Bandai 1/72 Tie fighter
Post regular build updates here :)
gaz45
Post by gaz45 »
This will be my entry
This will also be my first Bandai kit
gaz45
Re: Bandai 1/72 Tie fighter
Post by gaz45 »
With first test fitting the cockpit parts it appears to me to be a snap together kit is this the case has i have not built one of these kits before.
gaz45 wrote: Thu Jun 13, 2019 12:34 pm With first test fitting the cockpit parts it appears to me to be a snap together kit is this the case has i have not built one of these kits before.
Yep - as far as I'm aware all the Bandai Star Wars kits are snap-fit but I've always used a touch of glue as well on all of my builds to reinforce the bond.
Looking forward to seeing how you get on with this one as I have one lurking in my stash too.
gaz45
Post by gaz45 »
Thanks Neil
Good choice love a tie fighter and bandai kits are very well engineered to be an excellent fit but I use glue just as reinforcement
Dan
gaz45
Post by gaz45 »
Cheers dan
gaz45
Post by gaz45 »
Right here we go
The cockpit has been built and the inside has been primed in Ultimate grey primer and painted with Tamiya xf-66 light grey and once dried the stickers were added.
The figure was primed in Ultimate black primer and painted in mr hobby h-2 black with chrome silver x-11 detail
This was then put together and the outer hull was added.
Then primed in the grey primer and painted in the xf-66 light grey.
Then i painted a couple of the parts in xf-53 neutral grey but this was not a dark enough contrast so in the end i used xf-63 german grey.
To finish this section i primed the solar panels in the black primer and then i thought i would paint these in revell 09 anthracite which i had already thinned from a previous build ( waste not want not)
That's all for now thanks for taking a look and for your comments.
Super cool :thumb2:
I can hear that howling through space now :twisted:
Beltin start mate 👍🏻🤘🏻🤘🏻🤘🏻
