Restoring Old Models -Will Glue hold Styrene to painted part?
RobRomero
Post by RobRomero »
I’m restoring some old models a friend has left me. Can I glue plastic to other plastic parts that have paint on their surface?
Thanks
RobRomero
Re: Restoring Old Models -Will Glue hold Styrene to painted part?
Post by RobRomero »
I’m restoring some old models a friend has left me. If I glue plastic to other plastic parts that have paint on their surface will it hold up well?
Glue to paint is a bit iffy bud
What kind of cement are you thinking of using??
RobRomero
Post by RobRomero »
I'm using IPS Weld-On 16 Acrylic Plastic Cement (recommended by someone on this site as superior to Tamiya glue for restoring old models).
RobRomero
Post by RobRomero »
RobRomero wrote: Thu Sep 05, 2019 10:45 pm I'm using IPS Weld-On 16 Acrylic Plastic Cement (recommended by someone on this site as superior to Tamiya glue for restoring old models).
PS I'm finding the IPS Weld-On 16 a bit runny and difficult to apply neatly -it does seem to make a stronger bond tho.
Ya that is a new one to me, plumbing supply product???
I would have used a Ca (cyanoacrylate) glue ="crazy glue"and activator or kicker to make it snap set
But then I would likely try and get a plastic joint as I scrape my painted areas free of cement. You might not have the luxury of doing that depending on location
The styrene cements (Tamiya extra thin, Testors, Revell )actually melt the plastic to each other to form their bond, so don't work well with paint in the way
Hope this is helping :scratch::
Return to “Glues and Fillers”
