Beginner here
cmclernon
Ireland
Beginner here
Post by cmclernon »
Hi All, I'm a beginner here (or rather havent done a kit for over 40 years!). Recently recieved a kit of Revell Dambusters as a present. Its hard work. Messed up the undercarriage (too fiddly). At the moment working on the front gun turret. Has me stumped: dosent seem to correspond to the instructions. Help please.
Re: Beginner here
Welcome!
Hopefully someone will be along soon to help.
Re: Beginner here
Join Flickr, upload some photos, show us what is going on
Otherwise......
Nope, not a mind reader sadly
Re: Beginner here
Hi there,
I have the Revell Dambuster's lanc in the stash but haven't got around to building it yet.
If you could give us more of an idea as to what problems you're seeing with the turret and as Scott mentioned post a couple of photos to show what you're up against then I'll dig out mine and see if I can help figure it out.
Just out of interest which of the marking options are you building yours up into? I'm still dithering on which on to choose for mine.
Re: Beginner here
:welcome:
Re: Beginner here
:welcome: :th: :th: :welcome:
:th: :th: :cheers2:
ForeverPlasticKits
Re: Beginner here
Post by ForeverPlasticKits »
:welcome:
cmclernon
Ireland
Re: Beginner here
Post by cmclernon »
Tomcat64 wrote: Sun Jan 24, 2021 8:47 am Hi there,
Im trying to sent you photos but keep getting told file too large
cmclernon
Ireland
Re: Beginner here
Post by cmclernon »
I sent the following to Revell:
Sorry to bother you again, but I don’t seem to be able to be able to assemble the front gun turret as illustrated in the instructions (Steps 46 – 48). Parts 45 and 46 seem different looking from illustrations. Trying to assemble these would seem to leave a gap between the turret assembly and the nose of the fuselage (see photo 2). I’ve made a guess at how parts 45 and 46 should be put together (photos 3 and 4). Finally I can’t see how the turret can be joined without glue (presumably so the turret can swivel) without the turret simply falling out.
I'm using Guy Gibsons markings.
Forget previous reply: ;photos included.
cmclernon
Ireland
Re: Beginner here
Post by cmclernon »
Twokidsnosleep wrote: Sat Jan 23, 2021 10:43 pm Join Flickr, upload some photos, show us what is going on
Otherwise......
See photos. Turret parts not as illustrated (photos 1 and 5) there seems to be a gap between the turret assembly ( Photo 2 dry assembly) and the fuselage. Turret assembly falls out if not glued to fuselage.
Parker
Re: Beginner here
Post by Parker »
Does part 47 fill the gap?
Re: Beginner here
Does the big piece #47 fill the void??
I can't tell if that is on the turret or not in that last picture
oh, Parker beat me to it :th:
Re: Beginner here
Ok that definitely doesn't look right does it.
I've grabbed the instructions & clear parts frame from the one I've got in the stash, and I think you might have used part 59 instead of 45.
They're similar but 59 is a little taller and I'm guessing would be a part of the mid-upper turret that wasn't used on the Dambuster's lanc but probably included as part of a generic Lancaster kit from Revell.
I'll have a better look tomorrow but maybe recheck your clear frame.
Re: Beginner here
I've taken another look at your pics and the clear frame this morning and I'm still thinking you've grabbed the wrong turret...
I'm not sure how clear this will be but here is a photo of my clear parts frame, with number 45 indicated by the green arrow and 59 with the red one.
So the part 45 I've got seems to tally with the diagram in the instructions, hope that helps.
Just on posting photos (I saw you were having problems with that earlier) you will need to host them on an external site such as Flickr and then link to them from the forum. Unfortunate the forum currently doesn't have sufficient capacity or bandwidth to host directly uploaded photos which is why you were probably bouncing off the size limit.
There is a quick guide on how to use the Flickr integration on the forum ---> here
It can seem a little daunting to start with but really gets easy once you've got your head around it - as always feel free to ask if you need any help.
Re: Beginner here
Excellent work @Tomcat64
Above and beyond the call of duty
:th:
cmclernon
Ireland
Re: Beginner here
Post by cmclernon »
Oh yes, I see the part now: it broke off into the bag.
cmclernon
Ireland
Re: Beginner here
Post by cmclernon »
Anyone thinking of doing the Revell Dambusters kit, please note that in Step 56, use parts 63 and 64. 61 and 62 don't fit.
Re: Beginner here
cmclernon wrote: Sun Jan 31, 2021 10:59 pm Anyone thinking of doing the Revell Dambusters kit, please note that in Step 56, use parts 63 and 64. 61 and 62 don't fit.
I stay right away from Revell and airfix mostly. I hear too many sad stories.
Return to “Introductions”
