more than that :whistle:
Back to the saltmines of scale modelling - filling and sanding :crazy:
Tommy
TommyKillander
Hey Guys,
It's been a while since I sat down at the bench - been travelling and working and fixing stuff in the house the last weeks :tongue:
But now I'm back ;)
OK, the airbrakes on the Viggen are only extended when they are used. Unfortunately the fit is really bad... :wtf:
So we have to add a couple of shims to add more material
Decided to paint the inside of the airscoops/funnels - it's not a perfect job - but it will have to do :?
The navigation lights are really tiny and it is difficult to position them. So I took another approach - I used CA-glue as a filler and sanded and polished it into shape ;)
Tommy
very nice work so far Tommy! looking good :th: :th:
TommyKillander
chief5437 wrote: Sun May 12, 2019 12:32 pm very nice work so far Tommy! looking good :th: :th:
Thanks Chief, it's good to be back at the bench again ;)
Let's glue the fuselage together :banana:
Airbrakes for the underside - kit or PE ?
Think I go for the PE; not looking forward to drill out all those holes :shifty:
Bits and bobs on the fuselage
Tommy
TommyKillander
Hey Guys!
I decided to make a new gunbarrel from a hypodermic needle, so I ordered a set with different dimensions
Fitted the Oerlikon KCA 30mm gun pod.
I might have to trim the tip of the gunbarrel a bit :think:
Tommy
TommyKillander
Hey Guys,
Got some more done this weekend :D
Adjusted the gunbarrel a bit and also fitted the navlights on the top and bottom of the fuselage
Drilled out the vents on the side of the fuselage
I will replace the pitot tube on the tail fin with a turned metal part
It's looking more and more like a Viggen 8-)
I decided to scratchbuild the rear radar warning receiver from a bit of the sprue-tree and some 0.75 mm styrene rod
Now it's time so clean up all the small parts left in the kit and prepare them for painting :dance:
The plastic nipper is perfect for cleanup like this
Unfortunately one of the torsion links got damaged
Tommy
Awesome work Tommy - absolutely loving all the extras you're packing into this :clap: :clap: :clap:
TommyKillander
Tomcat64 wrote: Mon May 20, 2019 12:00 pm Awesome work Tommy - absolutely loving all the extras you're packing into this :clap: :clap: :clap:
Thanks Neil :)
I got some inspiration from a couple of Swedish build-threads where they went "all-in" on the detailing. Those where 1/48 scale builds but some of it are easy to transfer to the 1/72 scale.
It's a bit sad but there is not many preserved JA37 Jakt-Viggen, so it's really hard to find good walkaround photos.
Tommy
