stronger glue?
Meliodas2019
stronger glue?
Post by Meliodas2019 »
Hi All,
Wondered if anyone can give me any advice? I have been using Tamiya extra Thin cement for the few models I have started since I have come back to modelling
however recently some parts, with the lightess of touchs come off, so I want to ask for bigger pieces or pieces with minimum contact to the model, like cables on outside of a tank, should I use an alternative glue or am i simply not using enough glue?
Re: stronger glue?
Meliodas2019 wrote: Sun Jan 26, 2020 1:55 pm Hi All,
I find some plastics take longer or more glue to bond properly. Ca glue is a alternative.
Meliodas2019
Re: stronger glue?
thanks digger :th:
Return to “Glues and Fillers”
