Polar Lights 1/1000 Refit Enterprise NCC-1701
Tankboy76
Post by Tankboy76 »
Up next for me is the smaller model version of the best starship named 'Enterprise'. While it is themed on the Star Trek 2 film and comes with 'battle damage' decals - I intend a clean build. I also got the aztec decal set - which cost as much as the kit, but contains the aztec decals for both this kit AND the Reliant kit (they should make this more clear)
I don't intend a perfect recreation of any film or particular filming model. Every movie had differences - even rewatching the Kahn movie before starting the kit - colors of details vary throughout the one film. (I understand the optical effects interacted a lot which subtly affected many colors making the filmed Enterprise different from the studio model). So - I'll paint it to my memory of the Enterprise.
I'm actually a little bit ahead of building to posting, I've got pictures all the way up to a clear coat before dealing I'll post while I'm letting the decals dry.
Re: Polar Lights 1/1000 Refit Enterprise NCC-1701
:th: Nice start and looking good :thumb2:
Tankboy76
Post by Tankboy76 »
This is a snap together kit - and about 1/2 of the kit was just snapped together with some cement around the seam to hold it shut and the other half had the snaps cut off and glued in place after a bunch of on/off and sanding to try and get the seams more consistent. I was partially successful. I was somewhat disappointed by the detail in the parts, but as the classic shape came together, I was happy regardless.
Just about every seam got 1-2 rounds of putty and a lot of sanding. The saucer came out best.
One half of the bottom module was much more warped than the other half - you can see the shiny bits after a light sand. The other part had no evidence of similar sink marks. Oh well - some practice for putty, sanding and primer.
The paint job was pretty straight forward. I finally have some confidence with the Mission Models paint, and especially the clear coat that I was struggling with. Below is Grey 1500 Mr Surfacer, then Light Ghost Grey Mission Models base coat, some detailing with mission models and masking, and a semi-gloss clear coat.
What I learned was: MMP recommends light wet coats - wet still means wet: I was putting too little paint down, and too slowly - like I was building up a lacquer base coat on a car, and was ending up with a textured finish. Turning the pressure up to get finer atomization did not help: more overspray and more dust. Solution: lower pressure and heavier coats applied as quickly as I can (using a full trigger pull on my 0.5mm needle). Just need to thin enough to prevent sputtering, which takes more than MMP recommends, but varies a lot from bottle to bottle. I think I knew this before this model, but this paint job came together the easiest for me.
I'm into the decals now. I'll post progress tomorrow. Prepare for something like 231 update posts to cover the never ending decals.
That's looking really good! I always have trouble with MMP, glad you're figuring it out, paint looks awesome.
I loves me a bit of Star Wars 😉 Good work so far 👍🏻
Tankboy76
Post by Tankboy76 »
Star Wars, eh. :scratch::
Anyways - there are a lot of decals, these are just the extra ones, that go one before the ones that came with the kit. There are 4 fulls size sheets, and 1 itty bitty one with 2 decals on it. There are decals for both the enterprise and defiant here, the enterprise uses over half the decals.
And they seems to go down well. They are a little thick so they don't tear when you squeeze the bubbles out, but the react very well to Microsol (the red bottle). A finish clear coat to smooth things out and a flat coat will be needed.
If I'm optimistic I'm a quarter done with the aztec decals.
That is some true patience with all those decals! :bow::
Very nice! Good job with the decals.
wow decals and paint ...top result :th: :th: :cheers2:
:th: :clap: :clap: Doing good on the decals and nice work :thumb2:
Tankboy76
Post by Tankboy76 »
The aztec decals are all applied. I think I mentioned it before, but these decals are pretty forgiving, at the trade off of needing patience to let the applied Mircosol work - a few applications are needed to keep the decal wetted before they settle in, and it was necessary to let the decals soften partially before doing the final press with a cue tip, especially into a panel line. The directions recommend cutting the decals along the panel line, I pushed the soft decals into the line with a small tamiya cotton swab.
This is the decal sheet that comes with the kit. Much smaller, but the individual decals are much smaller too - there are a lot of decals here. Luckily for me, I'm not using the damage decals, and a chunk of these are for the -A enterprise, so there are doubles. The backing sheet is a different color than the aztec sheets, but the decals seem to behave similarly.
The decal film is looking pretty shiny, so I'm looking forward to the final clear coats to smooth and dull the finish.
Great job on the decals!
BigWall wrote: Mon Jun 29, 2020 11:53 pm Great job on the decals!
:th: :th: :cheers2:
