Ism Friday's night live at the bench what have you been working on for **august 31st**
**Open now until 1 hour before the show on Friday, August 31st**
Re: Ism Friday's night live at the bench what have you been working on for **august 31st**
Still working on finishing the Colonial Viper Mk 1 off. I am building up the courage to have my first ever attempt at doing a wash to pick out panel lines etc using Vallejo Model Wash. The kit has had a couple of coats of Humbrol Acrylic Gloss coat that been allowed to dry a couple of days. All the parts are now on including the landing gear bay doors. The rear section with the engine thrusters is still dry fitted in case I opt to try the wireless power connectors @bfrd recommended.
    Work continues on the 1/24 Tamiya Beetle
    TS-60 sprayed and interior buttoned up, also a wheel and tire upgrade.
    Have a great weekend guys!!
    Evenin' young Dan/Paul (delete as applicable)
    This week I've made some more progress on Meng's 1/35 Wasp Flamethrower Jeep.
    I've started painting the jeep itself in various shades of Vallejo ModelAir Olive Drabs and have assembled most of the bits of the flamethrowing gear which are dry fitted for the moment. A few seamlines to deal with but an enjoyable build so far.
    Rugash
    Post by Rugash »
    Still working on these two, no work so far for the weekend so I should get a bit more done.
    20200821_194824 by Matthew Ashby, on Flickr
    20200822_212807 by Matthew Ashby, on Flickr
    Hello everyone! I hope everyone is doing well.
    I'm about done with my Tamiya 1/25 Brummbar. With any luck I'll wrap it up this weekend.
    ImageBrummbar 25 by Big Wall, on Flickr
    Howdy folks!
    I've been working on a Bandai 1/48 Snowspeeder for the Summer Sci-Fi SIG. Primed in Ultimate Matte Black. Painted in a mix of XF-19 and XF-2; no real ratio, just mixed it until it looked right. Orange bits were made in a similar fashion using XF-7 and X-6. Next up will be decals and weathering.
    Hope everyone has a wonderful weekend!
    Progress on my AMT cobra 289 remake
    Fitting the brass bits to the body: windscreen, gas cap and the headlights
    Happy weekend...next weeks is a holiday for me :banana:
    BOABModels
    Post by BOABModels »
    The Revell Shelby Cobra 289 FIA is finished! There are a few errors with this kit - in actuality it's a 427 body but I'm pleased with how it has turned out. It's also 1/24 rather than the 1/25 it says on the box.
    I chose to leave off the chrome bumpers and do the sidepipes in white to give it more of a race car feel.
    Cheers!
    Thomas
    Good evening amusing modellers
    Tonight we have a 1/72 Dewoitine D.9 made with a KP Skoda D.1 donor kit and conversion parts from the Dujin resin kit. The wings are painted in Tamiya LP-11 Silver, the fuselage in Tamiya AS-12 Bare Metal Silver and the engine cowling is in I-forget-what silver. The Swiss markings were made using Tamiya TS-19 Bright Red paint with white decals sourced from an Azmodel Morane Saulnier type G/H kit (which I’m making using the other decal options).
    1/32 F-15E Strike Eagle:
    Seam checking and flaps cut out. Inserts temporary until I can think of a better join for them (may have to remove more on the underside). Still enjoying it though :cheers2:
    Tankboy76
    Post by Tankboy76 »
    This past week I have started a 1/35th Miniart M3 Grant. I've never built a MiniArt or workable link track kit before - this is actually only the second tank kit I've started. I'm certain I didn't know what I was getting into - there are too many parts and the photo etch is too small :ooops: I guess I'll be learning a few things. The camo scheme I'll be attempting is in the background.
    WordenB
    Post by WordenB »
    Continued this week with my efforts to finish some reboxed kits, however this Tamiya 1/24 Mitsubishi GTO didn't go as well as the Land Rover last week.
    The body shell has been a bit of a test bed for paint and 2k but after some flatting and polishing looked good enough to complete. I masked and sprayed the black trim but that didn't go too well and whilst removing the masking tape I managed to peel off a patch of 2k and paint from the front wing. Not sure whether to try and redo just the wing or strip the whole shell and start again. Can't win them all, this one is again destined for the box!
    Thanks for looking and have a good evening.
    Magnifier 1/12 GT-40 is getting close to being finished. just some greeblys to fit and the final assembly left.
    ImageP8288268 by andrew purchase, on Flickr
    Moebius Models 1/4105 Battlestar Pegasus.
    Just started on this one (so now juggling two Battlestars and a Viper...) Primary hull and FTL engine is assembled as you see in the photo. Painting instructions called for a Dark Metallic Grey - so I have used Humbrol #53 Gunmetal over Tamiya grey surface primer. I think its turned out quite well. Its a brush finish in the photo and its actually a bit streaky in places so I may chance using the airbrush to see if I can get a more even finish once the other sub assemblies are added (engines, flight decks etc.)
      RangerNeil wrote: Sun Aug 30, 2020 11:08 pm Moebius Models 1/4105 Battlestar Pegasus.
      Hi Neil I've just posted the new thread for this week if you want to post this build in there mate 👍🏻
      Kingdan wrote: Wed Sep 02, 2020 6:10 pm
      Will do sir!! :)
