First model in 20 years, 100% hand painted
MB13
Post by MB13 »
Hi guys, so I'm back in the hobby after about 20 years, unbelievable how the hobby have changed in those years can't believe it! There is an air force base near where I live so I see F/A-18 almost every day so I decided to go with the Revell 1/48 F-18 to start it off. I did not want to wheter it too mutch as I think the ''too pronunced panel wash'' makes it kind of cartoonish and unrealistic, so went with another technique. I also don't own an airbrush so I did the best I could with what I saw on the net and here is the result, the ones I did back in the days where not near as good as this one but it's still not as perfect as I would have liked so I have some questions:
1- What technique do you use to hand brush your models (For those who still do it lol) Primer or no primer, thin the paint a lot or not that much, what brush to use.. etc
2- Do you have some tricks or anything else that helps for filling, sanding, wheathering etc..
3- I'm hopened to criticism so any tips or advice or anything on everything that could help would be much appreciated!!
Thanks!!!!
P.S. 1 Don't know why but thw dots of the weathering show a lot more on the pictures compared as in real life, kind of strange
P.S. 2 The next one is already on the bench :)
KalebB
Re: First model in 20 years, 100% hand painted
Post by KalebB »
Great looking build! Even after 20 years youve definitely still got it :th:
Whether hand painting or Airbrushing, it's always good to prime everything first imo. Helps with paint coverage and adherence :cheers2:
MB13
Post by MB13 »
KalebB wrote: Fri Apr 03, 2020 5:25 am Great looking build! Even after 20 years youve definitely still got it :th:
Thanks Kaleb! I think I will not take chances and prime everything as you said loll thanks!
:thumb2: Looks good to me and nice finish. I see your using Vallejo which has been designed for brushing so stick with that until your ready to tool up a little more :th:
That's very cool, you've lost no skill in the last 20yrs :th: :clap:
Very nice work, great paintwork and finish.
Great work especially with a brush. What brand of paint are you using ?
:th: :th: :cheers2:
MB13
Post by MB13 »
Thanks a lot for the kind words guys I appreciate it!! :D
DIGGER303 I went with Vallejo because I red good things about this brand so went with it, I think they do a good job, but I discovered that brushing the AIR doesn't give me good results compare to MODEL so I only use Model now.
