Tamiya Panzer IVJ late/final
Strohmann
Post by Strohmann »
Building Tamiya IVJ with late/final style features. So far I have Aber 35L48, Griffon Model L35A096 Exhaust set, Eduard 35595 Mesh Schurzen set, MK SK-27 tracks, and a LionMarc MG barrel for the bow machine gun.
Re: Tamiya Panzer IVJ late/final
Going all out and dressing up the old gal sorting out which pedigree she is. :th: :th: :th: :cheers2:
Strohmann
Post by Strohmann »
digger303 wrote: Sun Jul 21, 2019 4:05 am Going all out and dressing up the old gal sorting out which pedigree she is. :th: :th: :th: :cheers2:
Yep, time to get out the JLC saw and the putty.
The gunners view thingy left of the gun has to go and the bow plate needs to be cleared. I stole the late style hull extenders from an old 90's Dragon kit.
jmurphy18
Post by jmurphy18 »
very cool build! Looks like you are planning some custom work
John M
Strohmann
Post by Strohmann »
jmurphy18 wrote: Sun Jul 21, 2019 3:38 pm very cool build! Looks like you are planning some custom work
Thanks. So far the hardest part was carving out the gun breech(?) to get the Aber barrel to fit.
Can't wait to get to the PE mesh armor. :- )
Strohmann
Post by Strohmann »
Finished sanding where the gunners view port was.
Then put the last bits on the gun barrel.
If you look closely you can just make out the blurry line between hobby and insanity.
Man that is small, what will they think of next. A figure removing lice !
alextheblue
Post by alextheblue »
Looking forward to seeing more of this one. Something tells me it's gonna really detailed! :th: :cheers2: :pop: :pop:
www.alextheblue.com
Strohmann
Post by Strohmann »
Got the turret together. Just needs sanding on the side of the gun recuperator housing and the top of the shurzen support hangers.
Next stop is probably the late version exhausts. My order of Gator's Grip glue should come soon. I'm thinking that might be less of a circus than CA glue.
Strohmann
Post by Strohmann »
Just finishing the tracks with the Super Power.
Strohmann wrote: Sat Aug 03, 2019 3:16 am Just finishing the tracks with the Super Power.
I'v the S version of glue..... I'm guessing that the SP is stronger ?
Strohmann
Post by Strohmann »
digger303 wrote: Sat Aug 03, 2019 4:21 am
Stronger? I'm not sure if it's much stronger than the blue capped one but it is faster. I can just dab a bit on the track pin or some small part with a small paint brush and it sets up fast and it doesn't melt any surrounding detail. It goes to 11.
Strohmann wrote: Sat Aug 03, 2019 5:21 am
Thanks
Strohmann
Post by Strohmann »
Hello again.
The polycaps in the drive sprockets were making them sit crooked so I had to do some surgery.
The Gator's Grip glue finally came. I tested it. The thin seemed weak but the normal works well.
So I started on the mesh skirts.
TheNordus
Post by TheNordus »
Looks like an exciting project. I've a set of modelkasten tracks for a panther and they look like a massive pain.
-Tommi
alextheblue
Great work! Some very nice detailing. Those skirts look fiddly! :crazy: :crazy: :th: :cheers2:
www.alextheblue.com
Strohmann
Post by Strohmann »
TheNordus wrote: Tue Aug 20, 2019 12:15 pm Looks like an exciting project. I've a set of modelkasten tracks for a panther and they look like a massive pain.
Those have the separate guide horns. :- )
Strohmann
Post by Strohmann »
alextheblue wrote: Tue Aug 20, 2019 1:52 pm Great work! Some very nice detailing. Those skirts look fiddly! :crazy: :crazy: :th: :cheers2:
I'm about half way through putting them together. I found that dropping them on the floor and swearing is good method to simulate battle damage and wear.
CygnusX1
Post by CygnusX1 »
Strohmann wrote: Tue Aug 20, 2019 4:03 pm I'm about half way through putting them together. I found that dropping them on the floor and swearing is good method to simulate battle damage and wear. :- |
that's usually the way most PE stuff gets built: plenty of swearing, a little bloodshed and maybe a burnt finger or two if you're soldering. :D
This build looks amazing so far though - reallly interested to see where you go with it.
Strohmann
Post by Strohmann »
The screens are done. The Loctite precision pen thingy was rather handy.
The late style exhausts are on. Kind of fiddly but it's done.
I got some wire for the tow cable as Tamiya just give you a piece of string.
That's all for now.
Strohmann
Post by Strohmann »
I put some plastic rod on the exhausts with gator's grip to start making the weld seams. I think I bought it by mistake a long time ago but the rods are thin enough for this task.
CygnusX1
Post by CygnusX1 »
Coming along nicely. Great work so far.
