Filler
nova
Filler
Post by nova »
Hi , I'm a real newbie so please forgive me for asking something that has probably been done several times before.
What is the easiest way to fill sink holes in panels ?
What filler do yo use ?
Re: Filler
I use a product called perfect plastic putty, it's not perfect but is very forgiving and can be cleaned up with water or reactivated.
Sprue goo works too as does Ca glue mixed with a filler like talc. Ca gets hard to sand if you leave it too long. There are other products out there. Basically you want something that is easy to remove yet won't shrink when drying. The Tamiya putties are bad for shrinkage except the epoxy which you won't be using for sink holes anyway.
I find AFV Club kits seem to have more sink holes than other brands, but that could be just my bias as I'v been building a few of those lately.
:th: :th: :cheers2:
nova
Re: Filler
Post by nova »
Hi digger.
Thank you for your reply.
My 1st build was an italieri 1/24 escort which I completed recently. I would put a pic here but can't figure out how .
The bonnet and boot on this kit are far from perfect nor does the front spoiler fit very neatly .
I have another that I will build soon but now knowing these imperfections I want it to be better .
Re: Filler
nova wrote: Mon Nov 16, 2020 11:20 pm Hi digger.
Open up a Flickr account, load some pictures on it and then post up again. I'll walk you thru posting a picture on the forum.
nova
Re: Filler
Post by nova »
Hi Bigwall
Flckr done .
Hopefully ready for you to show the way .
Cliff
Re: Filler
nova wrote: Tue Nov 17, 2020 10:41 pm Hi Bigwall
Flckr done .
Cliff
Ok. Hopefully you are doing this on a computer because I'm not very phone savvy
Open Flickr in another tab.
Double click on the picture you want to post.
On the lower right, there is a curved arrow. When you hover over it, it reads "Share Photo." Click on that arrow.
A box pops up. On the right side of the top line, click on BBCode. Then on the new lower line, click on the arrow to open the dialog box and select the photo size. I usually do "Medium (800x450).
Right click the address in the middle line to highlight it and then left click it and select "Copy."
Now paste the address into your post and you've got it.
You can always click "Preview" at the bottom of the "post a reply" window to make sure your picture will show when you submit the post.
dogsbody
Re: Filler
Post by dogsbody »
I like Mr. Surfacer for that type of thing, especially Mr. Surfacer 1000. I use a round toothpick to put a drop or two where I need it. For bigger spots, I've used a piece of hollow tubing to get more out of the jar.
Surfacer dries fairly quickly and sands out easily.
Chris
"What young man could possibly be bored
with a uniform to wear,
a fast aeroplane to fly,
and something to shoot at?"
nova
Re: Filler
Post by nova »
Hi dogsbody . Thanks for that , will have to try and source some of that and give it a try .
Cliff
nova
Re: Filler
Post by nova »
nova
Re: Filler
Post by nova »
Hi Bigwall,
Not sure if that's how it's supposed to be .
Cliff
Re: Filler
nova wrote: Wed Nov 18, 2020 8:57 pm Hope this works.
[img][https://www.flickr.com/gp/191062028@N05/6046Dg/img]
When you copy the code it has to be from the " BBCode ''
I think you used the email code
Re: Filler
nova wrote: Wed Nov 18, 2020 8:59 pm Hi Bigwall,
Cliff
Something isn't right. The picture didn't show up. I'm not smart enough to troubleshoot it from there. Try messing with it a bit. The picture will show when you click preview if it's done correctly.
