Decanting Question
mse240966
Decanting Question
Post by mse240966 »
First time decanting Tamiya Spray Cans, and something unexpected happened. The straw got very cold, and the glass mixing jar to the point frost appeared on the straw. It was decanted at room temperature and the can has been left at room temperate. Is this normal?
Gary30
Re: Decanting Question
Post by Gary30 »
Sounds entirely normal, due to the propellant gasses in the aerosol.
Portfolio
Click here
Yep Gary is right, as the gases go from liquid to gas they adsorb energy from the surrounding atmosphere and become very cold even to the point of causing ice crystals to form. Lpg is commonly used as a propellant this expands 270 times in volume as it goes from a liquid to gas. It is a liquid only when under pressure.
mse240966
Post by mse240966 »
Cheer guys, makes sense now thinking of it.
mse240966 wrote: Mon Jul 22, 2019 12:46 pm Cheer guys, makes sense now thinking of it.
Yep all is good
DO NOT PUT A LID ON !!!
Not until all the bubbling stops inside or you will explode paint everywhere
Usually a couple hours until you can gently swirl and no bubbles but I leave overnight
