Bemax Lancia Delta S4 build.
This will be my 1st Bemax kit :eeek: and is the 86 Monte Carlo rally version. The kit comes in white styrene and Paul did a review of the kit here:-
The kit has a full interior and the finished model can be displayed with the front and rear sections in place or off the main body. Ialso have the dedicated upgrade set for the kit.
ImageP4116885 by andrew purchase, on Flickr
ImageP4116887 by andrew purchase, on Flickr
:hi:
Gary30
Re: Bemax Lancia Delta S4 build.
Post by Gary30 »
Yes Hawk! This was going to be one of my next kit purchases, I can't wait to see you smash this one out of the park as well, good luck with it buddy
Portfolio
Click here
Gary30 wrote: Sat Apr 11, 2020 6:21 pm Yes Hawk! This was going to be one of my next kit purchases, I can't wait to see you smash this one out of the park as well, good luck with it buddy
:cheers2: Thanks for looking in and your comments Gary :thumb2:
Mpfiend
Post by Mpfiend »
Looking forward to this one,
Keith.
Regards,
Keith
Cars now too? Very cool.
:cheers2: Thanks for looking in and your comments Both :thumb2:
:banana: :banana: The build starts with the engine some carbon decals from the upgrade set and also the Arbarth decals added then the turbo/intercoolers ect were added to the engine completing this mini assembly [sorry forgot to take pictures] The inner body shell is prepped and painted then some more decals from the upgrade kit added.
The engine assembly is added to the body shell then the side panels and running gear was placed in position lastly today the screen that separarates the engine and driving compartment was added.
Some of the parts need a good clean up before paint but nothing too bad. When assembling the rads to the engine block add the rads first then add the turbos and other pipe work otherwise it can become very fragile until the glue sets.
ImageP4126929 by andrew purchase, on Flickr
ImageP4126932 by andrew purchase, on Flickr
ImageP4126935 by andrew purchase, on Flickr
ImageP4126937 by andrew purchase, on Flickr
ImageP4126938 by andrew purchase, on Flickr
ImageP4126940 by andrew purchase, on Flickr
:hi:
jchrisf
Post by jchrisf »
Already looks like a work of art. What color is the tub and also the calipers and heads? I love that metallic look.
Chris
Next Build: ?
jchrisf wrote: Sun Apr 12, 2020 8:04 pm Already looks like a work of art. What color is the tub and also the calipers and heads? I love that metallic look.
:cheers2: Thanks for looking in and your comments I will try to answer your questions below.
The tub was first coated in semi gloss black then given a coat of Alclad aircraft aluminium. The head was given a coat of gloss black and again a coat of aircraft ali just by changing from semi gloss black to full gloss black can change the tone of the metal finish and I have been using this technique for a while now. The pipework is mostly Tamiya burnt iron with alclad highlights on parts as needed.
The calipers were painted with Vallejo's liquid metal range these are alkahol based paints but they again give a different tone of silver just to break up the overall effect that using the same silver paint on everything sometimes just washes everything out. Also the calipers have etch disc inserts these were just left natural and given a coat of gloss clear to seal them after fitting.
Hope that helps.
Andy :thumb2:
jchrisf
Post by jchrisf »
Hawkmoon wrote: Sun Apr 12, 2020 11:18 pm
Hope that helps.
Andy :thumb2:
Thanks Andy! I'll be getting those paints soon. Do you have a preference for your Gloss and Semi Gloss blacks that you use under your metal colors?
Chris
Next Build: ?
jchrisf wrote: Sun Apr 12, 2020 11:46 pm
Hope that helps.
Andy :thumb2:
:cheers2: I never use Alclad's gloss black undercoat anymore had the dry sticky and not go off syndrome once to often with the darn stuff :eeek: :eeek: . So I generally use whats to hand which right now is Tamiya's semi gloss black be it the old one or the new lacquer type . The lacquer drys faster though. Again with the gloss black anything to hand as long as its a good paint it will work.
What I forgot to mention last night is how silver and many other colors can change from each manufacterer each one being a slightly different silver for instance so mixing a couple up in a build can actually enhance the model as it makes it more life like. If you look at engine pics in race cars the aluminium used has different colors/hues according to it being cast or machine finished so throwing in some different silvers is good. :thumb2:
jchrisf
Post by jchrisf »
Hawkmoon wrote: Mon Apr 13, 2020 9:29 am
Hope that helps.
Andy :thumb2:
Thanks again Andy! I really appreciate it and will be following your builds. It is amazing the difference in the same Alclad color over different shades of black.
Chris
Next Build: ?
:banana: :banana: More done on the tub but 1st if your looking for a highly detailed build then this may be for you its crammed full of it.
The rear stiffener and upper cooling radiator was added next along with the steel air intake. Note that the intake is on the roof so deep fording if needed can be done
The tub so far deals with the rear of the car in this stage we start putting the front of the car together along with the suspension and running gear. As you can see from the pics the front chassis glues directly onto the rear with a central cover that goes over the four wheel drive running gear . This centre section is provided as a clear part so you can omit the carbon decal provided in the upgrade set and show off whats underneath. I opted to go with the decal.
More etch and decals were added as the build carries on but the last parts to go on today was the front rad and steering gear parts. :banana: :banana:
ImageP4136943 by andrew purchase, on Flickr
ImageP4136945 by andrew purchase, on Flickr
ImageP4136947 by andrew purchase, on Flickr
ImageP4136949 by andrew purchase, on Flickr
ImageP4136952 by andrew purchase, on Flickr
ImageP4136954 by andrew purchase, on Flickr
ImageP4136956 by andrew purchase, on Flickr
ImageP4136957 by andrew purchase, on Flickr
ImageP4136960 by andrew purchase, on Flickr
ImageP4136961 by andrew purchase, on Flickr
ImageP4136962 by andrew purchase, on Flickr
ImageP4136964 by andrew purchase, on Flickr
ImageP4136965 by andrew purchase, on Flickr
ImageP4136967 by andrew purchase, on Flickr
ImageP4136969 by andrew purchase, on Flickr
:hi:
:banana: :banana: The inner tub assembly continues with the addition of etch plates at the rear and the cabin being fitted out gear stick,brake handle and fire exstingisher. The seats come next having the upgrade set carbon added to the backs and seat belts and other decals added. Next the dash was painted and again decals added along with the two inner doors that also have decals added before being fitted to the tub. All that needs adding now is the roll bar and the inner assembly is done.
The outer body has been started removing seam lines and adding parts and etch. :banana: :banana:
ImageP4146979 by andrew purchase, on Flickr
ImageP4146984 by andrew purchase, on Flickr
ImageP4146986 by andrew purchase, on Flickr
ImageP4146988 by andrew purchase, on Flickr
ImageP4146989 by andrew purchase, on Flickr
ImageP4146991 by andrew purchase, on Flickr
ImageP4146994 by andrew purchase, on Flickr
ImageP4146996 by andrew purchase, on Flickr
ImageP4146998 by andrew purchase, on Flickr
:hi:
jchrisf
Post by jchrisf »
Wow @Hawkmoon !!! That is incredible!
Chris
Next Build: ?
jchrisf wrote: Tue Apr 14, 2020 6:14 pm Wow @Hawkmoon !!! That is incredible!
:th: Thanks for looking in and your comments Cris :thumb2:
Hell don't put the shell on just the tyres it looks the bee's knees you've knocked it out of the park there. :bow:: :bow:: :cheers2:
digger303 wrote: Wed Apr 15, 2020 10:35 am Hell don't put the shell on just the tyres it looks the bee's knees you've knocked it out of the park there. :bow:: :bow:: :cheers2:
:cheers2: Thanks for your comments Digger and taking the time to view the progress on the build :thumb2:
:banana: :banana: The roll bar has been fitted completing the inner tub assembly. Next any etch/parts that needed fitting was added to the three body segments and then the insides were given a coat of red paint followed when the paint was dry by a coat of gloss varnish. If your wondering why the red the bodys of these cars were made from GRP [Glass Reinforced Plastic] and thats just the color of the final gel coat added to the body parts in the mold. Tomorow holds lots of masking and the outer paint goes on ready for decals. :banana: :banana:
ImageP4157001 by andrew purchase, on Flickr
ImageP4157003 by andrew purchase, on Flickr
ImageP4157005 by andrew purchase, on Flickr
ImageP4157007 by andrew purchase, on Flickr
:hi:
jchrisf
Post by jchrisf »
Looking good @Hawkmoon ! You're my hero.. you builds go fast and you also build highly detailed race cars. I can't believe how fast you are moving through this.
Chris
Next Build: ?
Wilo
Post by Wilo »
This is looking amazing!!! Have one in the stash to build myself
jchrisf wrote: Wed Apr 15, 2020 7:26 pm Looking good @Hawkmoon ! You're my hero.. you builds go fast and you also build highly detailed race cars. I can't believe how fast you are moving through this.
:cheers2: Thanks for looking in and your comments Cris as for building fast time is a luxury I dont have right now due to health issues :thumb2:
Wilo wrote: Wed Apr 15, 2020 10:47 pm This is looking amazing!!! Have one in the stash to build myself
:cheers2: Thanks for looking in and your comments there very much appreciated :thumb2:
Awesome man!! This is looking great... not sure how I missed this one, but in for the finish. :thumb1:
That interior is really detailed and digging all the CF you've added.
barryf1fan wrote: Thu Apr 16, 2020 2:15 pm Awesome man!! This is looking great... not sure how I missed this one, but in for the finish. :thumb1:
:cheers2: For looking in and your comments Barry :thumb2:
:banana: :banana: Ok some white has gone down today starting with the wheels and odds n sods. The main body parts were masked up inside then the outers were given several thin coats of Zero white and left to dry. Once the masking was removed the insides were touched up with red where and if needed. The rear section had carbon fibre decals added to the wheel wells and the centre section had the black added along the bottom sides. Looks like it could be the start of the decals going on. :banana: :banana:
ImageP4167010 by andrew purchase, on Flickr
ImageP4167012 by andrew purchase, on Flickr
ImageP4167014 by andrew purchase, on Flickr
ImageP4167016 by andrew purchase, on Flickr
ImageP4167019 by andrew purchase, on Flickr
ImageP4167020 by andrew purchase, on Flickr
:hi:
jchrisf
Post by jchrisf »
Looking great Hawkmoon! You accomplish so much each day
Chris
Next Build: ?
Some very clean building going on here
Lovely work
Twokidsnosleep wrote: Fri Apr 17, 2020 3:49 am Some very clean building going on here
Lovely work
jchrisf wrote: Thu Apr 16, 2020 6:52 pm Looking great Hawkmoon! You accomplish so much each day
:cheers2: :cheers2: Thanks for looking in and your comments both. Its my 1st Beemax kit there is some clean up needed on seam lines and small amounts of flash in places but apart from that fit is not Tamiya but close on the kit I am building. :thumb2: :th:
:banana: :banana: The clear parts were masked off and the surrounds painted black. The decals have been added to the rally plates and to the car itself. The upper spoiler first had more carbon decals added then the logo. Should be ready for a clear coat tomorrow after a final check over. :banana: :banana:
ImageP4177023 by andrew purchase, on Flickr
ImageP4177025 by andrew purchase, on Flickr
ImageP4177028 by andrew purchase, on Flickr
ImageP4177030 by andrew purchase, on Flickr
ImageP4177032 by andrew purchase, on Flickr
ImageP4177033 by andrew purchase, on Flickr
ImageP4177035 by andrew purchase, on Flickr
ImageP4177037 by andrew purchase, on Flickr
:hi:
jchrisf
Post by jchrisf »
Looking good!
Chris
Next Build: ?
Love it!! And one of my favorite cars from Sega Rally Championship!!
Looking forward to the assembly, Hawk! :thumb1:
:cheers2: Thanks for looking in and your comments both :thumb2: :cheers2:
:banana: :banana: The wheel hubs have been clear coated and when dry the tyres went on and were fitted to the car. The main body was split into 3 parts, the front and rear body parts will be removable to view the engine and front suspension set up once finished. The three sections were then given a coat of clear coat and left to dry. :banana: :banana:
ImageP4187044 by andrew purchase, on Flickr
ImageP4187046 by andrew purchase, on Flickr
ImageP4187048 by andrew purchase, on Flickr
ImageP4187050 by andrew purchase, on Flickr
ImageP4187052 by andrew purchase, on Flickr
:hi:
jchrisf
Post by jchrisf »
That looks awesome @Hawkmoon ! I can't believe you can do that kind of detail so quickly. What color did you paint the wheels?
Chris
Next Build: ?
jchrisf wrote: Sat Apr 18, 2020 5:56 pm That looks awesome @Hawkmoon ! I can't believe you can do that kind of detail so quickly. What color did you paint the wheels?
Hi Cris
Thanks for looking in and your comments, the wheel hubs should all be white like the spare wheel finish but for extra brake cooling used on some stages they added a cast aluminium plate with vanes that pushed more cooling air like a fan over the brake disc's/calipers . This addition was easily placed on the car or removed just by undoing the basic wheel nuts.
The four main wheel hubs were assembled with the optional fan plates on them and then they were all sprayed white with the same color that the main body was sprayed with. Once dry the car road wheels with the cooling plates were given a sprayed coat of Vellejo Liquid silver this again shows how just by the base coat can change the hue of the same silver used with different base coats. Once dry the hubs were finished off with a clear coat.
Vallejo alcohol paints can be brushed but they give a better overall finish if sprayed with an airbrush there only drawback is the finish can be fragile to handling to prevent this I have found 2k clear coats give a protective coat to keep them pristine. The new Lacquer clears may also be good here too but that's something I am looking into.
Andy
:banana: :banana: Calling this one done, the kit has some clean up needed and some holes need opening out but nothing major. The after market set is a must if you want the mud guards and some other details that are easily seen missing on the finished kit.
ImageP4197073 by andrew purchase, on Flickr
Beautiful model, Hawk. Man, that thing built up beautiful (because of your mad skillz :bow:: )
I had never even heard of Beemax until I joined this forum. :lol:
And with this, and the Lancia Stratos being two of my all-time favorite rally cars, may have to invest in one of these.
Incredible job on this one though, I love that car and yours is perfect!
:clap: :clap: :clap:
Can't wait to see "What's next". :D
:thumb2: Thanks for looking in and your comments Barry :oops: Beemax are an offshoot of Aoshima kits but tend to have full interiors and better detail rather than there normal kerbside car kits :thumb2: :thumb2:
How have I missed this :crazy: Superb build mate :banana: :bow:: :clap: :clap:
You'v done it again a couple more like that and we'll have to knight ya ! Sir Plastic knight of the sprue.
:th: :th:
jchrisf
Post by jchrisf »
digger303 wrote: Sat May 30, 2020 2:25 pm You'v done it again a couple more like that and we'll have to knight ya ! Sir Plastic knight of the sprue.
:th: :th:
Sir Andrew Hawkmoon!!! I like it 8-)
Chris
Next Build: ?
:cheers2: Thanks for looking in and your comments everyone all are appreciated :cheers2:
