Tamiya 1/48 Zeke - trying out a new pre-shading method
Nikola
New Zealand
Post by Nikola »
Hi gents,
This is my work in progress on Tamiya's older, somewhat simpler Zeke and my first 1/48 model. I am building it OOB with a closed canopy so not much excitement there.
However, I am trying out a new technique for pre-shading, which I borrowed from my experience in art, painting and colour theory, and which I call COMPLEMENTARY PRE-SHADING for now,
I used complementary colours of the base colour to pre-shade, aiming at more interesting colour variation and contrast. The base colour in this case is IJN Ash Gray, so the complementary colour for pre-shading is purple, Tamiya X-16 to be precise. I also primed the model in Vallejo Dark Yellow primer, this being the complementary of the pre-shading color.
This is more of an artistic than realistic approach, but I like to try and balance both in my models. The colors are much better in reality, but you all know that excuse, haha. Will have to wait for "proper" photos in the end. :)
Below are the results. I like it so far, looks promising. :)
You be the judges.
Maybe someone has done this before and if so, please share your experience.
Also, I could use some tips on weathering "Zekes" so those are more than welcome.
Thanks in advance guys! :)
Cheers,
Nikola
Nikola
New Zealand
Re: Tamiya 1/48 Zeke - trying out a new pre-shading method
Post by Nikola »
You can even go further when doing a "virtual light source" method (I don't know the proper name :)) and introduce "warm" colours for pre-shading "cold" base colors in areas which will be in shade and vice versa, "cold" pre-shading for "warm" ones. This is done in painting.
Will try that as well one day.
Best,
Nikola
MrBowcat
Post by MrBowcat »
Very nice. I did something similar recently on a F-14 Tomcat. Grey primer, black over the panel lines, then mottled blue in places finished off with the top coat of grey. It added some very nice variations.
Si vis pacem, para bellum
Nikola
New Zealand
Post by Nikola »
MrBowcat wrote: Mon Nov 11, 2019 12:32 pm Very nice. I did something similar recently on a F-14 Tomcat. Grey primer, black over the panel lines, then mottled blue in places finished off with the top coat of grey. It added some very nice variations.
Hi MrBowcat,
Thanks for your reply. Got any photos of the bird? Would like to see how it turned out :)
Thanks in advance!
Best,
Nikola
MrBowcat
Post by MrBowcat »
Hi Nikola,
It's still a work in progress, but this is it after the preshading
After the top coat
And how it is now after a clay wash.
Nikola
New Zealand
Post by Nikola »
MrBowcat wrote: Tue Nov 12, 2019 11:18 am Hi Nikola,
After the top coat
Hi MrBowcat,
Hey, that looks good! Thanks for sharing. Is it 1/48?
What is a clay wash? :)
Cheers,
Nikola
MrBowcat
Post by MrBowcat »
Cheers Nikola, yes a 1/48.
I used a Flory Models wash, which has a clay base. I believe the Ultimate washes are also clay based. Basically they allow you to coat the model with a wash, then when dry the excess can be removed with a moist paper towel or cloth. If sprayed or brushed over a matt or semi-matt finish (as I did) it not only stays in the panel lines but can also be used for dirt deposits on panels.
Nikola
New Zealand
Post by Nikola »
MrBowcat wrote: Tue Nov 12, 2019 12:32 pm Cheers Nikola, yes a 1/48.
Thank you very much for the info MrBowcat! Much appreciated.
Best,
Nikola
Very nice shadowing and panel detail. :th:
Nikola
New Zealand
Post by Nikola »
Kevthemodeller wrote: Mon Nov 18, 2019 7:41 am Very nice shadowing and panel detail. :th:
Thanks Kev!
How's the Fortress coming? I have the same one on the shelf waiting for me to have some more free time, haha.
Any ''heads up'' or advice on this bird?
Thanks in advance.
Best,
Nikola
Nikola
New Zealand
Post by Nikola »
Nikola wrote: Mon Nov 11, 2019 10:47 am Hi gents,
You be the judges.
Cheers,
Nikola
Hi gents,
Just an update on the Zeke.
Almost finished. I decided to try and paint some of the markings instead of using decals. Turned out reasonably OK.
Need to finish the landing gear, the prop and the canopy, and Das Is It.
Again, my phone photos are terrible :) Also, I didn't remove the liquid masks from the wheel wells so they are visible.
The model needs some touch ups overall, but it turned out OK.
Thanks for looking!
Best,
Nikola
Nikola
New Zealand
Post by Nikola »
Hi guys,
Finally, here is the link to the finished model:
viewtopic.php?f=34&t=27908&p=340768#p340768
Thanks for looking!
Best,
Nikola
