Hasegawa 1/72 Macrss VF-1D Valkyrie 'virgin road'
Johno
Post by Johno »
Here is my submission Hasegawa's 1/72 VF-1D Valkyrie 'virgin road' from the macross saga. Can't wait to dig into this, been a huge macross fan since i was a kid and max is definitely my favorite character and love the blue scheme on the valkyrie so this will be fun.
Moebius 1/32 viper mk. vii
Hasegawa 1/72 vf-1A/S/J
Airfix 1/32 WW1 B type 'Ole Bill' bus
:boom:
Re: Hasegawa 1/72 Macrss VF-1D Valkyrie 'virgin road'
:th: :banana: :pop: :pop: :pop: :banana: :th:
Johno
Post by Johno »
Here's the instructions
:boom:
Johno
Post by Johno »
Well i guess it's about time i give an update. So the build has been going well, i have benefited from attempting a different version of this kit before that ended up boxed because of some issues i was having with the seams on parts and it was only my second or third kit attempted so was having some rookie issues and it was before i discovered the wonders of sprue goo.
So the kit goes together in multiple assemblies that should be painted separately and than assembled because all the little hard to get nooks and crannies on the finished product.
First up was assembling and painting the cockpit and than putting together the fuselage. Then the magic sprue goo on the seams and sanded away
the various other assemblies went together well, including the internal mechanism the wings eventually attach to so they can fold and unflold that i unfortunately forgot to photo before closing up. Remembering to wait on putting on the tiny fins and such that go on the assemblies till the final step after all assemblies are done, just before painting. as i learned from the other version i attempted and spent as much time re-attaching and looking for broken off pieces as i did anything else.
the thruster/leg assembly is a bit more complex than the rest.
it required painting the thruster and fan parts before assembly. Did the thruster ends in tamiya burnt iron and some shinning silver on the fans then a coat of clear to protect the paint
then assembled, sprue gooed and a couple panel lines scribed crooked filled and scribed again, which is par for the course for me any time i touch a scriber. But the finished product ended up good.
so most the main assemblies are done except for the tail fin piece, which i have saved for last because it is pretty delicate once finished so i saved it for last in the assembly order. After that will be putting on the various tiny fins and such than on to prime and paint.
:boom:
Johno
Post by Johno »
So, let me tell you how it all went wrong. The painting started off well enough, primed them and they were ready to go.
then i decided to take a risk and mask and paint the white parts rather than use the decal, it did not go well for me. First i decided to make templates for the tape by scanning and printing the decal sheet and cutting out the shapes and using those to cut the shapes in tape it started off a pain, first realizing i had to flip the image cause the tape stuck too much to the front of the photo paper, then took me forever to figure out i had to save the image as a pdf to keep the exact size when printing of the image. Once i figured that out i was super excited cut the shapes stuck to the tape and cut and peeled and it all seemed like it was going to work. The i started by painting the white and this was the beginning of the end.Image
first off i got mission models paint cause i liked the mecha blue color they had and heard great things about the paint, at first everything seemed great, sprayed smooth, the coverage with the white was really good but then inspecting the paint the next day i noticed how soft the paint was when dry, almost powdery to the touch just accidentally hitting two parts together scratched the paint and just a rub of my finger on an edge rubbed the paint thin enough to see the primer underneath. I really don't think it was user error, i wore gloves every stage, used Ultimate primer which i know is great, kept the surfaces clean and smooth and used missions own thinner to spray with. So since the paint was so soft i didn't trust taping right on it, which may have been a mistake. I sprayed a thin coat of aqua gloss to try and protect the paint then taped everything off and here is the resultImageImage
basically every line was like this, now if you look close its not so much that paint bled under the tape, which it did in a little spot or two, its mostly that the paint lifted at the edges, and i even pulled the tape off super careful and pulled it off as soon as it was dry too the touch. Not sure if it was cause the gloss, or the paint, or some other dumb mistake of mine, but i am throwing in the towel and she is off to the bin, its heartbreaking but can't really strip it cause thing like the thrusters painted and built into the legs. I'm just done, this is my first officially binned kit, ive got a couple i have put aside for various reasons, have one from the wheeled vehicles gb i made a big mistake on but just put aside cause i can strip it but none i offcially binned till now. I am super bummed. I feel i need to do something dramatic to officially end the kits life and give me some sort of cathartic release, but am yet undecided on what that shall be.
:boom:
Well, that happens sometimes. I recently also binned my first kit. Felt much better after getting rid of it.
Johno
Post by Johno »
aur0ra145 wrote: Sun Sep 27, 2020 11:13 pm Well, that happens sometimes. I recently also binned my first kit. Felt much better after getting rid of it.
i'm with you there, just finally admitting defeat, after a moment or two of anger, felt good, I'm really excited now to finish a couple kits i've had sitting on the side while i tried to finish this one, its just a relief now to finally be over with it.
:boom:
