Too hot to spray?
mse240966
Too hot to spray?
Post by mse240966 »
First time with Tamiya Lacquers and Retarded Thinner. Had a nightmare, with paint drying on the nozzle, needle and colour cup.
In the UK today it is an unsual 29 degree. So is this too hot for spraying?
ForbesHutton
Re: Too hot to spray?
Post by ForbesHutton »
What was the humidity? That's more of a factor with paint than the temp.
mse240966
Post by mse240966 »
ForbesHutton wrote: Sun Aug 25, 2019 5:12 pm What was the humidity? That's more of a factor with paint than the temp.
Thanks for quick reply. BBC weather says 46% humidity.
ForbesHutton
A little bit too dry for spraying. I don't think you would want to run a humidifier at that kind of temperature, you'd end up with a humidex around 35 which would be very unpleasant. You could try a bit more thinner, or just spend the day at the beach waiting for better weather.
mse240966 wrote: Sun Aug 25, 2019 5:10 pm First time with Tamiya Lacquers and Retarded Thinner. Had a nightmare, with paint drying on the nozzle, needle and colour cup.
How much did you thin them
mse240966
Post by mse240966 »
Paul wrote: Sun Aug 25, 2019 9:26 pm
Thinned by at least 50%
mse240966
Post by mse240966 »
I think I have sussed it out. The Tamiya Thinner when poured into the plastic cup I used to mix paint and thinner, ate the plastic. Melted plastic was in the paint.
mse240966 wrote: Sun Aug 25, 2019 11:03 pm
Yep that could be your problem the cheap cups are rubbish
Paul wrote: Sun Aug 25, 2019 11:05 pm
Yep however if use the cups intended for laboratories or medicine cups they are generally ok.
