Mold line remover
Mold line remover
This is basically a scraper. The blade is quite thick and stiff and has been flat ground to give a nice sharp edge. However they used a rather course stone to achieve that. I may try to flatten that a little more with a selection of finer stones.
It does what it says it will do and does it a bit better than using a hobby knife. I guess it would be about 25% better than a hobby knife. So is it worth it ? At $17 aud I believe it is as it is a long life item and makes clean up quicker.
MrBowcat
Re: Mold line remover
Post by MrBowcat »
I bought one of those, and it does a very good job. The only issue is on small parts, or hard to reach areas it's too fat to get in. I tend to still use a craft knife more often than not, but still a good tool to have in the box.
Si vis pacem, para bellum
Return to “Tools”
