Thinning Tamiya TS paints?
PeterW
Post by PeterW »
Morning,
So I have decanted my Tamiya TS-7 paint (successfully) and applied it via the airbrush directly to the model.
It was a bit of a struggle adjusting the airbrush and it felt as if it was struggling to get through (the nozzle was wide open).
I kept layering the paint in what seemed to be very thin layers, as it just wasn't coming through effectively.
Consequently the finish is a bit dodgy and seems to have the dreaded 'orange peel' effect, and a bit rough to the touch :(
Should I have thinned this decanted paint? Is that what is normally done? If so what type of thinner, I presume the usual Ultimate stuff may not be suitable. Do I need a lacquer thinner?
There may be many more these posts in the near future :D
Peter
onemanclapping
Ireland
Re: Thinning Tamiya TS paints?
Post by onemanclapping »
Hi Peter
I have followed Paul's advice on this and thin it with approx 10% Tamiya lacquer Thinner with Retarder.
PeterW
Post by PeterW »
onemanclapping wrote: Wed Apr 01, 2020 9:54 am Hi Peter
Hi OMC,
The Tamiya recommended proportions are slightly different, but I'll definitely be taking that advice next time. Thanks. It's on order :)
Not sure if I can face stripping the new paint back, any ideas? I read some strippers will damage the plastic?
Peter
SteveNoble
Post by SteveNoble »
You don't need to strip the old paint off if it's a little rough. Just sand it out with fine wet and dry 1000, 1200 even 1500 used wet and respray over the top when you have the appropriate thinner..
